599 project,rebuild/track day car | Page 2 | FerrariChat
Discussion in '612/599' started by kiwifaza, Jul 15, 2015.
  1. MaseratiCorse
    MaseratiCorse Formula Junior
    Nov 13, 2014
    472
    Melbourne, Australia
    Nicholas
    Believe they also have different flanges for the cats?
  2. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,460
    Check Fabio Engineering - Italian guy that is making some very interesting exhausts.
  3. Andrew 912
    Andrew 912 Karting
    Dec 18, 2010
    160
    AES
    #28 Andrew 912, Jul 23, 2015
  4. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    43,050
    ESP
    Bas
    Fabio makes beautiful stuff, but he's in Italy. I know for a fact that there are some very skilled guys in NZ which would be much easier for the OP...
  5. kiwifaza
    kiwifaza Karting
    May 12, 2009
    145
    New Zealand
    #30 kiwifaza, Jul 25, 2015
    LightGuy likes this.
  6. MaseratiCorse
    Nov 13, 2014
    472
    Nicholas
    Rosso Scuderia? Gorgeous!
    Let the project begin... :)
  7. simsko
    simsko F1 Rookie
    Feb 5, 2012
    3,635
    Awesome base to start from.
  8. kiwifaza
    kiwifaza Karting
    May 12, 2009
    145
    New Zealand
    Yes it`s Rosso Scuderia, and Simon it is a great base, in fact too good , its becoming very clear that the car is too good to bastardize in any way, which is a bit of a double edge sword, great for me that its a pin of a car but hard to take it out to the dream of a hard out track car, I`am going to wait until we get the engine apart,see how the costs go and then settle on how far to take it, current thoughts are HTGE suspension,aero kit,2nd cat delete ,HGTE tcu upgrade, GTO wheels, oh nearly forgot, Red Green White stripe down the middle
  9. kiwifaza
    kiwifaza Karting
    May 12, 2009
    145
    New Zealand
    #34 kiwifaza, Jul 28, 2015
  10. simsko
    simsko F1 Rookie
    Feb 5, 2012
    3,635
    Stripe sounds great!
  11. PAP 348
    Dec 10, 2005
    100,236
    Mount Isa, Australia
    Pap
    Awesome car..................wanna sell it? :D:D
  12. LightGuy
    LightGuy Four Time F1 World Champ
    Oct 4, 2004
    46,160
    Texas
    David
    IMO you are on the right "track" :D
    You might want to have some custom brake ducts built. Great bang for the buck.
  13. phrogs
    phrogs F1 Veteran
    7,363
    Kzoo Michigan
    How feed did it get? And lomg ago before your hands touched it?
    I have fixed a couple of flood cars. Really I like them better than bent metal.
  14. kiwifaza
    kiwifaza Karting
    May 12, 2009
    145
    New Zealand
    #39 kiwifaza, Aug 5, 2015
    Progress and good luck, striped the motor and the news is fantastic, heads and valve train completely untouched/undamaged , left bank clean , right bank took the brunt , but because it was at low revs ,very little damage. at this stage ,one bent rod ,one piston&liner and that's it as far as the eye can see, have sent everything to be assessed and crack tested by the engineers but at this stage its looking like a very light repair
  15. kiwifaza
    kiwifaza Karting
    May 12, 2009
    145
    New Zealand
    jonny , according to the owner the car got very little water inside,not enough to puddle above the carpet but the intakes are plumbed to the front bumper and a 6ltr engine doing 1200 rpm sucks 7200 cubic ltrs of air per minute, that makes for a pretty good vacuum cleaner,LOL , the car was pushed from the puddle by two road workers with in minutes and without the owner and his wife having to exit the car , so all in all it didn't get all that wet for very long at all, the rebuild process is proving to be very painless and relatively simple, to be fair i have a great team on board for the project
  16. PAP 348
    Dec 10, 2005
    100,236
    Pap
    Awesome news, looking to be a very easy (and cheap) fix for this car. :)
  17. F.Engineering
    F.Engineering Formula Junior
    343
    ITALY
    Fabio
    Hi, I'm Fabio from Italy, i have did the headers 6-1 for 550/575 but at the moment not for 599, on ebay Germany now are available une set of GTO headers, but remember that your 599 have 4 upstream lambdas and 4 downstream lambda, instead GTO have 2 upstream lambda and two downstream lambda, then or you modify ECU or you modify headers.
    With 6-1 you will have a gorgeous sound and more engine power.
    Best Regards
    Fabio
    Ferrari 599 GTO Auspuffkrümmer Krümmer Kat Katalysator Exhaust Manifold Catalyst | eBay
    Ferrari 599 GTO Auspuffkrümmer Kat Katalysator Exhaust Manifold Catalyst | eBay
  18. Jdahlstrom
    Jdahlstrom Formula 3
    Feb 28, 2005
    1,184
    Miami, Fl
    Josh Dahlstrom
    #43 Jdahlstrom, Aug 5, 2015
    Kham97 likes this.
  19. galt
    galt Formula 3
    Jun 19, 2005
    1,141
    Love those wheels for the 599. Are they available in the right size and offset to match the factory GTO wheels?
  20. Jdahlstrom
    Feb 28, 2005
    1,184
    Miami, Fl
    Josh Dahlstrom
    Honestly I am not sure. You might have to call bbs for that answer.
  21. Roupin
    Roupin Formula 3
    Oct 7, 2013
    2,167
    Encino
    Roupin
    Negative: BBS Road Wheels Detail | BBS USA
  22. Jdahlstrom
    Feb 28, 2005
    1,184
    Miami, Fl
    Josh Dahlstrom
  23. phrogs
    phrogs F1 Veteran
    7,363
    Kzoo Michigan
    Makes sense, Had no idea they were bottom feeders.
    I'm looking at one now and it looked really clean but it ended up being the ingestion into the motor that totals the cars.
    thanks for the education.
  24. kiwifaza
    kiwifaza Karting
    May 12, 2009
    145
    New Zealand
    #49 kiwifaza, Sep 14, 2015
    Finally parts are all here , unfortunately my mechanic is away for a month but it's still great to have everything ready too go, most excited about the new exhaust looks fantastic can't wait to here it !!!
  25. RossoNero
    RossoNero Karting
    Sep 7, 2012
    164
    JHB, South Africa
    Henry
    Please do keep us up to speed on how easy / difficult the installation of those 6-to-1 headers is.
    I have a 599 and was planning on installing the Novitec system, but would far prefer a system that gives you that high-pitched GTO noise.
