575M - F1 to Gated 6 Manual Conversion | Page 14 | FerrariChat
Discussion in '456/550/575' started by dhalperin13, Apr 3, 2021.
  1. Qavion
    Qavion F1 World Champ
    14,500
    Ian Riddell
    Developed?
    I've been trying to help folks (in FChat DM) with wiring issues associated with the conversion wiring. I'm not associated with EAG, but I think I'll need to know how EAG does it (to help folks in the future).
    If we could get a definitive answer for this on both the F1 car and the non-converted gated car (i.e. does the immobiliser have to be turned off to crank the engine), that would help us figure out how each car is wired up. On F1 cars, usually the Immobiliser or the RH Motronic ECU (after being activated by the Immobiliser ECU) sends an "OK to start" signal to the F1 TCU on a particular wire. The F1 TCU then allows engine cranking (using its logic for start). i.e. The F1 TCU sends an earth to the starter relay on a different wire. Since the F1 is being removed on converted cars, the starter relay has to get the OK to start signal directly from the Immobiliser ECU or RH Motronic ECU. This is achieved by putting a jumper wire on one of the F1 system connectors. i.e. the two aforementioned wires are joined together.
    e.g. on the F430
    This jumper appears on manual cars, too. The plug is part of a common wiring system.
  2. tazandjan
    39,311
    575Ms crank fine with immobilizer armed but will not start. When you press the fob in the US, you should get two beeps letting you know the alarm is disarmed and the immobilizer is not active. When you lock her, you should get one beep. This varies with different country alarm kits. See attached alarm manual.
    dhalperin13, Auraraptor and Qavion like this.
  3. Qavion
    14,500
    Ian Riddell
    Is this for both the manual and the F1, Taz?
    I'm trying to find some similarities between the 575 and another (single) F-car of this era, but the 575 seems to be a mixture of several F-cars. Anyway, anything from the 360 up until the option of a manual (gated) car was removed, seem to have this jumper plug.
    The 575 probably has a fixed earth on pin 6 of the jumper plug (like the gated F430). On other cars, pin 6 either goes to the Immobiliser ECU or to the RH Motronic ECU. On cars with F1, the jumper plug is replaced with a wiring harness which goes to the F1 TCU.
    To be confirmed.
    dhalperin13 and Ferrari55whoa like this.
  4. tazandjan
    39,311
    Ian- Believe that is for both, but not 100% sure.
    Qavion likes this.
  5. Chupacabra
    Chupacabra F1 Rookie
    3,583
    Behind a drum kit
    Mr. Chupacabra
    I get no beeps at all, but the immobilizer is functional and defeats as it should.
    FWIW, I had no issues with mine post conversion. 360 Trev and Sam did the ECU work; perhaps they could be of assistance
  6. tazandjan
    39,311
    Alarm siren is likely shot if it is a US model.
  7. vandevanterSH
    vandevanterSH F1 Rookie
    3,335
    AR
    Stephen Van Devanter
    Same sequence with OEM gated. No chirps, no start…siren shot (battery leak)
    Qavion likes this.
  8. Qavion
    14,500
    Ian Riddell
    You mean you can crank the engine without disabling the immobiliser?
    Taz, do you have a paddle shift on your car?
  9. vandevanterSH
    3,335
    AR
    Correct, the engine cranks but not start. Perhaps the most helpful point I discovered, by desperation, is if the siren has gone tits up, the immobilizer won’t disable in usual manner but will disable with ignition on and then pushing FOB.
    Qavion likes this.
  10. Qavion
    14,500
    Ian Riddell
    Great tip, thanks. I wonder if the “ignition on” method bypasses some kind of siren testing process. I’ve noticed on my F355 I can turn the ignition and press the fob, and the siren doesn’t chirp in its usual manner.
  11. vandevanterSH
    3,335
    AR
    “Great tip”….. I spent a fair amount of research time looking for a solution to “No chirps…no Start” for 575 that didn’t involve a long flat-bed ride or removing immobilizer/siren, no luck. Fortunately, Monkeys and Typewriters approach provided solution.
    dhalperin13 and Qavion like this.
  12. tazandjan
    39,311
    Ian- Affirmative on the crank, no start. For that reason, whenever I refuel, I lock her to keep myself from getting in, trying to start and only having the engine turn over. 550s will not even crank.
    Qavion likes this.
  13. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    Hey Guys,
    I'm currently only very briefly checking up on messages as I'm still on vacation with family but I do have developed a full immobilizer delete solution for this era of immobilizer that does work on the 575M, 360, etc. I don't tend to do it often however as it has both pros and cons associated with it.
    There are a couple wires which sometimes need to be spliced to bypass a relay (if you cannot crank engine with immo on - which actually depends on model) and most importantly an engine ECU reflash to be done - then the immobilizer is completely eliminated and you can just use your key to start the vehicle without fobs being required.
    This is not a solution for everyone however as if you have an electrical problem with the immobilizer itself or want to completely remove it you will unfortunately loose your remote central locking! Only central locking on the key then works. The immobilizer box combines both the key fob receiver function and immobilizer in one unit. This was later corrected on newer models but this generation sucks in that regard.
    Trev
    Sent from my CPH2145 using Tapatalk
  14. dhalperin13
    dhalperin13 Karting
    Mar 26, 2021
    234
    Dan
    @360trev thanks for checking in Trev!
    EAG is hoping to get an update from ECU Repair today. They confirmed earlier this week that they are in possession of the units. My understanding is that EAG is going to have a call with their technician today.
    I wish I had the technical foundation to understand the nature of the problem here. @TheNewEAG Maybe Chris, EAGs CEO will be available to provide some insight.
  15. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,330
    Gibraltar
    360trev
    Let me give them a quick call and find out the situation for you ... [emoji106]
    dhalperin13 likes this.
  16. dhalperin13
    dhalperin13 Karting
    Mar 26, 2021
    234
    Dan
    Immobilizers and ECUs are “repaired” and being shipped back to EAG this week. I should get some more detail on the extent of the repairs soon.
    I ordered a couple neat items today through Daniel @Ricambi America:
    1) Maranello Skunk Works Sway Bar
    2) MSW Steering ECU
    @Cribbj is doing some cool work on our Maranellos! Thank you!!
    Ferrari55whoa and brogenville like this.
  17. Ferrari55whoa
    Ferrari55whoa F1 Rookie
    3,472
    Los Gatos, CA
    Eric
    Dan when you get the car back we need to have a party at your local cars & coffee!
  18. dhalperin13
    dhalperin13 Karting
    Mar 26, 2021
    234
    Dan
    Maybe I should road trip out west and then ship her back to Chicagoland :)
    Mellow_Maranello likes this.
  19. Ferrari55whoa
    3,472
    Los Gatos, CA
    Eric
    My youngest brother is talking about a few cubs games with bobbleheads and if I fly out then I will definitely let you know so I can see your amazingness!
  20. teamwill
    teamwill Rookie
    Apr 19, 2023
    1
    Hi Trev… not used this forum before but Fabio said I should get in touch regarding ECU remap as having a new fiammenghi fitted to my 575 tomorrow
    Thanks !
  21. Ferrari55whoa
    3,472
    Los Gatos, CA
    Eric
    @teamwill if you use the @360trev with the “@“ that will tag him in the alerts.
    Congrats on Fabios set up (love my remote mufflers).
    Your profile doesn’t say where you are located in the world (if you don’t mind sharing).
    Thanks — Eric
    brogenville likes this.
  22. dhalperin13
    dhalperin13 Karting
    Mar 26, 2021
    234
    Dan
    Mirek, brogenville, Qavion and 2 others like this.
  23. Ferrari55whoa
    3,472
    Los Gatos, CA
    Eric
    #erotica
  24. Condor Man
    Condor Man F1 Rookie
    4,938
    Los Angeles
    Looks like they are now back on the case!
    The dash looks so much better too!
  25. dhalperin13
    dhalperin13 Karting
    Mar 26, 2021
    234
    Dan
    Before
    Thank you!! I was only able to drive the car for a couple of days before dropping it off with EAG and that dash kept catching my eye. The luggage shelf was repaired as well and by all accounts is looking (and smelling) great.
