575M Shopping - Independent Inspection | FerrariChat
Discussion in '456/550/575' started by 8500rpm, Nov 12, 2021.
  1. 8500rpm
    8500rpm Formula Junior
    May 20, 2014
    546
    San Francisco Bay
    Chan
    Hi all, F355 alumni and looking to get into my first V12 F-car! Surprisingly, haven't been able to find an authoritative buyer's guide for the 575M.
    I'm looking at a car that is located quite far from any dealer or independent Italian car specialist. So I'm afraid I may need to settle for a non-specialist mechanic near the seller for a PPI. The other complication is that I would need to buy this car remotely so a good pair of eyes is absolutely mandatory.
    If anybody here could help me out with what a good baseline inspection guide should contain for these bruisers?
    To demonstrate that I'm really trying to do my homework, I'm going to take a stab with my prior F-car experience. Would appreciate if anybody can add or elaborate!
    1. Elephant in the room: Any CELs or other unresolved errors?
    2. SD2 clutch life readout for the F1 clutch - this has a recent service record showing new clutch and near-full life, I'm not too worried about it but will verify.
    3. Presence of any mods or aftermarket components - Exhaust, suspension, any common or risky mods?
    4. Condition of drive belts - Depending on the service records the car may need new belts per the 5-year interval
    5. Ignition - Coil on plug, more reliable than the 550. Do these need to be looked at every major service?
    6. Compression test - this is almost always recommended for older cars with valve guide issues but perhaps not an issue for the 575?
    7. Headers and cats - another sore spot on older V8 Ferraris. Any concern on the V12s?
    8. Cat temp ECUs - Do these fail as regularly as they do on the older cars?
    9. Put it on a lift and look for any engine oil leaks, coolant, gearbox/transaxle oil, diff oil leaks
    10. Condition of F1 fluid, gearbox fluid, brake fluid, diff fluid
    11. Condition of coolant hoses and other fluid lines
    12. The usual brakes/tires/battery condition
    13. Structure, rust, evidence of collision repair
    14. Cosmetic condition (dings, paint thickness and protective coatings, interior leather, sticky plastics)
    Any feedback or advice would be appreciated!!
    -Chan from California
    Pic of my former 355 F1 for authenticity.
  2. Ferrari55whoa
    Ferrari55whoa F1 Rookie
    3,268
    Los Gatos, CA
    Eric
    #2 Ferrari55whoa, Nov 12, 2021
    8500rpm likes this.
  3. 8500rpm
    May 20, 2014
    546
    San Francisco Bay
    Chan
    #3 8500rpm, Nov 12, 2021
    Thanks for the PDF! Noteworthy additions:
    Check fuel filters, tank and lines for leaks
    Mirek likes this.
  4. 8500rpm
    May 20, 2014
    546
    San Francisco Bay
    Chan
    Another addition: Vacuum and idle lines, does the car idle smoothly?
  5. DECLINE1965
    DECLINE1965 Rookie
    Nov 12, 2021
    1
    So. Cal / Az.
    DON CLINE
    Hello everyone,
    I will be watching this thread closely because I am considering a 550 or 575.
    I'm a novice, never owned a Ferrari, always wanted one. I have fewer years in front than behind.
    My life stage, maturity and mechanical aptitude is fueling this. I'm reading all I can from the community.
    I will have one, love it, work on it, drive it respectfully and pass it on when I go.
    Don
    8500rpm, root and white out like this.
  6. white out
    white out Formula 3
    Mar 3, 2010
    1,263
    Compression test - 355 thing
    Headers and cats - 355 thing
    Cat temp ECUs - do fail, but it's quite obvious as the car will be in limp mode
    Common mods - exhaust and suspension (usually suspension ECU swaps) as the 575 is a bit softer in sound and feel than people expect
    8500rpm likes this.
  7. henryr
    henryr Two Time F1 World Champ
    22,280
    Atlanta
    Juan Sánchez Villa-L
    575 are pretty robust
    i can;t recall any systematic non cosmetic issues
    root, 8500rpm and white out like this.
  8. vandevanterSH
    vandevanterSH F1 Rookie
    2,810
    AR
    Stephen Van Devanter
    As a long term 575 owner, 17 years/105,000 miles, it's a pretty reliable car but even minor issues are $$$$. The only recurring problem has been issues with the cam belt system. I've had four (five?) belt services and at three there have been issues with worn bearings. The first was at 10k miles still under warranty. Both fuel pumps replaced at 100k miles.
    8500rpm likes this.
  9. DPA360
    DPA360 Karting
    Jul 16, 2007
    153
    Los Angeles Cali
    I just dropped of my 550 for service with Carl at Blackhorse. He is super knowledgeable, honest, very reasonable! Super hard to find here in LA. Good luck
    Mirek and 8500rpm like this.
  10. Ferrari55whoa
    3,268
    Los Gatos, CA
    Eric
    Last year when I was on the hunt there was a black 575 west of chicago a few hours and I had considered paying the fee to have an independent from chicago go do the PPI for me. Depending on how remote the one is you are looking at you could always go that route and send someone to the car.
    8500rpm likes this.
  11. 8500rpm
    May 20, 2014
    546
    San Francisco Bay
    Chan
    Thanks for sharing! These are the tensioner bearings, right? The ones that many people would rather use Hill Engineering parts over OEM SKF bearings?
  12. root
    root Formula Junior
    487
    Bay Area, Ca
    #12 root, Nov 14, 2021
    Hi Chan, I remember your lovely F355 and the memorable driving video you had of it. We met once at a mutual friend garage when I was considering F355 to buy. After much research I decided to buy 550 partly because it is so much more robust than the F355 and more in line with my driving preference. I wanted a V12 up front with stick shift in my "affordable" range. That limited my search to 456 or 550 models. The 575 addressed a few of the 550 weak points such as engine mounts and primary coolant hoses. Both are easily upgradable in the 550. The HE timing belt tensioners should address the weak OE tensioner issue.
    8500rpm likes this.
  13. vandevanterSH
    2,810
    AR
    "These are the tensioner bearings, right?"
    The 10k mile failure was the right cam drive "sprocket" bearing the other two were tensioner, at 70k miles several other components needed to be replaced; can't remember exact details. This is obviously a sample of one but something to think about since a complete failure in this system would be catastrophic.
  14. Themaven
    Themaven F1 Rookie
    Nov 2, 2014
    4,338
    Eastdown
    Darius
    I wish I could help with personal experience but almost nothing has gone wrong with my 575 in the six and a half years I have owned it. (yet!)
    The only issues I have had, which seem pretty universal, are minor, if a tad irritating:
    stickies - like roaches, always with us
    leather trim around the tailgate loose and needing fixing
    bonnet (hood) strut weak in cold weather
    A couple of the 575s I looked at had corrosion on the inside front edge of the bonnet/hood, and the dash leather shrinkage and waviness, as well as leather trim issues elsewhere, which can add up.
    All in all one of the most reliable cars I have owned. So far.
  15. 8500rpm
    May 20, 2014
    546
    San Francisco Bay
    Chan
    Thanks for all the input guys!
    Seems like the car I've an eye on needs a belt change. Do you guys typically add a new water pump along with the belts as a preventive item?
    I know it's a good idea to upgrade to the aftermarket all-aluminium unit found on Ricambi America either way.
  16. 8500rpm
    May 20, 2014
    546
    San Francisco Bay
    Chan
    Will gladly share my experience here when I have a car in hand! Good luck and feel free to use this thread for technical inquiries if you like.
  17. tazandjan
    38,943
    Mine still has the original water pump at 27,000 miles and 18 years. Unless leaking......
    But she has had the coolant changed every two years for 14 years, at least.
