67 GTC Front Shocks | FerrariChat
67 GTC Front Shocks
Discussion in 'Vintage (thru 365 GTC4)' started by enio45, Feb 10, 2018.
  1. enio45
    enio45 Formula 3
    1,537
    Gilbert, AZ
    Ed
    I have a customer that dropped off a 330 GTC for a full restoration of the car.
    Upon some inspection we noticed on side of the front shock mount was welded on to in an attempt to repair some damage most likely from not doing the recall . The other side did NOT have the recall plate welded on.
    Taking apart the suspension, it had 2 different shocks on the front.
    What I'm trying to determine is what is the correct part number for the front shock to determine which one
    we have is correct etc.
    I did a search on line and could not find a creditable part number ......
    Appreciate the advise.
  2. enio45
    enio45 Formula 3
    1,537
    Gilbert, AZ
    Ed
    OK that looks pretty definitive to me :)
    Would that number be stamped on the shock as well?
  3. dm_n_stuff
    That one I can't help you with.
    When I helped take my Dino apart, I don't recall if the shocks had a part number on them.
    D
  4. dm_n_stuff
    82N1451 is the Koni part number
  5. enio45
    enio45 Formula 3
    1,537
    Gilbert, AZ
    Ed
    yes, that is what i need.....looks like i have one that number and some other number and different looking shock!
    some kind of a CF on the front shocks !!
    thank u a lot for the help
  6. JayEff
    JayEff Karting
    Aug 8, 2017
    212
    Michigan
    Is it your plan to modify both shock towers to the recalled configuration?
  7. enio45
    enio45 Formula 3
    1,537
    Gilbert, AZ
    Ed
    Yes, i need to repair the damage and create the orig look - then add the recall plate and weld that in.
  8. dm_n_stuff
    There's a rebuilt set, with springs, on ebay right now, search the part #. (No personal involvement, just found them when I googled the part #)
    D
