612 Timing belt - While I am in there questions | FerrariChat
Discussion in '612/599' started by TrojanFan, Feb 9, 2018.
  1. TrojanFan
    TrojanFan F1 Rookie
    Nov 17, 2008
    4,897
    So. CA & NV
    Peter
    I'll be changing the timing belts and tensionier bearings in the next few weeks. The car has about 42,000. I have no service records going back so I don't know what has been changed or how long ago. Not looking to throw money away but would like to be smart about it once things once it is opened up.
    As long as I am in there I'm assuming that it makes good sense to replace the Connection Sleeve (the $300 rubber hose #40) as well as the water pump. Anyone come across anything better than the stock Ferrari part for the connection sleeve? Is there a recommendation on a better aftermarket hose (Hill Engineering or anything like that)? Also on the water pump, is the recommendation to replace the entire assembly or just the normal wear parts (#13,18, 19 & 27)? Anyone have any experience with the "Italia Engineering" water pumps from Ricambi? They look to be an upgrade and run about the same as just the normal wear parts.
    Anything else on the "while you are in there" list that I should be looking at? Image Unavailable, Please Login
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    My advice: Fix what's broken - nothing more. Don't go looking for problems. If something looks worn, replace. If not, leave it alone.
  3. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    I think you are wise to replace the under-plenum coolant hose (as you plan) during major - I would, and did.
  4. fatbillybob
    Aug 10, 2002
    26,349
    socal
    What does the guy doing the service say? That answer can give you a clue as to that person's level of service. If the 612 is like previous V-12's there is no definition by Ferrari of "major service."
  5. TrojanFan
    TrojanFan F1 Rookie
    Nov 17, 2008
    4,897
    So. CA & NV
    Peter
    #5 TrojanFan, Feb 10, 2018
    The guy doing the service, at least in part, is the guy asking the question...me.
    I'll know more once I open her up but I'd like to have as many of the parts on hand that I anticipate needing before I start. Had I a complete service history, it would be easier to plan however Ferrari of Fort Lauderdale won't share the service records so I am going into this blind and assuming that a belt service has not been recently done, the pleneum hose has not been replaced and its the original water pump. Also wondering if the tension bearing for the accessory belt (AC) is something that reguarally needs replacing.
  6. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    They are owned by a giant company and yep - they won't provided records - they are very strict about it. But, if you call them and are friendly, they will look up what's been done and verbally tell you.
  7. trygve11
    trygve11 Formula Junior
    740
    Kansas City
    Jason Hagen
    You HAVE to do that hose. It is a must do. Trust me, mine blew at 35K after I DIDN'T do it the month before and it required a lot of wasted labor (on my part as I did all the work). That hose sees a lot of pressure and ultimately will just rip, right in the middle, and dump all coolant. I just went with a new OEM after investigating all other available options.
    As for water pump, just do the bearings and outer seal. It is fully serviceable if you have the right mechanic.
  8. RonH
    RonH Formula 3
    May 29, 2016
    1,061
    Newport Coast, California
    Ron H
    Dave, sorry my experience is like Peter’s. I spent a lot of money with Ferrari of Ft Lauderdale on a PPI and follow up work with the verbal promise they would bend the “rules” and give me the records for my car (they had serviced the car it’s entire life). Forget about it. Not happening.
    Tried a second time when I moved the car to California and they wouldn’t even give it to Ferrari of Newport Beach on a professional courtesy basis.
    Frankly, a bit of bait and switch by Ferrari of Fort Lauderdale when they were pitching doing work on my car. Not saying they are bad folks, just don’t drink any of their Koolaide. Get it in writing and don’t assume they will deliver no matter what they verbally say. As you said, a giant company and they are not realationship based.
    Ron
  9. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Ron - my experience was the same (as I stated). I brokered a deal for my buddy with them and they still would not give me records for my car. But, I can be a huge PITA so I kept pushing and verbally they told me what was done. I think (would need to check) that I eventually got some really limited stuff on email. I need to be sure the last part I'm not confusing with another - will check tomorrow.
    Remember - this all comes down to privacy laws. So, while I don't like it, I get it.
  10. RonH
    RonH Formula 3
    May 29, 2016
    1,061
    Ron H
    Sorry Dave, it has nothing to do with privacy laws. I told them they could redact the name of the prior owner. I just wanted to know what was done by them on the car I owned. Manufacturers like Mercedes provide a national data base on your car repairs and you can get a print out from any dealer. So no privacy issue there.
    Ferrari of Ft Lauderdale is simply a big company that doesn’t care what you or I think. Nothing more complicated than that.
    Ron
    Makuono likes this.
  11. Motob
    Motob Formula 3
    Nov 11, 2003
    2,238
    Frederick, Maryland
    Brian Brown
    The person doing the work on the car should be able to feel the wear on parts (play in waterpump and belt idler bearings), and guide you as to if they should be replaced. The large hose on the thermostat housing was updated by Ferrari to a much better quality silicone hose with more reinforcement after problems with the 456/550. That said, it costs almost nothing in labor to replace it now for piece of mind. The hose that I see more problems with is the small hose that goes from fitting #38 in your diagram to the coolant reservoir. I would recommend inspection/replacement of that hose.
  12. Makuono
    Makuono Formula Junior
    998
    Ricardo
    Good timing for this thread since I'm also planing to do the same to my car very soon.
    What about #18 on this diagram:
    Apparently is might be a potential problem also. It is?
    By memory, I believe that there are some aftermarket solutions for it?
  13. brogenville
    brogenville Formula 3
    2,016
    Robin
    The connection sleeve hose (#40) is under the plenum - I don't see how this is going to be readily accessible to you if you're just doing a belts service? Doing the water pump isn't a bad should though as its a quick wee job when you're in there. You're also bound to get coolant on your belts whilst removing the pump (which everyone says is a no-no, though as it happens my DuPont chemical compatibility guide would say otherwise), so its handy that you're replacing the pump at the same time as the belts. I just replaced my pump for the Ital-Engineering version; I cant really say whether its better than the original, though it does at least have a cast metal impellor rather than the F-spec plastic one. Ricambi said they've sold hundreds of them without any issues, so it cant be a bad thing. The only piece of advice they gave me was to hold onto the old pump just in case complete new pumps become unavailable at some point in the future. The reason being is that the Ital pump cant be rebuilt, at least not with the same parts as the Ferrari pump.
    As for the belt service, just give all the rotating components a good wiggle when you're in there. I picked up a worn aux belt pulley this way, but I failed to check the cam belt drive pulley bearings, which turned out the be the route of all my problems. I wouldn't go changing them out for fun though... the space is very limited and its quite a bit of work to take the cover off the front of the engine.
    As an aside, and I'm sure some people will throw up in disgust at this, but I had pretty good results using an iPhone guitar tuning app to measure the frequency of the timing belt tension. Well, its done a few hundred miles so far without issue. :)
  14. 67bmer
    67bmer Formula 3
    1,193
    MD
    Check the date codes on the belts! That will give you the worst case. You'll know the last service could not have been done before then. Its a bit of a mystery of how much time elapses between the date code and installation. I did not have records for my car (360 Modena, Ferrari of Ft. Lauderdale) but I can tell by the date codes that the belts would have been replaced at a reasonably correct date and mileage using dates on carfax report.
