599 Suspension upgrade options | FerrariChat
Discussion in '612/599' started by redbadge1, Jun 18, 2025.
  1. redbadge1
    redbadge1 Rookie
    May 14, 2017
    5
    Hi 599 owners,
    My rear suspensions are leaking and resulting a pretty pretty bumpy ride at the rear end. I'm looking into what options do I have to make it a better handling car. I believe the dialed in suspension will make 599 a much more enjoyable car.
    Shockingly there's no off the shelve aftermarket options from any reputable brands: Ohlins, Bilstein, Nitron etc.
    The feedback I got from the novitec/KW one was not good. I didn't like the KW I had on other cars so that's off the list.
    I can stay OEM, probably buy the Nagengast, or buy custom Ohlins DFV by Madeno, but not sure if i'm ready to invest 10k on suspensions. What other options should I be aware of?
    bamaman likes this.
  2. white out
    white out Formula 3
    Mar 3, 2010
    1,287
    KW is the only system that comes to mind. Depending on where you are located, Nitron might be able to make you a set.
  3. George Vosburgh
    George Vosburgh F1 Rookie
    There are plenty of coil-overs for the car. Also you can send them to Europe for a remake, I don't advise doing this. I went with OEM replacement. My first set went almost 50K miles so I think I'm now done with this. I expect them to hold for another 40 or 50K.
    375+ likes this.
  4. mike051
    mike051 Karting
    Jan 21, 2019
    89
    Be careful on the fact your 599 has magneride system. If you put non-magneride system, you have to manage the errors the Control units are going to send you.
    In Europe, Nagengast, in Poland, has a good reputation for rebuilding magneride systems.
    https://nagengast.pl/en/kategoria-produktu/ferrari-en/
    brogenville likes this.
  5. white out
    white out Formula 3
    Mar 3, 2010
    1,287
    There are delete modules for preventing error lights. Easy plug and play.
  6. mike051
    mike051 Karting
    Jan 21, 2019
    89
    You can also put a black tape on the dashboard. It’s easier.
    More seriously, it depends on whether you think the magneride system is part of the car and should continue to be used or not.
  7. windsock
    windsock Formula 3
    1,149
    Rebuild Masters here in the US has done at Least a dozen sets of Magnaride shocks for the 458, 599 and California and all have been great, and cost was about $800 per shock.
    George Vosburgh likes this.
  8. tazandjan
    39,141
    Do you have a url for them?
  9. mike051
    mike051 Karting
    Jan 21, 2019
    89
  10. redbadge1
    redbadge1 Rookie
    May 14, 2017
    5
    Thanks for for the info. Yes I'm aware of the trade off on the Magneride and Manettino. Have to say the gen 1 Magneride on the 599 is is outdated as a suspension technology so I don't have any problem opting out for them if a high quality modern aftermarket options is available. Sadly it doesn't look like any companies do in house design/test for 599 suspension, unless I spend $$$$ on the Madeno Ohlins set.
    I know Nagengast is a great option for rebuild. Has anyone here actually got theirs rebuilt by Rebuild Masters? I've never heard of them and I don't see 599 as a option on their website.
  11. KB599GTB
    KB599GTB Rookie
    Feb 2, 2020
    33
    Benjamin Karl Bussey
    I have had some fluid leak out of two of my shocks but cannot detect any change in ride quality or suspension behavior and have been surprised about that.
    I am also wondering just how much fluid is in these reservoirs, say a cup or pint? Regards, mine is a 2010 599 GTB.
  12. redbadge1
    redbadge1 Rookie
    May 14, 2017
    5
    The volume doesn't matter, once the seal is blown, the pressure won't be stable under different temperatures. You'll gradually feel the lose of the dampening force.
    KB599GTB likes this.
  13. bamaman
    bamaman Formula Junior
    Nov 27, 2015
    936
    Mobile Alabama
    William M (B.J.) Lyon, Jr.
  14. diegolrz
    diegolrz Karting
    55
    Dallas TX
    I am in very early stages of getting a custom coilover setup done for my 612 (OTO with HGT2 package). I have selected MCS as I have them on my track car and they are amazing, I think I will go with the 1way adjustables, I have 2 way remotes in my track car - that is very likely overkill for the 612.
    I have no idea how different the 612 suspension is vs the 599. But if there is interest, I can keep everyone updated as we make progress.
    C4YES likes this.
  15. mike051
    mike051 Karting
    Jan 21, 2019
    89
    Interested in following the progress.
    As far as I know, the 612 has a Sachs technology, similar to the Skyhook system of the Maseratis and different from the Magneride system of the 599.
    You can find more explanations here:
    https://en.wikipedia.org/wiki/Active_suspension
