612 adding heated seats | FerrariChat
Discussion in '612/599' started by QtrItalian, Mar 20, 2021.
  1. QtrItalian
    QtrItalian Karting
    Jan 22, 2021
    172
    As I look around for a potential 612 I wanted to ask if anyone has had success in adding heated seats to a car without them. I know finding a desired spec is the best idea. Still I wonder is this plausible with purchasing the OEM parts or via an after-market source? My read of numerous posts here doesn't seem to show convincing evidence it has been done (within reasonable cost) but wanted to check. Thanks!
  2. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,376
    Weston, MA
    Paul
    Just curious, but where are you located, and how many times would you drive a 612 in temperatures around freezing?
  3. ttforcefed
    ttforcefed F1 World Champ
    18,876
    I can only imagine this wld not be worth the headache.
  4. QtrItalian
    QtrItalian Karting
    Jan 22, 2021
    172
    I'm in the SE but may relocate. I find them comfortable in the mornings. I can do without lane change assist, back-up cameras, ventilated seats and keyless entry but might miss these...
  5. brogenville
    brogenville Formula 3
    2,020
    Robin
    I’m not aware of anyone who’s done it, though it had to be possible (whether or not the effort would make it worthwhile is another matter).
    Seat heating is fine by the seat ecu, which is installed in the base of each seat. I would hazard a guess that it’s got the hardware built in to control a heating element , but you’d have to really strip the seat down to get the heating element installed. The switch and element could be had from a Maserati QP of the same era.
    You may also need some coding of the body ecu, with proxy alignment to the instrument cluster, as the display indicates when the heating is active or not.
    I tend to agree with Ricky, that it’s probably not worth the hassle. The other thing is that heated seats in 612’s have a habit of switching on by themselves, making them pretty annoying sometimes.
    Camp Freddie and QtrItalian like this.
  6. ttforcefed
    18,876
    yep that happens in my 612. in my FF its the ventilation setting - finally having it fixed after 10 years
  7. vjd3
    vjd3 F1 Rookie
    2,582
    Massachusetts
    Vic
    I added non-factory heated seats to a 2006 911 awhile back ... it wasn't much to do it, the dealer's leather subcontractor just pulled the bottom covers, installed the heaters under the leather and wired a little toggle switch to turn them on an off. $500 or so. If you don't actually put the toggle into the side of the seat itself, it would be unnoticeable -- provided the leather shop was good at what they are doing. You could run it to the dash, or hide it inside the armrest, or whatever.
    Of course, a 2006 911 isn't a Ferrari ;)
