'73 246gts insulation material rear bulkhead | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by 246gts, Apr 30, 2005.
  1. 246gts
    246gts Karting
    Jan 10, 2005
    134
    cheshire, uk
    Does anyone have a source for the insulation (foam??) on the bulkhead between the engine compartment and the cabin. Parts book shows a cover on the engine side of this material, part no 0200477, was this fitted to '73 gts models as well?
  2. tbakowsky
    tbakowsky F1 World Champ Consultant Professional Ferrari Technician
    Sep 18, 2002
    19,960
    The Cold North
    Tom
    No longer available..unless sombody has found some some place. I tired to find this stuff for a customer of mine..but no luck.
  3. racerboy9
    racerboy9 F1 Rookie Silver Subscribed
    Nov 3, 2003
    2,650
    Check McMaster-Carr online. They are in Atlanta and have a huge selection of foam sheets of various specfications. I got some for the rear bulkhead and under the belly pan.
  4. dm_n_stuff
    dm_n_stuff Four Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2003
    43,747
    26.806311,-81.755805
    Dave M.
    Get me some thickness specs and I can get it from the same guys we buy 1/4" heat resistant foam in rolls from. Good to 350 degrees or so. Doesn't degrade, I've used it to replace the foam under my headliner, and it worked great.
  5. 246gts
    246gts Karting
    Jan 10, 2005
    134
    cheshire, uk
    Thanks for that Dave
    Problem is I need help in getting a thickness as I dont have anything at all to look at. Also does anyone know if the foam has a "surface" to it as on later 348's etc which was presumably to make it more oil resistant.
    If anyone has an original on a GTS please try to mail a photo. I keep stressing gts as it is different because of the cross bracing.
  6. dinogts
    dinogts Formula 3 Owner Rossa Subscribed
    Feb 15, 2005
    2,466
    Hanging with Thor Thorson
    Just curious -
    If the original was asbestos, will FCA judges deduct points?
    Mark
