599 GTO question | Page 2 | FerrariChat
599 GTO question
Discussion in '612/599' started by MaxPower, Mar 18, 2012.
  1. MaxPower
    MaxPower Two Time F1 World Champ
    Mar 28, 2006
    20,786
    At sea ... aahhh ...
    MP
    Another strange thing happened the day before I gave the car in to the shop ...
    Going over a bridge (nothing steep), 4th gear in full auto, manettino in "wet" mode, 60 kmph, foot OFF the accelerator ...
    Was raining, so in centre lane, away from drains, running/still water, etc ...
    The rear end fishtailed !!! Fortunately I caught it or would certainly have spun around ...
    Now I'm officially scared !!!
    Any thoughts folks?
  2. speed racer
    speed racer Formula 3
    Feb 16, 2008
    1,462
    Burr Ridge IL.
    PJ
    Maybe not tires/rims.....F1 gearbox issues....
  3. MaxPower
    Mar 28, 2006
    20,786
    MP
    update ...
    picked up the car yesterday ... the only aberration they found was that they had to remove 5g of weight from one of the rear tyres.
    i'm hoping that this imbalance may have been the cause of the instability. will take it for a run on the weekend and see how it goes.
    fingers crossed.
  4. MaxPower
    Mar 28, 2006
    20,786
    MP
    how wld that affect stability?
  5. MARK1992
    MARK1992 Formula 3
    Feb 7, 2010
    1,214
    Have you driven it since they removed the weight, even at low speeds?
  6. MaxPower
    Mar 28, 2006
    20,786
    MP
    just picked it up yesterday ... that's it.
  7. MaxPower
    Mar 28, 2006
    20,786
    MP
    btw, spoke to sm ... he declined on the excuse that he doesn't have diapers thick enough ...
    :rolleyes:
  8. Dipsomaniac
    Dipsomaniac F1 Veteran
    Mar 23, 2006
    5,956
    Doha/Sydney
    Derek K
    well are they able to plug in the PC & data monitors and then we take it for a run and they can analyse the data upon our return?
  9. MaxPower
    Mar 28, 2006
    20,786
    MP
    i'll ask them ... good suggestion, tnx ...
  10. Ducati
    Ducati Formula Junior
    Jan 23, 2004
    362
    So. Cal
    Joe
    At those speeds it is like a race car. My suggestion is a full race style alignment check.
    Corner weights, ride height, camber adjustment, toe out--In setting and last just before any ride like that check the tire pressures yourself.
    I am sure the car was tested at the Fiorano circuit at high speed but alignments do change particularly during the first few hundred miles.
    You want confidence witht the car. A knowledgeable shop can also suggest some changes if it is still not right after that.
    Stradale's can be a very sensitive to camber and ride height so my shop added some negative camber to make my car less nervous. Just an idea.
  11. MaxPower
    Mar 28, 2006
    20,786
    MP
    good suggestion mate. unfortunately, there isn't anywhere else where i can really take this car locally ...
    will ask around tho ...
  12. j09333
    j09333 Formula 3
    May 7, 2004
    1,153
    I usually do over 300km/h run everytime I drive my car.
    I feel your pain.
    My car showed somewhat fearful reaction one time.
    Changed parts, balance, alignment and pretty much everything with no correction.
    It was tire after all.
    So, when time comes you will need new tires, why not buy ones now and try it.
  13. MaxPower
    Mar 28, 2006
    20,786
    MP
    u reckon the car was supplied with defective tyres? cos car's less than 3 months old ...
  14. j09333
    j09333 Formula 3
    May 7, 2004
    1,153
    It happend when I put new tires on.
    I did everything suggested with no result.
    Tire change was the last thing I tried, but should have done it from day one.
    Didn't expected tire defect for once, and after all those troubles, even after resolution, I lost interest for the car and sold it.
    Just from my experience.
  15. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    Get new tires.
    Keep the old set if that's not the answer. You will need them anyway.
    If it is the tires, the tire warranty should cover it.
    Hope this works out.
  16. SW73
    SW73 Karting
    Nov 27, 2010
    119
    Singapore
    Steven
    Hello Max
    I did 3 breakfast runs recently on the NSHW , first time i drive the GTB up , tyre pressure was at 2.2 Front and 2.1 Rear when cold . Have the same feeling as you during 210 - 260 km/h . Did not push it further .
    Second run , i release the tyre pressure to 2.0 Front and 1.9 rear , run was almost prefect . No more such feelings at all . Ride felt planted at all speeds , up to 310km/h .
    Third Run , same results as second run .
    Going for another one this Sunday , have just increased the Tyre pressure today to 2.3 Front and 2.1 Rear . Will let you know if that unstable feeling comes back .
    Stock GTB , running 20 inch wheels .
  17. MaxPower
    Mar 28, 2006
    20,786
    MP
    sounds good ...
    i'm doing a run this sunday too, lets see how it goes ...
    tnx ...
  18. MaxPower
    Mar 28, 2006
    20,786
    MP
    update guys ...
    took the beast up north for 3 days and ran her hard ...
    surprisingly, the skittish behaviour did not manifest itself ...
    strange ...
    now i'm stumped ...
  19. j09333
    j09333 Formula 3
    May 7, 2004
    1,153
    Then I would consider it as tire break in...
    Every new tires need at least 400-500kms of runin
  20. MaxPower
    Mar 28, 2006
    20,786
    MP
    well, i'm now at 4,000 km on the clock ...
    over the weekend i put on just 1,000 km ...
    so it just can't be the running in ...
  21. Sareve
    Sareve F1 Rookie
    Oct 23, 2007
    2,968
    Singapore/Melbourne
    Daniel
    Maybe it was a difference in road quality? I felt that the road we travelled on the first time you took your car up to 300+ was significantly bumpier than the roads we've been travelling on over the past few days.
  22. greyhair
    greyhair Formula Junior
    Jan 1, 2011
    477
    Central Valley Ca
    Great News
    I think the wieght and rebalance on the wheel/rims worked for you, it did for me.
    Sometimes a good rebalance person will move the tire over the rim to help off set the rim problems/defects from the manufacture so the rim will need less weight when balanced correctly with the tire imperfections as well. With the 5g of balance wieght removed and a good balance job may have solved or help solve the problem. Sometimes the car manufactures rush this step to get the car out to the public. That is why some wheel balancer machines are better than others. Hunter balancer puts a load on the wheel as it rotates to simulate real world road conditions and tells the guy exactly where to place the wieght for best performance while measuring the rim fro being true and within the manufactures tollerances.
  23. MaxPower
    Mar 28, 2006
    20,786
    MP
    possible, but did not feel like it was the road ...
    i'm hoping it was just that extra 5g ...
    even so, i'm meeting the local michelin boys to do a full check on their machines ...
  24. 5nine9OC
    5nine9OC Rookie
    Apr 11, 2012
    17
    Orange County
    That doesn't seem right at all. Why don't you grab one of the service guys at your local dealership and take him for a spin. Take care of it as soon as possible.
  25. carcommander
    carcommander Formula 3
    Sep 28, 2006
    1,705
    Southeast
    Jim
    I haven't been at 300k lately but sometimes full tread depth tires squirm at speed. Now that the tires are worn it may have stopped.
