'69 365 GTC Headlight switch issue | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by VincentLuong24, Mar 24, 2015.
  1. VincentLuong24
    Jun 30, 2014
    16
    Hello fellow members,
    I have a '69 365 GTC with a funky headlight switch issue. When I first acquired the car, I would have to twist the headlight switch and wiggle it up and down slightly to get the headlights to turn on. The high beams nor the running lights never worked. Now the headlights won;t turn on at all. I'm just curious, has anyone out there encountered this issue that has found a simple fix? If not, does anyone know where or who I can get a replacement switch from? Any help or advice will be much appreciated. Thanks in advance and I look forward to hearing from you guy!
  2. afwrench
    afwrench Formula Junior
    Nov 24, 2004
    593
    NY
    Hi Vincent,it could be as simple as some loose wires.Look at the back side of the switch with the battery disconnected. You should not drive the car as it is .A short could occur and fire resulting.Get it fixed right and the enjoy the car. Good luck,Mike
  3. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,041
    Before you disassemble everything, get some electronic contact cleaner and spray it into the hole in the side of the steering column where the switch is located. Do this while working the switch through it's range of movement. Usually the problem is dirt accumulated over the years, and many times the contact cleaner will get the switch working again. Good luck.
  4. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,685
    NJ
    Peter
    I recommend Deoxit Gold spray contact cleaner. It is amazing at fixing bad connections and it also leaves a lubricant on the contacts (this is important to prevent wear on sliding contacts). It isn't that easy to find in general, but Guitar Center usually stocks it: CAIG DeoxIT Gold G5 Spray Contact Conditioner 5 oz. | GuitarCenter. Be sure to get the Deoxit "Gold" and not the "Cleaner" (it's easy to mix them up because the cans look very similar).
  5. Tinbender
    Tinbender Formula Junior
    327
    Raleigh,Lake Lure,NC
    Terry W. Phillips
    I had a very similar problem with a 365GT 2+2 I had. I am not sure if the headlight switch is the same but with that switch there is a set of contacts up in the end of the handle that you twist. The best I remember you pop off the end of the black plastic part that you twist and then you can separate the two halves of the main part and get to the contacts to clean them. Be very careful with the plastic parts. Good luck.
  6. VincentLuong24
    Jun 30, 2014
    16
    Thanks for all of the replies! I'll give cleaning a shot to see if it will work and keep you guys up to date with the situation!
  7. VincentLuong24
    Jun 30, 2014
    16
    The contact cleaner worked flawlessly! Thank you once again to everyone that quickly replied with the useful advice. I greatly appreciate every single response.
  8. VincentLuong24
    Jun 30, 2014
    16
    #8 VincentLuong24, Mar 25, 2015
  9. ersatzS2
    ersatzS2 Formula Junior
    Jan 24, 2009
    862
    Norfolk VA
    Thanks for the pictures that is flat out gorgeous. Maybe my favorite color for a 330/365. It sounds like your problem is solved, but in the interest of adding to the thread for posterity: my light stalk was missing when I got my GTC, probably removed by a repair shop and lost. Classic Coach made a perfect reproduction when they did my engine rebuild, updated with more reliable innards. Apparently this is a high failure component?
  10. Rifledriver
    37,103
    Great looking car. The prettiest roofline ever penned.
    Keep that contact cleaner. Yours was not an unusual problem.
  11. John B
    John B Formula 3
    May 27, 2003
    1,564
    NJ
    Beautiful car!
    Is it Blu Sera?
  12. VincentLuong24
    Jun 30, 2014
    16
    Thanks everyone! Glad you like it.
  13. VincentLuong24
    Jun 30, 2014
    16
    Thanks! It's actually Bleu Scuro.
  14. Peter Lipman
    Peter Lipman Rookie
    Nov 24, 2020
    21
    Peter Lipman
    i am having an issue with headlights on my 365 gt 2+2. they dont work. i am trying to locate the two relays related to the headlights and i cannot find them under the dash on either side. i am using wire colors and number of contacts as a guide with regard to the schematic. i can identify everything i see under there that looks like a relay and i cannot find the headlight relays. Help please.
  15. shoreorthopod
    shoreorthopod Karting
    Oct 14, 2012
    152
    Would reach out to tom yang... he knows these cars inside and out backwards and forwards and fixed my headlight switch issue (albeit different issue than yours).
  16. Peter Lipman
    Peter Lipman Rookie
    Nov 24, 2020
    21
    Peter Lipman
    How do I reach him? Thanks
  17. Peter Lipman
    Peter Lipman Rookie
    Nov 24, 2020
    21
    Peter Lipman
    I found his email address
