72 246 GT - Idle Cam Position & Adjustment...how? | FerrariChat
Discussion in '206/246' started by rspiker, Mar 31, 2025.
  1. rspiker
    rspiker Rookie
    Mar 26, 2016
    13
    Chattanooga, TN
    Ronald J Speicher
    Rough to start and then maintain idle when driving Dino yesterday...checked the service manual and read the indications surrounding the idle cam and adjustment bolt, ie rotation, location, alignment, etc.
    As I was reading the incredible post from DinoLasse from 2012 (wow!) regarding the US/European differences, I noticed the position and relationship between the cam and the idle adjustment arm/bolt. My guess this is at engine cold. The first pic is from DinoLasse's post.
    The second pic is of my Dino with engine cold as well. Mmmm...
    Anyone have information/experience on steps to take to get this in alignment? I do have a service manual, but to say the least, it lacks a bit of detail in their process description that I have not yet developed the skill to 'just know' if it's not specifically spelled out. Hopefully during retirement I can spend some time absorbing more Dino skills...
    Any assistance would be appreciated....Thank you very much.
  2. mar3kl
    mar3kl Formula Junior
    Nov 17, 2011
    470
    Silicon Valley
    Mark
    Welcome to the world of janky early analog emission control systems. I wish I could help but this is the main reason why I bought a euro dino. Years ago I wrestled with British emissions systems of the same era and swore never again. Unless you’re trying for a platinum award I’d just get rid of as much of it as you can and enjoy your retirement driving your car.
  3. DinoLasse
    DinoLasse Formula Junior
    606
    Sweden
    Lars
    Hi, and thanks for the kind words about my thread from 2012(!). Yes, I went all out on that one. Glad somebody noticed.
    Now for the adjustment of the cam. The problem you experienced with starting and maintaining the idle at cold start is probably not caused by the adjustment of the cam. When it is working, it barely makes any difference. Better to check for possible ignition problems or clogged idle jets. Then adjust the idle mixture and set the idle for 900 to 1000 rpm when warm. If everything is normal, the idle when cold will then be quite low, but it should not stall. You should be able to easily keep the engine running with just an occasional blip on the throttle. Once you get the start and idle to be smooth and normal, you can then proceed to set the idle speed cam. Mostly for looks, though.
    The adjustment screw pointing at your cam looks to be set too far away. The way I did the adjustment was to run the engine until warm, and then set the adjustment screw so that it had only a slight clearance to the disc. When the engine is cold, the adjustment screw should then be riding on the disc and forcing the throttle linkage to a higher idle speed. That is in theory. In reality it does not work well at all, but it may help a bit. It is simply a way to raise the idle when cold. It does not affect mixture etc., so it could hardly be the cause of your problems with cold running.
    And yes, the picture of my engine was in cold condition. There should be a slight clearance to the disc, although it is hard to see.
  4. DinoLasse
    606
    Sweden
    Lars
    Correction: The adjustment screw should be in contact with the disc when the engine is cold, as in the picture. Clearance only when engine is warm.
  5. rspiker
    rspiker Rookie
    Mar 26, 2016
    13
    Chattanooga, TN
    Ronald J Speicher
    Thank you, Lars,
    If you would, please post a close up pic of the idle cam and its markings in relation with the adjustment screw, at cold conditions, pls.
    Your pic I grabbed previously doesn’t reflect the markings on top of the cam.
    This pic would give me an idea of the ‘cold condition’ positions.
    Thank you very much!
  6. Steve Magnusson
    26,766
    Yours (with the cam thing completely disabled) is how many of the carbed models wind up being adjusted. In that condition, it's up to the Driver to "squirt" extra fuel and add extra air as necessary using the acc. pedal during cold start up to keep it running. The cam just opens the throttle more when cold (only adds extra air) -- you'd also need to use the choke to add extra fuel -- and that can be a little risky on the cat-equipped carbed cars and risks fouling a plug or two on the non-cat cars as the choke mechanism in DCNF carbs opens well, but sometimes doesn't close so well (even though the Driver returns the choke lever in the cabin to the fully-closed position).
  7. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    The 20 mark on the cam relates to the engine temp at 20 deg C and that should align with the adj screw. If its out of sync.then remove the cam and relocate the bi mettalic strip. If operating correctly, from cold (20C) the throttle linkage is moved by the cam which in turn operates opens up the carb buterfly's & the accelerator pump circuit, no different to you squeezing the gas pedal.
    Not worked on the Dino setup but the idea carried over onto the 308 carb cars, it doesnt work as the 50 + year old bi mettalic strip doesnt have the energy to move the throttle linkage to increase the idle speed.
    As others have said, leave it in a position so it doesnt work and check your idle jets, if its been sitting for a few months then these can clog up. First sign is popping from the exhaust or carb throats when decelerating.
    Tony
  8. DinoLasse
    606
    Sweden
    Lars
    Sorry, but I do not have that US Dino any longer. Have an M-series Euro model now.
    But Tony explained the position of the cam so you can set it to where it looks good.
    And best of luck to you in chasing down the real problem with your cold running condition by checking "the usual suspects."
