612 ownership cost? | FerrariChat
612 ownership cost?
Discussion in '612/599' started by 1ricardo, Feb 2, 2018.
  1. 1ricardo
    1ricardo Karting
    Nov 14, 2012
    69
    Brazil
    Ricardo Baptista
    Dear friends
    I wonder how much is the ownership cost for a 612?
    And also I would like to know what are the common problems with these cars? What to look for when buying a used one, of course...
    Is this a DIY type of car? For instance, can I change the timing belt myself?
    Regards
    Ricardo
  2. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,370
    Weston, MA
    Paul
    I can only speak for my 2008 OTO, but ownership cost is very reasonable. There's just the usual fluid changes, although keep in mind it takes 13 quarts of oil and has 2 filters. I had 2 sets of Pirelli P Zeros which only lasted about 10K miles, but now I have Michelin PS 4S and I think they may last a little longer. Belt changes are only every 5 years and are not engine out so doable yourself if you have the skill.
    Certainly the most common problem is sticky buttons, then retracting leather dash and rear panel, and then cracked fuel pump. Overall it's a pretty reliable car.
  3. RonH
    RonH Formula 3
    May 29, 2016
    1,061
    Newport Coast, California
    Ron H
    Agreed. Same for my 2007.
  4. donv
    donv Two Time F1 World Champ
    24,064
    Portland, Oregon
    Don
    My experience with my 612 OTO (owned since new) is also that it has been quite reliable. It's in getting its second set of belts right at this moment.
    I wouldn't confuse "reliable" with inexpensive, though. As pointed out, basic service costs are considerably higher than on most "normal" cars, and if something does break, parts are pretty expensive. But as far as Italian exotics go, I'd say it's pretty darn reasonable.
  5. raider1968
    raider1968 F1 Rookie
    Mar 13, 2008
    4,966
    NC Mnts & Asheville
    John E
    No problems with my 2008 pre OTO except dash shrinkage
  6. trygve11
    trygve11 Formula Junior
    740
    Kansas City
    Jason Hagen
    Some of what was mentioned already plus some others for sure... Yes, did fuel pumps. Yes, did sticky buttons. Yes timing belt. No, it isn't DIY unless you're ready to go pro!
    Headliner will come down in any warmer climate after 10-12 years. Full interior pull apart to address that.
    Window switches go bad and are extremely expensive, unless you follow my $5 repair sequence noted in my "I just pulled the engine out of my 612 today" thread. Then they last forever and can take "over-extension" and abuse.
    Front and rear (race engineered, non-sealed) tie rods will fail after 25 to 35K. If yours haven't yet, you just haven't had them checked properly.
    Must do the main lower plenum coolant hose every major service. This is under the intake plenum. Approx 3" diameter, 14" hose. It will ruin your week when it goes.
    Water pumps like to go every 20-30K.
    Watch CV axles boots throwing grease on rear axles. Those aren't fun to replace.
    The rest is bullet proof. Well, except the clutch if you don't know how to drive an F1 properly... ;-)
  7. StickBreitling
    StickBreitling Formula Junior
    Oct 12, 2012
    342
    Front ball joints corroded on mine.
    The mirror adjustment knob is a bit fragile.
    Front radiator is exposed to flying gravel which can punch a hole in it, resulting in air conditioning that doesn't cool. Apparently, it's now a rare part to get hold of.
