599GTB Transmission failure | FerrariChat
Discussion in 'Technical Q&A' started by Wieslaw 599, Jul 2, 2019.
  1. Wieslaw 599
    Wieslaw 599 Rookie
    Jan 17, 2019
    21
    Wieslaw Chmielewski
    #1 Wieslaw 599, Jul 2, 2019
    Hello, I have a problem with transmission, after about 20 - 30 km of driving in traffic on display appeared Transmission Failure and very diificult to change gears and after of 2, 3 km car shifted to N and driving over. In service they changed pump and again it happened after a week, today the replaced small part I don't know a name transmitter or something like that and 2 km before home it happened again. It always happens when outside temperature is high about 30 C and when car drove about 25 km. May be some of you had/heard such a case ???? Thanks for help.
  2. George Vosburgh
    George Vosburgh F1 Rookie
    The people who are servicing your car are guessing at the problem. Take it to someone who knows 599s.
  3. Wieslaw 599
    Wieslaw 599 Rookie
    Jan 17, 2019
    21
    Wieslaw Chmielewski
    On Friday I was driving Ferrari around workshop and after 36 km it happened again. I parked the car about 2 km from their workshop, I phoned and mechanic arrived with computer. He said he suspects what's causing trouble. After an hour I could start the engine and I left the car in the Ferrari. Today afternoon should be ready.
  4. MrF355
    MrF355 Formula Junior
    Mar 4, 2008
    495
    Kimi
    You need to have an expert look at your car. If this means paying extra at a dealer it is worth it in the long run. The transmission is quite strong and robust. If your F1 pump went I would suspect it is from lack of use.
