612 reverse lever fix | Page 2 | FerrariChat
Discussion in '612/599' started by belfry, Jun 3, 2015.
  1. belfry
    belfry Formula Junior
    May 14, 2015
    502
    Robert Batt
    I bought a set of 6 so I'm not sure which one I ended up using.
  2. Makuono
    Makuono Formula 3
    1,009
    Ricardo
    #27 Makuono, Apr 16, 2016
    Finally I managed to repair my 612's broken F1 lever, using Hill Eng part. This part is made of billet Alu, instead of cast (correct me if I'm wrong) original part - see pictures.
    As others said before, it is an easy process:
    1- turn car bat killer switch off
    2- remove 4x bolts holding the module to the console
    3- once module is out, turn it upside down and remove brown plastic cover (caution)
    4- remove 1x center bolt that tights the electronic board and lever mechanism together
    5- remove 1x bolt that holds the broken piece to the lever chrome plastic cover - this is a very small bolt - Torx T6. It was a headache to remove it.
    6- clean all gently
    7- reverse steps and enjoy your "new" F1 module - remember that now you need to pull up and push back if you want to reverse the car! :)
    Ricardo
  3. southnc
    southnc Formula 3
    Dec 25, 2013
    1,765
    Charlotte, NC
    Adam
    Great stuff - glad to actually see the new part works.
    This should save folks plenty of bucks, as my car had the whole assembly replaced - thankfully, before I purchased it - and that cost thousands of dollars.
    Way to go!
  4. Ricambi America
    Sponsor Owner
  5. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,843
    Weston, MA
    Paul
    Nice job Ricardo. Thanks for posting that. I'm sure it will help some people.
  6. montegoblue
    montegoblue Formula Junior
    594
    East TN
    Thank you Ricardo -- this hasn't happened to mine yet but sure it will ...
  7. Larsoni
    Larsoni Rookie
    Feb 12, 2020
    20
    Curtis A. Larson
    In the process of replacing the F1 lever, which has more substantial posts, obviating need for the little brass grommets. One problem: when disassembling the box, the black plastic dooflicky connecting the lever to the receiver fell out. Is it possible to reinsert and reassemble to test?
  8. mtradwan
    mtradwan Rookie
    6
    any one get the plastic bit broken, how would u fix that?
