612 Sessantas and OTOs with HGT1/HGT2 | FerrariChat
Discussion in '612/599' started by tazandjan, Oct 19, 2016.
  1. tazandjan
    38,082
    #1 tazandjan, Oct 19, 2016
    In the past I had postulated that the Sessanta/OTOs with 599 twin disc clutch and gearbox case had quicker shifting like the 599 HGTE when fitted with HGT1 (Sessanta) and HGT2 (OTO). Superfast 1 fitted to those 612s gave 100 ms minimum shift times, the same as the standard 599 shift times. In late 2009, the 599 HGTE came out with 85 ms min shift times. I thought the HGT1/HGT2 packages gave a similar decrease in min shift time. Turns out I was wrong. The HGT1 and HGT2 packages eliminated the quicker shifting TCUs of the HGTS/HGTC packages and eliminated the package specific Shock Absorber ECU, as well.
    Here is the documentation on that change, also explaining that non-OTO/Sessantas fitted with the F133H engine and its required new TCU to match 7.3.2 already improved shift times. Going to Superfast 1 on the OTO/Sessanta further speeded that shift time to 100 ms.
    Summary with Numbers from Ferrari:
    612 standard min shift time: 180 ms
    612 HGTS/HGTC min shift time: ~160 ms (~10% reduction)
    612 7.3.2/F133H min shift time: ~125 ms (~30% reduction)
    612 OTO/Sessanta min shift time: 100 ms (including HGT1/HGT2)
  2. Makuono
    Makuono Formula Junior
    998
    Ricardo
    #2 Makuono, Oct 20, 2016
    Terry,
    Thanks for sharing.
    My 612 (08' non-OTO) has the F133H and the information you posted makes sense. The gearbox is fast (it gets faster when driving faster and using RPM) and I don't find it jerky. Dramatic yes!
    Now...we just need to understand which were the changes the F133H engine brought (if any...) - more power? RPM? Better fuel management (ahaha)? Less emissions (oh oh)? Same performance but different/updated electronic management (motronic 7.3.2)? Ferrari secrets!
    Ricardo
  3. countryman
    countryman Rookie
    Oct 17, 2016
    19
    Miami
    Bill
    Hello,
    that's interesting, but i knew that standard 612 had shift time of 220 ms .... it's correct?
    Best
  4. Alcav5
    Alcav5 F1 Rookie
    3,972
    Scarsdale, NY
    Al
    As a non race car driver , could I really discern a .015 millisec shift difference? Maybe at full throttle?
  5. ttforcefed
    ttforcefed F1 World Champ
    18,876
    how fast does a 430 shift?
  6. southnc
    southnc Formula 3
    Dec 25, 2013
    1,765
    Charlotte, NC
    Adam
    Thanks, Taz.
    Good info.
  7. ghardt
    ghardt Formula 3
    Apr 18, 2004
    1,259
    Texas
    Jerry
    My 2007 612 feels like it's been launched off a pogo stick when shifting at full throttle. It's cool, but I don't see the need to have much faster shifts on a GT car. Do faster shifts wear the clutch parts out quicker?
  8. tazandjan
    38,082
    Bill- The 575M min shift time is 220 ms, the 575M HGTC, Superamerica, and early 612 all had 180 ms min shift times. All well documented.
    360, Challenge Stradale, and F430 are all quoted as 150 ms min shift time by Ferrari.
    Have never seen any explanations on changes for the F133H engine, except for the change to Motronic 7.3.2. Hardly seems enough to warrant a new engine designation, though, and it did not change the engine designation for the 599 when if went to 7.3.2.
    For that matter, I have never seen an explanation of what changes were made to the F133E 575M engine when it became the F133F 612 engine. Have that for the F133G Superamerica engine, which was basically a hot-rodded F133E, but not for the F133F 612 engine, much less the F133H. I know the intake manifold runner sizes were increased for the F133F 612 engine and Motronic injection/ignition curve changes were made, but that is about all I know.
  9. ttforcefed
    18,876
    ok makes sense - my OTO feels quicker than my CS and 430s
  10. southnc
    southnc Formula 3
    Dec 25, 2013
    1,765
    Charlotte, NC
    Adam
    My understanding is the 360 shift times are 180 ms, whilst the 360CS is 150 ms.
  11. tazandjan
    38,082
    Adam- Ferrari claims 150 ms for the 360.
  12. countryman
    countryman Rookie
    Oct 17, 2016
    19
    Miami
    Bill
  13. aintveen
    aintveen Rookie
    Oct 22, 2015
    35
    Duesseldorf/Germany
    Andreas Intveen
    #13 aintveen, Oct 21, 2016
    Thanks for the info Taz!
    My 612 (08 registration - non OTO) has exactly the options the bulletin is referring to: HGT2 + CCMD
    Andreas
  14. MoeD
    MoeD Formula 3
    1,278
    Moe D
    #14 MoeD, Oct 30, 2016
    Perhaps a dumb question, but since OTO cars got Superfast shifting prior to 599, what makes one certain that the improved 85ms Superfast was not then installed on OTO's prior to 599 as well and advised in a later bulletin, if at all? It seems like it would stand to reason.
    I have a late OTO- 2010- and in sport mode the shifting is kick in the back quick.
    I make this point because somewhere online I saw that '09 cars got improved shift times, and I can't be certain if they were referring to the 100ms shift time or an improvement from the 100ms time.
    Is this possible, or it's definitely not the case?
  15. tazandjan
    38,082
    Moe- The 612 OTO did not get Superfast 1 shifting before the 599, which had it from the beginning of production with both Motronic 7.1.1 and Motronic 7.3.2.
    Read the attachment at the top for your other question. No changes were made to shock ECUs or TCUs for HGT2.
    The 2009 reference you saw, which I posted, was comparing shifting to pre-OTO 612s.
    So no, it is not possible OTOs had 85 ms shifting. I was wrong when I said that.
  16. MoeD
    MoeD Formula 3
    1,278
    Moe D
    Ok Thanks for clarification Terry... ;)
  17. 1961GTE
    1961GTE Rookie
    Aug 26, 2012
    49
    Buckinghamshire UK
    Sean
    So Taz - my 2008 Sessanta with the F133H engine has 100ms shift time, correct??
  18. tazandjan
    38,082
    Sean- Affirmative, you have the 599 twin plate dry clutch, 599 gearbox case (with 612 ratios and parts), and Superfast 1 TCU with 100 ms min shift times. CCMs, too. The Sessantas were effectively prototypes for the OTO.
  19. 1961GTE
    1961GTE Rookie
    Aug 26, 2012
    49
    Buckinghamshire UK
    Sean
    Thanks as always Taz
  20. HKS479
    HKS479 Karting
    Sep 23, 2015
    142
    Zurich, Switzerland
    Hi Taz, with respect to your table above, do you know when the F1-S gearbox was introduced? I.e. The cars that have the F1-S button on the gear selector plate. Was this also in line with the new F133H engine type / 7.3.2 ECU or before?
    I think the general consensus is that F1-S was introduced late 2007 but my car was built in Spring 2006 and has the F1-S box. I believe this was the first car to get this option which was a special (612 GP Edition for Switzerland).
    I have not figured out yet which engine type my car has but if I had to guess shift time, based on driving experience of early 612s, pre-OTO and OTOs i would say 125ms feels about right, i.e. Much faster than early car, very slightly slower than OTO.
    Thanks, Jeremy
  21. tazandjan
    38,082
    #21 tazandjan, Dec 15, 2016
    Jeremy- I am not sure exactly when F1-S was introduced, but probably the same time as the HGTS/HGTC packages around late 2005/early 2006. By February 2006, F1-S was featured in all the owners manuals for European and US models.
    If your 612 was built in early 2006, I believe that is before the F133H engine came out in 2007. Shift speed on yours should be 180 ms for a standard 612 and around 160 ms for an HGTS/HGTC. Even 180 ms is pretty quick. The F430 was rated at 150 ms by Ferrari, not much quicker. My 575M at 220 ms will rattle your teeth at 7500 rpm when shifting in Sport.
    The engine Type and number can be read on a stamping on the engine. Kind of hard to see, but here are some 575M photos (same basic engine, F133E vs F133F)) to show you where to look with a flashlight. I believe you will see F133F on the stamping, but let me know if you see something different.
  22. HKS479
    HKS479 Karting
    Sep 23, 2015
    142
    Zurich, Switzerland
    Thanks Taz, the pictures are very useful. Unfortunately I am traveling on holiday for the next few weeks so I will need to wait before I can find out. Its will be interesting to find out shift speed. As mentioned it feels much quicker than the 180ms of the early car. We will see. Basically I like the shifts, they are not as smooth as the OTO but they feel properly mechanical and are fast enough to feel 'right'.
  23. HKS479
    HKS479 Karting
    Sep 23, 2015
    142
    Zurich, Switzerland
    Taz, you were right, F133F engine so that puts the shifts around 160ms. So this is purely down to a different TCU?
    I didn't realise the F1-S was available so early but now that I do I'm seeing F1-S cars delivered from Jan 2006.
    Many thanks, Jeremy
  24. tazandjan
    38,082
    Jeremy- Affirmative, a different TCU with updated algorithms to go with the new Motronic 7.3.2 ECUs that turned the engine into an F133H. The old TCU was not compatible with 7.3.2. When the Sessantas and OTOs introduced the 599 gearbox case and twin disc clutch, the TCU was upgraded to include the 599's Superfast 1 software.
  25. Stevenb
    Stevenb F1 Rookie
    Aug 5, 2012
    2,799
    Los Angeles
    Steven
    Anyone on the look for a low mileage HGT 2? I have one available
