74 246 Dino GTS vent window locks | FerrariChat
Discussion in '206/246' started by roccapalumbo, Jul 31, 2004.
  1. roccapalumbo
    roccapalumbo Karting
    Mar 16, 2004
    135
    ohio
    robert
    Recently aquired a 74 dino gts and the metal locks for the side vent windows have come off. What is the best way to reattach these metal locks to the glass windows? Thanks.
  2. dm_n_stuff
    dm_n_stuff Four Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2003
    43,711
    26.806311,-81.755805
    Dave M.
    Glue works, for a little while.
    What I saw on a car in Reading was rather more ingenious.
    The owner had designed a chrome clip that went around the glass itself, and the window lock was then welded to the clip.
    I haven't gotten these made yet, but it's on my list of things to do.
  3. roccapalumbo
    Mar 16, 2004
    135
    ohio
    robert
    Dave, thank you what a great idea. I have a fabricating engineer who lives across the street who I bet can make them. If successful I will have him fab four and I will send you two. Many thanks Dave and have a good weekend.
    Robert
  4. dm_n_stuff
    Dec 10, 2003
    43,711
    Dave M.
    Robert,
    Once again you show why it's great to be here at FChat.
    thanks,
    Dave
  5. roccapalumbo
    Mar 16, 2004
    135
    ohio
    robert
    As do you Dave. Thank you again. Robert
  6. yasmin
    yasmin Formula Junior
    Mar 18, 2004
    939
    Melbourne, Woking. Turin
    Not sure if you are correct here. My 74 246GT has these 'clips'. I think they may have been standard on later models (not fabricated)
  7. tx246
    tx246 F1 Veteran Owner Rossa Subscribed
    Nov 4, 2003
    6,660
    Texas
    Shawn
    i have seen them as well and believe they are aftermarket. to the best of my knowledge, the dinos and daytonas both had the latches glued to the windows with paired "buttons" on the outside to complete the look. they are a pain in the rear. in fact, i know several people who fitted real latches by drilling a hole in the glass. unless a car has already been modified, i would not fit this system. after all, where are you going to leave you car that someone will break into it?
  8. Daryl
    Daryl Formula 3
    Nov 10, 2003
    1,035
    Barrington Hills, IL
    Daryl Adams
    I just glued mine and never really "latch" them. In the few times I've been caught in the rain I've never had any problems with water infiltration.
  9. 365boy
    365boy Formula Junior
    Nov 5, 2003
    357
    Brighton, England
    John Leaman
    On a similar subject, does anyone know where I can lay hands on a Daytona right hand side (orignial style, glued) clip ? Mine recently went missing when it came unstuck for the umpeenth time..
    Cheers, John
  10. eve23
    eve23 Rookie
    Aug 3, 2004
    9
    ny
    ed evangelista
    robert
    if you could make an extra set of the clips for the window locks i would much appreciate.....the glue does not hold mine onto the glass....
    thanks
    eddie
  11. dm_n_stuff
    Dec 10, 2003
    43,711
    Dave M.
    John,
    Are they the same as the dino??
    If so, PM me. I have a spare, let me know,
    Dave
  12. 365boy
    Nov 5, 2003
    357
    Brighton, England
    John Leaman
    Many thanks Dave. You have PM.
  13. docf
    docf Formula 3
    Sep 14, 2008
    1,420
    Florida
    Gary
    100% Correct! All were the same-all were factory glued-we reglued . All fell off again &again. Some post end of production began the drilling and attaching a back piece, but at the time replacement windows were plentiful and not expensive. Never saw until late after production with someone coming up with the backplate idea. My Dino was gone by then.
  14. TheMayor
    TheMayor Ten Time F1 World Champ Rossa Subscribed
    Feb 11, 2008
    106,069
    Vegas baby
    I gave up gluing mine. The glue works for just a little while.
    Its one of those Dino-isms that give the car "character"! :)
  15. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,798
    Southern California
  16. TheMayor
    Feb 11, 2008
    106,069
    Vegas baby
  17. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,798
    Southern California
  18. dm_n_stuff
    Dec 10, 2003
    43,711
    Dave M.
    Yep.
    Gimme a little time, I'll find it.
    D
  19. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,798
    Southern California
    Great
    Great Dave!
  20. dm_n_stuff
    Dec 10, 2003
    43,711
    Dave M.
    Still digging.
    As I reread the original thread, it appears that we had a member here considering fabricating a few sets. Nothing ever came of that.
    Did you peek at the sources list sticky for it?
    D
  21. pshoejberg
    pshoejberg Formula 3 Silver Subscribed
    Dec 22, 2007
    1,818
    Denmark
    Peter H
    I just want to add some technical info regarding the infamous glued vent window locks. I have experienced quite a lot with different types of glue and mounting techniques and my conclusion is that the best (and only?) way to ensure a solid repair is to slightly scratch / grind the area to be glued on the glass and corresponding metal surface (I used a small Dremel grinder with a round sand stone). Hereafter use 2 component slow hardening epoxy glue like Araldit or similar. I made a special mock up to apply a good amount of pressure to the lock against the window while the glued set up. So far, the lock have been steady in place for a year and I use the vent window very frequently.
    Best Peter
  22. msdesignltd
    msdesignltd Two Time F1 World Champ Rossa Subscribed
    Nov 17, 2003
    20,271
    NYC. / E. Hampton
    Michael
  23. dinogts
    dinogts Formula 3 Owner Rossa Subscribed
    Feb 15, 2005
    2,466
    Hanging with Thor Thorson
    You have to be about the only Dino owner that I know of that uses/closes those vent window locks. Every Dino that I have seen where someone closed the locks, the vent window glass delaminated.
  24. pshoejberg
    Dec 22, 2007
    1,818
    Denmark
    Peter H
    You are absolutely right. My right side glass delaminated last year and I went for a glass with a hole for the lock. The original glued left side glass is still holding fine and I use it trouble free on hot days but keeps fingers crossed every time I tension the lock.
    Best Peter
  25. racerboy9
    racerboy9 F1 Rookie Silver Subscribed
    Nov 3, 2003
    2,642
    I don't ever plan to use the vent locks so I think I will use a less reliable glue such as Lexel (clear butyl rubber) or silicon sealant to affix the locks. I want them on the vent windows but don't want to risk chipping the glass. I would rather the glue fail.
