308/328 GTB/GTS / DINO GT4 PARTS CROSS REF. THREAD | FerrariChat
Discussion in '308/328' started by thecarreaper, Jun 25, 2005.
  1. thecarreaper
    thecarreaper F1 World Champ
    18,076
    Savannah
    2ND TRY. i am tired of searching for part numbers. all the thank you's go to the other folks who have shared this info in other threads. i hope this helps the community as a whole. Michael M.
    RADIATOR EXPANSION TANK CAPS
    STANT 11229, 13PSI, FITS TIGHT
    ALSO STANT 11230
    THERMOSTATS ( NOT CORRECT OEM)
    VW GOLF / RABBIT 1980 REF
    VW PN# 056121113A 180F
    VW PN#05612111371 160F
    RADIATOR COOLING FAN SWITCH 2 POLE
    VW PN# 82395948182 180F
    VW PN# 82395948172 160F
    AUTOZONE SWITCH FOR COOLING FANS
    SORENSEN 40-5012 180F
    HOSES :
    GATES YELLOW STRIPE, REF NAPA
    MAIN COOLING HOSES 1 1/2 ID
    MAIN HEATER 5/8 ID
    BRAKE BOOSTER 1/2 ID COOLANT TANK 3/4 ID
    BREATHER 3/8 ID
    REF GATES HOSES
    PN# 20267 TIGHT BEND
    PN# 21461 RADIATOR HOSE 45 DEGREE BEND, FRONT UPPER HOSE.
    FUEL LINE : 5/16 ID, FUEL GRADE
    IGNITION WIRES:
    BOSCH 7MM WIRES V8 DODGE CHRYSLER PN# 098608
    TAYLOR 8MM WIRES SET 73251
    FUEL INJECTED CARS :
    BOSCH INJECTOR 0 437 502 047 1980 TO 1985
    FUEL FILTER GTS/GTB MONDIAL PUROLATOR F64857
    CARB CARS :)
    FISPA TYPE IS TALL AND SKINNY ( LATE CARB)
    BALDWIN PF834 OR ? LI-1584
    FIAMM STYLE SHORT AND FAT ( EARLY CARB)
    BALDWIN PF866
    PIERCE MANIFOLDS INDIVIDUAL AIR FILTERS
    ( 1 800 874 3728, NO AFFILIATION)
    AIR FILTERS, COMPLETE, NEED 4 :
    PN# 99217.212G
    TOP GASKETS, WEBER DCNF 40:
    PN# 41705.029
    BASE GASKETS, THICK
    PN #99005.125
    BALDWIN FILTERS, REF
    AIR : PA 2094
    OIL : B253
    FUEL ( FIAMM) PF866
    DASH LIGHTS
    SMALL PUSH IN
    SYLVANIA 2723
    LARGE TWIST IN ( DASH)
    SYLVANIA 3893
    COOLING FAN RELAYS
    BOSCH RY-88 A2L ( STANDARD RELAY)
  2. thecarreaper
    18,076
    Savannah
    SPARK PLUGS:
    HOT NGKBP5ES
    WARM NGKBP6ES
    OEM NGKBP7ES
    WHEEL BEARINGS, LARGE (REAR)
    SKF 62208-2RS1, SKF 101221
    WHEEL BEARINGS SMALL (REAR)
    SKF 62207-2RS1 SKF 101220
    FRONT WHEEL BEARINGS : OUTER LM11949 RACE LM11910
    INNER LM67048 RACE LM67010
    PINION TAIL BEARING / SEAL
    28158-28300
    YORK AIR COMPRESSOR (AIR CONDITIONING) : PN# 258108
    BELTS, A/C AND WATER PUMP / ALTERNATOR :
    GATES 7208 / AND GATES 7261 NOT SURE WHICH IS WHICH.
    BRAKE PADS:
    BEST : PORTERFIELD AP04S "R4-S"
    FRONT BRAKES , REF PORCHSE 911S, 1977 FOR PADS AND CALIPERS.
    CHEAP LOCAL PADS : WEAREVER D-45 ( ADVANCE AUTO / AUTOZONE)
    REAR PADS , REF PORSCHE 914. CHEAP LOCAL PADS , RAYBESTOS PGD31BM
    HEADLIGHTS
    SYLVANIA H6024
    LIGHT BULBS
    WAGNER 1156, ALSO 7506BP, AND 500BP. 1156 IS FRONT LIGHTS AND LICENSE PLATE BULBS.
    EXHAUST GASKETS:
    DONUTS : FEL PRO 8194 AND NEA EX-1
    CLUTCH TOOLS
    MGB TOOL, OR "IH10" , 14372 1 1/4 10" SPLINE, REF 1980 INTERNATIONAL SCOUT II .
    FIAT OIL CAP PN# 24350000
    COOLING FAN ( LOCAL FIND)
    HAYDEN # 3653, PEP BOYS.
    WIPERS BLADES AND REFILLS
    BOSCH 18" , REFILLS TRICO 43-180
    Talon38, tazz99 and JuLiTrO like this.
  3. thecarreaper
    18,076
    Savannah
    I HOPE THIS HELPS OTHERS !!! :COOL:
    LLynn and Talon38 like this.
  4. jimangle
    jimangle F1 Rookie
    Nov 5, 2003
    2,506
    Haverford
    James
    Michael,
    Thanks a lot for the part #'s. It's a great help.
    We'reAllF'd and Talon38 like this.
  5. thecarreaper
    18,076
    Savannah
    added :
    ENGINE LID STRUTS PN# RB87905038 ( Pep Boys )
    Talon38 and JuLiTrO like this.
  6. spang308
    spang308 Formula Junior
    Jul 17, 2004
    893
    York, PA
    Just printed this as a reference.
    Thanks for compiling it.
    No neked chicks in this post??? Whats up wit dat?
  7. Dom
    Dom F1 Veteran
    Nov 5, 2002
    8,489
  8. thecarreaper
    18,076
    Savannah
    ok guys, twist my arm...... WARNING : FERRARI CONTENT :cool:
    [nice pics... wrong thread... try the Bikini thread...
    thanks, Brian C. Stradale]
  9. thecarreaper
    18,076
    Savannah
    sorry about the pics.... :) ( they ASKED me though...) :)
    thanks for making this a "sticky". i hope others will add to it for the good of everyone here. Michael
  10. Dr Tommy Cosgrove
    36,449
    Birmingham, AL
    Tommy
    Thank you!
    Now can someone please sticky this?
  11. Dr Tommy Cosgrove
    36,449
    Birmingham, AL
    Tommy
    It's now a sticky thread!!!!!!!!!
    THANK YOU, THANK YOU, THANK YOU!
  12. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    You're welcome ;)
  13. thecarreaper
    18,076
    Savannah
    thank you to ferrari parts exchange, they had the elusive 308gt4 window switch in stock ! :) pn is 30073407 !!!
  14. docweed
    docweed Formula Junior
    Dec 8, 2004
    452
    Morgantown,WV
    Chuck Stewart
    308 K&N air filter E2930, Advance Auto Parts #17400186 $56.48
  15. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    I have recently found out that 328 ABS parts cross reference with Alfa (at about 1/10 the price). When I get the bill, I will post the part numbers.
  16. thecarreaper
    18,076
    Savannah
  17. thecarreaper
    18,076
    Savannah
    308 series fuel filler hose and clamps
    NAPA PN# 1055,
    Marmon Clamps #705-1531
  18. Dr Tommy Cosgrove
    36,449
    Birmingham, AL
    Tommy
  19. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    Replacement for Bosch electric antenna for 308QV:
    Harada MQ-1 looks and works identically... plug and play for only about $10-$15.
  20. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,961
    MD and NE
    Robbie
    K & N air filter for 328/308 Part number #33-2518
    $38.00 free shipping AJ-USA 1-800-877-1911
  21. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    328 and Mondial 3.2 main relay for Jetronic ECU: same as Porsche 928 32v 85-89 OEM part, part number 92861512400 (about $100 less through Porsche suppliers).
    328 and Mondial 3.2 CV boots: same as Porsche 911 (85-89) (about $30 less each through Porsche suppliers).
  22. 285ferrari
    Sponsor
    Sep 11, 2004
    20,961
    MD and NE
    Robbie
    If you are in need of the small plastic push in pieces that you screw into to hold the tag in place. Found them at Pep-Boys.
    License-Tite! is the maker --part number 45962--OEM style #6
  23. branko
    branko F1 Rookie
    Mar 17, 2003
    3,710
    Birmingham, Alabama
    Branko Medenica
    Ferrari no longer makes the AC pressure cut-off switch #100460 for 308's but a clone that works great and screws right in is BMW# 64531370463 and only costs about $30.00.
  24. tomberlin
    tomberlin Formula Junior
    849
    Bethesda
    tom berlin
    Anybody know if the map light in a 78 308 is from another car or where to get one?
    Tom
  25. thecarreaper
    18,076
    Savannah
