599GTB oil temp | FerrariChat
599GTB oil temp
Discussion in '612/599' started by Ferdi, Jun 14, 2024.
  1. Ferdi
    Ferdi Rookie
    Oct 3, 2020
    13
    Switzerland
    Ferdi
    Hi All
    Is it normal for the oil temperature to rise to between 120° (248F) and 130° (266F)? The temperature then stabilizes at 110°-120°, in the city it can rise to 130°. But it never goes in to the red range.
    What can cause a high oil temp.?
  2. tazandjan
    39,166
    Does not sound high to me. Oil is not like water and is not going to boil off at those temperatures. It actually works better at the temperatures you note and those temperatures get rid of any moisture in the oil.
    AhmetUz and Skidkid like this.
  3. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    This is how the manual describes it:
    Oil temperature gauge:
    - Blue = Oil T < 80 °C (176 °F)
    - Green = 80 °C < Oil T < 155 °C
    - Red = Oil T > 155 °C (311 °F)
    There's also a separate warning light for high temperature
    brogenville and Skidkid like this.
  4. flat-12
    flat-12 Formula Junior
    Mar 18, 2011
    375
    Germany
    It may also depend on the air temperature and for sure the driver. So Switzerland should be comparable to Germany. In my opinion 130 Celsius is quite high for normal driving, even in heavy traffic.
    Owning a 599 for some years now, the oil temperature of my car is about 100 Celsius driving trough Munich.
  5. Ferdi
    Ferdi Rookie
    Oct 3, 2020
    13
    Switzerland
    Ferdi
    Thank you for your replies.
    I know 130*C is not causing damage or similar, but I'm wondering how the oil temperature behaves on other 599s. What also concerns me is why the oil temperature is so high. Mine was recently inspected and Ferrari reported no abnormalities.
  6. tazandjan
    39,166
    You do have an oil cooler/radiator under the coolant radiator. You might want to check and make sure there is no paper or a plastic bag blocking the cooler.
    Skidkid likes this.
  7. Skidkid
    Skidkid F1 Veteran
    9,519
    Campbell, CA
    John Zornes
    Good idea. The original grill tends to pick up a bunch of stuff, including leaves.
  8. George Vosburgh
    George Vosburgh F1 Rookie
    One of the reasons I went to the GTO grill.
    Skidkid likes this.
  9. Ferdi
    Ferdi Rookie
    Oct 3, 2020
    13
    Switzerland
    Ferdi
  10. Ferdi
    Ferdi Rookie
    Oct 3, 2020
    13
    Switzerland
    Ferdi
  11. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,113
    Atlanta
    Tom Spiro
    Actually, what happens is that leaves and debris get sucked in between the radiator and the AC evaporator and oil radiator.. when I had my radiator replaced, I was shocked at the amount of dry leaves in between them not sure how you would get them out other than compressed air ... and using a lot of it. but I doubt that would cause that much of temp increase.
  12. AhmetUz
    AhmetUz Karting
    Aug 11, 2022
    154
    #12 AhmetUz, Jul 31, 2024
    Hello,
    According to the gauge on your vehicle, your oil temperature seems a little higher than normal (is it always like this?) but you are still not in the red zone, so I don't think there is anything to worry about. I used to have a 599 and the oil temperature of my vehicle was generally around 90-110 depending on driving and weather conditions (sometimes it could drop to 80 in cool weather and highway driving). Only once, in very hot weather and urban traffic, did it get very close to 120, but other than that, the situation was as I mentioned above. In your case, as I said, there is nothing to worry about or to check the car or take precautions. You shouldn't forget that you drive a v12 car :)
  13. Ferdi
    Ferdi Rookie
    Oct 3, 2020
    13
    Switzerland
    Ferdi
    Thank you guys for your feedbacks, I'll keep an eye on this gauge.
    I checked all the gaps around the oil cooler even with an endoscope, no debris and no dry leaves.
    The highest temp i've seen was 140, and it never went higher.
    Some Ferrari-specialists say that's good for the engine so the oil can do it's magic, some say that's too much. As long as it does not exceed to the red or near the red I'll be able to live with it.
    Thank you guys and have a nice Weekend
  14. swiss612
    swiss612 Karting
    May 10, 2016
    234
    Zurich
    Michel
  15. swiss612
    swiss612 Karting
    May 10, 2016
    234
    Zurich
    Michel
