599 GTB Instrument Panel Indicator Lights Failure. | FerrariChat
Discussion in '612/599' started by 360modena2003, Dec 2, 2017.
  1. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,380
    Hello,
    I started my 599 without waiting for the "check" to go off and a "electrical system failure" showed up my display.
    Now the indicator light of the blinkers, high beam, seat belt, check engine light do not illuminate anymore - everything else works perfectly.
    Is there a dedicated fuse for these "bulbs", any suggestions? Otherwise I will pull the instrument panel and check the bulbs individually.
    Thank you
    Sent from my EVA-L19 using Tapatalk
  2. afwrench
    afwrench Formula Junior
    Nov 24, 2004
    593
    NY
    Have you tried turning off the main battery switch and going through the reset procedure?
  3. Mor
    Mor Karting
    Oct 14, 2017
    95
    You need instrument cluster repair. Sorry, very costly thing. On thursday I received info about my cluster from Autotronics. 3200 GBP plus VAT. Ferrari tex is not cheap.
    Wysłane z iPhone za pomocą FerrariChat
  4. 360modena2003
    Jul 11, 2009
    2,380
    Yes, I did, not luck.
  5. 360modena2003
    Jul 11, 2009
    2,380
    You don't need to those prices - there is a company in California that specializes in instrument cluster repair- FAI - there are others as well.
  6. Mor
    Mor Karting
    Oct 14, 2017
    95
    First it was 1200GBP, but during repair they said I need new circuit board. Even they try repair old one two weeks, the cluster falls on tests. So now all costs of the repair are as I write. If he can do this in less money, it’s great. We will see.
  7. Mor
    Mor Karting
    Oct 14, 2017
    95
  8. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
  9. Mor
    Mor Karting
    Oct 14, 2017
    95
    Now I need guarantie repair, but next time I’ll go with them.
  10. BMWairhead
    BMWairhead Formula 3
    Sep 11, 2009
    1,035
    Portland, OR
    Ted
    BBA Reman advertises 599 gauge service. I've used them for ABS controller rebuilds and have always been happy.
