599 Tail Light Repair | FerrariChat
Discussion in '612/599' started by nota400, Feb 17, 2020.
  1. nota400
    nota400 Karting
    Nov 21, 2015
    82
    Does anyone repair 599 tail lights?
  2. Kiwi599
    Kiwi599 Rookie
    Mar 6, 2019
    28
    Auckland, New Zealand
    Ian
    I had the warning ‘bulb out’ on the dash and couldn’t get the light repaired. I had to buy a new one. In fact I bought 2. I have a good left hand light if that’s the one that’s out.
  3. Rex71
    Rex71 Formula Junior
    Mar 24, 2007
    352
    Jeddah,Saudi Arabia
    Majd B.
    Do you mean you have to replace the entire lamp housing ?
    Not only the LED bulb ?
  4. George Vosburgh
    George Vosburgh F1 Rookie
    Scuding could have rebuilt them for you.
  5. Kiwi599
    Kiwi599 Rookie
    Mar 6, 2019
    28
    Ian
    You can’t change LED bulbs on a 599 only the 612, the 599 is a sealed unit.
  6. brogenville
    brogenville Formula 3
    2,020
    Robin
    Sounds like a cracking bit of design...
  7. Ds599
    Ds599 Rookie
    Jan 3, 2020
    20
    Q100
    Just paid 1k usd for my left rear dealer replacement. It was on most of the time but sometimes it turns off for 10-15 mins. Very common among 599/430/458. Is not the led, is the ic controlling it. At least I found a new use of the broken light lol Image Unavailable, Please Login
    brogenville likes this.
  8. brogenville
    2,020
    Robin
    Send it to one of the instrument cluster repair shops. I would bet that they will be able to fix whatever has gone wrong with the control board.
    599_GTO likes this.
  9. Motorama
    Motorama Karting
    Jul 10, 2018
    157
    Stijn Van Loffelt
    I changed one side and a week later the other went...the resistance of the led increases and triggers the bulb warning..
    Red599 likes this.
  10. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    Unlikely. LEDs don't really have a resistance, they are a constant voltage device (voltage doesn't change across a wide current range). There is a resistor in series with an LED that limits the current so that the LED doesn't break down. It is far more likely that the voltage regulator is failing or the resistor is failing. Based on how the display fails, I am guessing voltage regulator.
  11. Motorama
    Motorama Karting
    Jul 10, 2018
    157
    Stijn Van Loffelt
    All the leds worked. I only got the bulb message while releasing the brake pedal. And only if it's cold outside. If i put some temperature in the light unit there is no problem. Surely a resistance problem
  12. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    Yes, it could be resistance. It is not the 'resistance' of an LED. If the LED works, it is dropping about 1.5V no matter how much current you put through the device. It will get hot and it can burn out but it doesn't dim significantly and it doesn't change resistance. It is some other part of the circuit.
