'74 GTS - overheat - water misting situation and repair question | FerrariChat
Discussion in '206/246' started by Neelfryer, Jan 16, 2025.
  1. Neelfryer
    Neelfryer Formula Junior
    Jan 11, 2017
    344
    Beverly Hills
    #1 Neelfryer, Jan 16, 2025
    hello friends
    after moving my car to avoid fires here in so-cal
    I went to retrieve it and driving home I noticed the temp gauge spiking
    I pulled over and mist was spewing up from mid engine
    I figured - a hose is cracked - leaking ?
    so I towed it to a Mechanic
    He called me today to say "small heater hose blew - it will be a couple maybe 3 hours, plus new hose and some coolant"
    I texted back great - do the job
    later in the day
    "sorry for the delayed update, unfortunately before we can go any further you need to come in so we can show you and explain this particular hose - it runs through the center of the car and if it comes apart
    in the center of the car it's changed the difficulty of the job - can you find a few moments to come by tomorrow before we proceed "
    can an informed person comment on this situation
    I may even post the video I took on the roadside of the where the mist was misting from
    BUT
    my ******** meter is going off and I am sensing a shake down for hours of labor to replace a hose
    I just pulled my escalade from the dealer who was trying to charge me 1150 for a 300 dollar repair - they were at least nice about it when I said I'm sending my flatbed guy to pick up my truck - they immediately try to requote me - and I politely said - no worries and we partied friends
    AM I GETTING HOSED ?!
  2. Neelfryer
    Jan 11, 2017
    344
    Beverly Hills
  3. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    That is the area of the 3 hoses "T" ; Thermostated J hose, header tank, and 10m++ of heater hose to front heater box
    3 hours to change the J hose or header hose is probably OK but the front heater box hoses would be much more time.
    1) What series Dino please?
    2) if some hose is rotted here is ALL the hose OK?
    3) The J hose could be blocked from bad Thermostated and more
    4) Do you change your coolant every year or two?
    The Dino cooling has many materials Iron, Almnium, Brass, copper so that the cooling system must be change quite often. Not rip off but one area where maintenance is really needed. Superformance sells the small J hose for $30. Savara Thermostated are very expensive and if water pump too, much more cost.
    My bad guess is I fear you have deferred maintenance and the mechanic wants to show you exactly how bad all is
    Neelfryer likes this.
  4. Sergio Tavares
    Nov 15, 2018
    1,308
    Sergio Tavares
    #4 Sergio Tavares, Jan 17, 2025
    ps - if any work is parts changed please ask for the original SEFLEX hose clamps to return to you as these are quite dear to find
    also, this work would reveal the great viewing of your engine serial, perhaps good to take a photo if cooling hoses removed
    Nobody can make comments on the video, please turn on
  5. Sergio Tavares
    Nov 15, 2018
    1,308
    Sergio Tavares
    Perhaps like the bad puppy the mechanic will scold you about maintenance with your nose at it.
    I would fear ths meeting.
  6. daviekj
    daviekj Formula Junior
    486
    Neelfryer, Looks to me like the steam is coming from below the thermostat rubber hose pair, looks to be from the water pump. Water pump gasket or bearing seal?
    Kevin
    Sergio Tavares likes this.
  7. daviekj
    486
  8. Sergio Tavares
    Nov 15, 2018
    1,308
    Sergio Tavares
    Did the hose fail to cause the OverTemperature
    or did the OverTemperature caused the hose to fail?
    This could be more than one hose
  9. Neelfryer
    Jan 11, 2017
    344
    Beverly Hills
    Sergio - I am the bad owner who did do the coolant flush so this issue is kinda on me
    this is an E series - 74 GTS
    I spoke to a mechanic I trust last night who thinks it's the hose that runs through the rocker panel and that I should have them cut of the bad part and pull the hose forward but reading Sergio's post makes me fear that the hose could be split in a more unfortunate place and that the gas tank may need to come out to replace
    and great advice about keeping the clamps - I am gonna keep the broken hose too - just to see it
    I also got confirmation from the mechanic I know and trust that the guy doing this repair is knowledgeable and good
    so my deferred maintenance is the issue here
    and the car say too much in this last year
    I am going to see him and the car in an hour and will report back
    this is gonna cost me 2k is my guess
    THANKS for the insight SERGIO!
  10. daviekj
    486
    So another candidate then, could be the “T” piece. In the region of your YouTube steam up.
    My original steel T piece was heavily corroded (bottom). On the verge of being a leak. So I made one from stainless (top). I recall the replacement rubber pipes I purchase did not have suitable ID for the original T piece OD, so made the stainless T piece to fit the rubber! Kept the original in case I need an original pattern at a later date.
    Kevin.
  11. Neelfryer
    Jan 11, 2017
    344
    Beverly Hills
    update - I saw the car on a lift and got to take cool undercarriage shots and the car looks very clean and rust free (I know rust lives deep in these cars lol)
    this hose was replaced before because it's not the original hose - which makes some sense as the car is 51 years old? is that math right ?
    and the clamps were not original either - tho they looked Italian - with Italian writing on them
    he is gonna try to pull the hose that runs along - inside the rocker forward and see if it's good and holds water etc
    if that doesn't help - we will move the fuel tank and replace the hose entirely
    I feel good about the guy doing the repair - he has a thick Italian accent - so that's enough, right ? lol
    no, he actually used to work for the mechanic who has serviced and repaired this Dino for me in the past and he said he is excellent
    the shop was very clean and they had a low key vibe and some nice old Ferraris laying around
    so - note to all of us - the coolant flush routine is something to stay on top of
    I stick to my 2k estimate for this repair
  12. Sergio Tavares
    Nov 15, 2018
    1,308
    Sergio Tavares
    Please forgive me but I am not sure what has failed
    but for $2k you can buy every new part for the cooling system needed ... engine hoses, tunnel hoses, heater hoses, breather hose, thermostate, heater valve, seals, water pump new T x 2, clamps coolingant and more
    Your kind video shows this Dino has much original !
    body tab in engine compartment is there - for breather hose is usually brokened, fuel return stay is correct, oeiginal fuel pump..
    Very super nice Dino in Nocciola
  13. Neelfryer
    Jan 11, 2017
    344
    Beverly Hills
    Thanks Sergio
    No offense taken at all
    I keep saying 2k because I have to assume that their hourly has to be 200+ an hour
    I have to think that I am gonna be tagged with 6 hours of labor plus parts - plus tax ....2k?
  14. Neelfryer
    Jan 11, 2017
    344
    Beverly Hills
    yeah the bill was
    $1981.31
    so I knew nothing expect
    I was gonna get hosed for 2k
  15. Sergio Tavares
    Nov 15, 2018
    1,308
    Sergio Tavares
    and the other hoses are good ones?
