612 dash nightmare | Page 2 | FerrariChat
612 dash nightmare
Discussion in '612/599' started by m5shiv, Jun 14, 2017.
  1. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    #26 m5shiv, Jun 15, 2017
    Are you seriously referring to W140 model year 1991 cars as apples to apples ? These are not only old but have seen hundreds of thousands of miles of service in all weather conditions as daily drivers compared to late model low mileage pampered garage queens.
    Anyway not sure why I'm wasting my breath. My CL65 is not mbtex btw. And the cars are quite a bit cheaper if we want to keep talking about oranges.
  2. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    I have 11 cars and only the 612 has caused me so much heartbreak from rotten engineering. I plan to keep this car for ever, but that's besides​ the point.
  3. SCEye
    SCEye F1 Rookie
    Aug 28, 2009
    2,950
    Norcal - Peninsula
    Shiv,
    may I ask if you are doing the interior yourself or where you are having it done? I think mine needs similar work pretty soon. I am looking for a good local place.
    Thanks.
  4. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    #29 m5shiv, Jun 15, 2017
    Canepa Design in Scotts Valley. Tell Bruce I sent you, but take him the disassembled parts, not the assembly disassembly task or your wallet will be destroyed. His leather guy is probably the best I've ever seen.
  5. SCEye
    SCEye F1 Rookie
    Aug 28, 2009
    2,950
    Norcal - Peninsula
    thanks for the quick reply.
    there's a meet there in 2 weeks. I may make the drive down.
  6. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Having removed / installed several interiors, as you know, it's a ton of work and requires special skills, tools, patience and knowing not so nice words in multiple languages :D :)
  7. RonH
    RonH Formula 3
    May 29, 2016
    1,061
    Newport Coast, California
    Ron H
    Shiv, I have similar cars to you, a 2005 CL55 and a 2007 612. On the CL55 I agree with you, I have never had leather problems. On the 612 I had the same glue problems as you with the dash by the center vents and on the underside of the dash by the speedo. I also had problems with the headliner where it joins the back window. In all cases the glue comes unstuck. So obviously this is a recurring theme. However, overall it is relatively easy to fix.
    In dealing with both cars (whether mechanical or cosmetic) it is obvious that the Ferrari is hand made while the Mercedes is really a high end, relatively high volume, production car. So totally different animals and the production car will always win out in terms of fewer ongoing problems.
    So I think the leather issues just go with the territory. Just part of owning the car and not really that worrisome. If you didn't have to periodically fix it, what would you do, just drive it? 😀
    Ron
  8. RonH
    RonH Formula 3
    May 29, 2016
    1,061
    Ron H
    Ron
  9. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    Ron, it's not hard, it's just extremely time consuming and as Dave says, requires a lot of care and swearing.
  10. m5shiv
    m5shiv Formula 3
    1,259
    SF Bay Area
    Shiv
    I'm still waiting for Taz to say something. If I recall, he redid his dash too.
  11. SCEye
    SCEye F1 Rookie
    Aug 28, 2009
    2,950
    Norcal - Peninsula
    sorry to be a pest but I am a little confused now. Not sure what you mean. You suggest I disassemble the dash myself then take the parts down? Instead of having his shop doing this. Wallet destroyed? Now I'm a little worried. If you are inclined to share the cost by PM, it'd be appreciated (I completely understand if you don't). Thanks again.
  12. JohnBradleyDaniels
    Oct 16, 2011
    136
    Spartanburg SC
    I've started using a leather cleaner/conditioner (Perrone Aerospace) that I got from a friend that has his jets detailed with. Apparently it helps keep the leather soft and hydrated due to the dry recirculated air. Its suggested by Gulfstream and Lear he was told.
    So far its been good as it doesn't leave any sticky surface or discoloration.
  13. donv
    donv Two Time F1 World Champ
    24,103
    Portland, Oregon
    Don
    I'd be very cautious about that. Also, as you point out, aircraft interiors are subject to dry air-- but they are also replaced more frequently-- probably every 5-10 years at most.
  14. JohnBradleyDaniels
    Oct 16, 2011
    136
    Spartanburg SC
    This is a good point. I may just go back to rosewater and a light soap oil. Natural always comes out on top!
    Thanks for pointing that fact out I overlooked.
    Cheers!
  15. RonH
    RonH Formula 3
    May 29, 2016
    1,061
    Ron H
    You may want to try Leatherique products. Home Page | Leatherique Restoration Products
    I know a number of Ferrari owners use them and I do myself. They provide products to maintain your leather as well as to repair it and color match it. I do my leather maintenance myself and it's very easy.
  16. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,379
    Weston, MA
    Paul
    Based on a recommendation from a top detail specialist, this spring I treated all my leather with CarPro Cquartz Leather Coating. It is supposed to protect against staining, but my primary reason for applying it is it protects against UV rays.
    Right now my dash and rear deck leather is in excellent condition. Hopefully this product keeps it that way.
  17. RonH
    RonH Formula 3
    May 29, 2016
    1,061
    Ron H
    A while back Shiv posted that he had encountered significant cost and trouble repairing his dash and I know that others have had similar experiences. I want to post a success story so others will not necessary be discouraged and can weigh their options.
    Most dash repairs are motivated by shrinkage but that was not my issue. I have always found my interior a little boring (tan with red stitching and piping) and the tan dash also drove me nuts because of the windshield glare. So I decided to change it up.
    I had RMT Motorsports in Yorba Linda replace the tan dash, leather steering wheel cover and floor mats with a black, red and tan leather theme. I have attached before and after pictures and hopefully you agree with me that it was a great job and looks 100% better.
    However, the real point is that the entire package was not that expensive. RMT did all of the removal and installation work (Shiv your pictures and Dave’s comments certainly discouraged me from any thoughts of doing it myself) and RMT subbed out the leather work to a specialist. I think they did a great job and you cannot tell the difference from a factory job. They used "Ferrari leather" imported from Italy (I am told that is a must) and about the most unreasonable part of the job was paying the "Ferrari tax" of $800 to change out the tan plastic air vent in the top of the dash with a new Ferrari OEM black vent.
    So I would tell everyone not to be afraid to try it if you get someone that knows what they are doing.
    Flint Ironstag likes this.
  18. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    We could have refinished that for you ;)
  19. raider1968
    raider1968 F1 Rookie
    Mar 13, 2008
    4,966
    NC Mnts & Asheville
    John E
    I had to do the headliner, dash, sage on the interior roof etc but had it done by Ferrari in Atlanta - not cheap but a great job -
  20. G. Pepper
    G. Pepper Three Time F1 World Champ
    34,044
    Texas/Colorado
    George Pepper
    I figured the OP lived in a low humidity environment, but no. I had no leather problems in five years with my 456M, and it was 16 years old when I sold it. Never treated the leather, and San Antonio is brutal in the summer. My garage is climate controlled, though.
  21. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    Looks good Ron, I like it :) You seem to suggest it was affordable. Though, without a ballpark cost it doesn't really help others in terms of offering an option for redoing the dash... Mind sharing labor cost for R&R'ing the dash? How many hours? Cost for the leather work? Though, I perfectly understand if you prefer to keep to yourself.
  22. RonH
    RonH Formula 3
    May 29, 2016
    1,061
    Ron H
    Thanks Jes.
    I take your point. If I was the Sultan of Brunei then everything is reasonable. :)
    I don’t want to compromise RMT but Randy is a great guy and I am sure he wouldn’t mind me “spilling the beans”. Overall it was $6.5k. But that included the black air vent with a $800 Ferrari tax, redoing all the grill plates on the dash from tan to black, having red stitching on the dash leather (not that noticeable in the picture but it really pops live), redoing the entire steering wheel in the Black and Tan leather with red stitching, 4 new floor mats in black, tan and red leather, fixing the rear of my headliner (which was sagging a little—I had previously fixed it myself but that only lasted for a year) and wonderful California sales tax on everything. So in my world that is pretty reasonable (probably in the Sultan’s too!)
    Obviously a simple same color dash restoration would be significantly less. I can certainly tell you it was great work, looks awesome up close (like it was a factory original job), and the new tan portion of the steering wheel cover is identical in color to my existing tan interior. So I am very happy and no longer blinded by dash glare. :)
    Ron
  23. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    That is very reasonable - AND it looks great. I like the touch of the red center band on the steering wheel. How is your car in terms of stickiness? Don't recall if you already did it...? Otherwise this would have been a great opportunity with it all apart. I pulled my interior apart last spring and had Dave re-do all the soft-coating - only some pieces were sticky, but I didn't feel like doing a piece meal and did a preemptive strike. Not cheap, but looks and feel amazing!
  24. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Thanks, Jes. 612's and 599's are the most expensive to do as they have so many parts.
  25. RonH
    RonH Formula 3
    May 29, 2016
    1,061
    Ron H
    Thanks Jes. The red band was Randy’s idea. So I can’t take credit but it is a nice touch and ties the red in with both the Black and Tan.
    I also totally agree re the sticky. My car was originally a Florida car and had significant sticky but I made the Florida dealer have Dave fix it before I took delivery a few years ago. So it is fine now. So you are right, I would do that too with everything pulled apart.
