747-8: Flight Report | Page 15 | FerrariChat
Discussion in 'Aviation Chat' started by LouB747, Aug 17, 2012.
  1. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Huntington Beach, CA
    Lou Boyer
    #351 LouB747, Aug 4, 2013
    Pressurization. Air comes in through pack inlet doors. NACA scoops with adjustable doors. There's 3 of them. One for each PACK (Pneumatic Air Conditioning Kit). You can see 2 in the picture. The other ones on the right side of the fuselage. Air exits from 3 PACK exit doors. They can be seen in the 2nd picture. They're fully open here on the ground. Not sure how open they are inflight, but assuming they're just cracked.
    All the pressurized air in the airplane must have an exit point. On the 747, they're located out by the tail (last pic). They can be operated by both AC and DC power, in order to be able to open them in an emergency.
  2. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Lou Boyer
    #352 LouB747, Aug 4, 2013
    Navigational Display terrain feature. While I believe the screens a little small for this feature of the -8, it does give a nice display of what's going on around you. Leaving Anchorage for Narita, you can see the planes altitude is approx 8000 ft and climbing. The climb is shown be the white line that projects from the white triangle (airplane). It changes angle based on climb rate. A mileage scale is shown below. Clearance altitude is shown in magenta and by a magenta dashed line (20,000). Terrain is colored based on threat level.
  3. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Lou Boyer
    #353 LouB747, Aug 4, 2013
    Weather. While the -8s radar is completely different, the display is essentially the same. In the following picure we are deviating around weather. We are going left of track in the picture, but will be going back and joining the original track soon. You can't see the weather we passed, but there was a lot of "RED". Anyways, the flight plan course is magenta, with LEPKI being the next waypoint. A clearance to deviate 20 miles left was approved, so a white dashed 20 mile offset was entered. This gives you situational awareness as to how far off track you are. On the -8 (shown here), you also get the miles you're off track shown below the airplane symbol. Here we are 16 miles Left of track. While not necessary, it is nice.....
  4. FERRARI-TECH
    FERRARI-TECH Formula 3
    Nov 9, 2006
    1,677
    Los Angeles
    Ferrari-tech
    That white line looks like a pretty impressive rate of climb, if that's to scale looks more like you are flying an F15 ;)
    Great pic's as always Lou
  5. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Lou Boyer
    #355 LouB747, Aug 4, 2013
    Yeah, it does look almost impossible. But the navigation scale is out to 160 miles, while the vertical scale is 20,000 ft (appox 4 miles). The white line is indeed the projected flight path. But because of the difference between the scales (160 vs 4) the angle gets weird. You can change the range, and as you do, the white lines angle changes.
    Here's a blurry picture. We were doing 3000 fpm.
    I wish we could climb out at that angle!!!
  6. Bob Parks
    Bob Parks F1 Veteran
    Nov 29, 2003
    8,017
    Shoreline,Washington
    Robert Parks
    #356 Bob Parks, Aug 4, 2013
    Thanks for posting this stuff on the 747, Lou. It brings back a lot of things on which I worked. The leading edge slats that change curvature were referred to as Variable Camber Kruger flaps. They are made of fiberglas and route the flow up and over the wing leading edge and intercepts it before it gets to the stagnation point at the lower surface of the wing. More efficient than the flat Kruger flap, they are placed farther out on the wing span and farther aft of the of the flat Krugers that stall before the VCK's, producing a more normal stall. Clever design.
  7. 2000YELLOW360
    2000YELLOW360 F1 World Champ
    Jun 5, 2001
    19,800
    Art
    Isn't there a sped limit under 10 k? Looks like 268 indicated. Am I wrong?
    Art
  8. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Lou Boyer
    Yeah. fAR 91.117 says 250 below 10,000. But if you keep reading, subpart d reads as follows:
    d) If the minimum safe airspeed for any particular operation is greater than the maximum speed prescribed in this section, the aircraft may be operated at that minimum speed.
    For the 747, minimum safe speed is around V2 + 100 kts. It's calculated by the FMS. This takeoff was around 830,000. So minimum safe is 268 here. At max (987,000), minimum safe is around 290.
    If ATC requests 250 and we're heavy, we have to stay at flaps 1 until 10,000. Flaps 1 in the 747 is actually half the leading edge slats, and no flaps.
    According to ICAO rules and rules that govern other countries, you must maintain 250 below 10,000. In this case, you have to request a high speed climb. It's always approved. Usually the controllers give you, "high speed climb approved" on initial contact if you don't request it.
  9. alexm
    alexm F1 Veteran
    Sep 6, 2004
    5,223
    Coast up from Sydney
    Alex
    Thanks for the continued posts & pics.. fascinating and much appreciated to see whatever you can continue to share.
  10. Tcar
    Tcar F1 Rookie
    #360 Tcar, Aug 4, 2013
    If you look at the pic at the top of this link, you can see all of the above:
    The 747:
    Krueger flaps in action (Fiberglass honeycomb).
    All 3 AC PACK intakes (open) and outflows (closed).
    In glorious color.
    https://en.wikipedia.org/wiki/Krueger_flaps
  11. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    #361 Bob Parks, Aug 4, 2013
    Again, thanks for posting these lovely pictures. I had the privilege of working on the ECS system on the 767 and 777. The outflow doors are open in flight but as you mentioned, they are more in-trail than they are on the ground. A huge amount of air flows through that system after being in-taked by the scoops. The air is filtered and refreshed every 30 seconds.The NACA scoops shown, by the way, were not the most efficient on a curved surface like the under wing fairing and they were changed to simple ramps on the 777 and subsequent aircraft. That cabin pressure outflow valve on your airplane is a far cry from those on the 707's when smoking was allowed on the aircraft. The outflow valves on the early airplanes were were gummed-up with a sticky brown goop that trailed aft of the exhaust on the fuselage skin. Coal tar from cigarette smoke. It not only gummed up some of the electronics but discolored the interior decorative panels. No one realizes now how much cleaner the interior environment is since there is a no smoking rule in effect on airliners. I have posted it before but I will mention the episode where a customer ordered a replacement for a damaged interior panel and rejected the replacement because it didn't match those in the airplane. After an extensive investigation it was discovered that the airplane interior had been discolored by cigarette smoke and we could not match the color. Time for a thorough cleaning.
  12. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    #362 Bob Parks, Aug 5, 2013
    One of my diagrams of the flat Kruger flap.
  13. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Lou Boyer
    Here's a video of the outboard sets (curved) being retracted. The airplane does "rumble" a bit as they're being retracted on climb out. At a point, it's like having a straight 2 X 4 out there in the airflow. Obviously a lot bigger.....
    https://www.youtube.com/watch?v=fC_qkaiLLl8
    Kudos to all you engineers!
  14. Bob Parks
    Nov 29, 2003
    8,017
    Robert Parks
    I forgot that those L.E. flaps were driven by an air turbine that makes a helluva racket when they run. A single shaft running from wing tip to wing tip operates them so that there is less chance of having asymmetrical flap extension. I will try to dig up the diagram of the VCK operation.
  15. 2000YELLOW360
    Jun 5, 2001
    19,800
    Art
    thanks, shows me what I didn't know.
    Art
  16. Hawkeye
    Hawkeye F1 Veteran
    8,195
    Lou,
    do they ever deny a request to deviate around weather? How much "RED" can you fly through? I've heard that UPS/FedEX guys fly right through most stuff and was wondering if that's a myth or not?
    Thanks!
    Chad
  17. MarkPDX
    MarkPDX F1 World Champ
    Apr 21, 2003
    15,111
    Gulf Coast
    Not Lou but I have flown a bit..... There is some flexibility in deciding what to fly through and what an experienced cargo hauling crew may choose to fly through is perhaps a bit different from what a passenger aircraft may accept. To say that some will fly through "anything" is just nuts because, if nothing else, somebody will probably ask how all the dents got in the aircraft from the hail.
    I'm not all that familiar with what kind of weather radar commercial aircraft use but the variety of radar can even play a big part of it. I grew up using a high power radar that was actually a bit dangerous if you pointed it at stuff on the ground. It was old technology but a skilled operator could use it to assess the weather and truly determine what should be avoided. The new low power color radar offers is a lot "smarter" in some ways but it still seems to show a lot of red when its really not all that bad just yet. For a period I flew with a mixed squadron and it was interesting to see how there is a tendency to just trust the radar and avoid all red rather than tune and identify what the real weather threats might be. Aircraft with older and more manual radars would fly right through areas with zero difficulty where the guys with newer radars would just blindly trust the box. This can sometimes mean the difference between getting in someplace or diverting to another field. Some of my more vivid memories of flying have been picking a course through thunderstorms in order to make it to a destination.
    Again not Lou.... I have never heard someone denied a request to fly around weather, even if they were just being overly cautious.
  18. donv
    donv Two Time F1 World Champ
    26,143
    Portland, Oregon
    Don
    I'm not Lou either, but yes, occasionally they will deny it. Not common, though. Usually, it involves other traffic, and they will ask you to go the other way instead, or will try to negotiate something which works for everyone.
    I remember years ago hearing it when heading south to Las Vegas-- the airspace there is a corridor between two restricted areas. The guy wanted to deviate, and ATC said they couldn't authorize it because of the restricted area. The airline guy said he was doing it anyway, and ATC told him to "proceed at your own risk." He probably declared an emergency, but I don't remember for sure. He was certainly using his emergency authority.
    ATC does try to be as helpful as they can be, and generally they will be very accommodating.
    As for FedEx and UPS, I wouldn't be surprised if, on average, they were more willing to fly through turbulence and weather than a typical pax carrier. However, it greatly depends on the individual Captain.
    I know I'm more willing to fly through stuff on an empty leg than I am with passengers, and I don't see why the same wouldn't apply here. However, in no case would this have anything to do with safety, just comfort.
  19. jcurry
    24,140
    In the past
    Jim
    [ame=http://www.youtube.com/watch?v=J-qPtWc4heA]Fed-Ex Diversions to Memphis 8/23/03 - YouTube[/ame]
    The classic radar feed video of Memphis during FedEx rush hour. Note they all fly around the red during their approach and fly in circles when the 'red' is over the airport. A couple even divert, likely due to fuel.
  20. Jet-X
    Jet-X F1 Veteran
    Nov 2, 2003
    5,693
    Washington State
    Brian
  21. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Lou Boyer
    They don't deny a deviation request for weather very often. It does happen, but not too much. If you can't go right, you can usually go left. Or vice versa. I try and avoid the RED. Sometimes you arrive at your destination and both your destination and alternate are blanketed with thunderstorms. Sometimes RED is just an area of heavy rain. I'd take a large area of RED over a small compact pockets of RED. Also, tropical thunderstorms typically aren't as severe as frontal thunderstorms. That said, I try and avoid all thunderstorms. I believe somewhere it's written that you should avoid storm cells by 20 miles. In reality, that rarely happens......
  22. FERRARI-TECH
    Nov 9, 2006
    1,677
    Los Angeles
    Ferrari-tech
  23. tritone
    tritone F1 Veteran
    7,204
    On the Rock
    James
  24. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    if memory is close to correct... the 20 mile rule came into play when a plane went down on approach into Atlanta when it got hit by both extreme hail and lightning...
    prior to that the norm for separation was 5 miles... research studies show that lightning can reach out 20 miles or more from the center of activity... one does not need to be under a cloud for lightning to strike... from personal experience I had lightning strike a nearby tree, we were in full sun shine with some cumulous clouds without any hint of rain or any storm activity in the immediate area
    I've taken a few lightning strikes while flying without any immediate damage... only after inspection the aluminum skin was damaged where the lightning hit... the hit area shows erosion or perforation in the aluminum...the eroded area looks rough like sponge...
  25. Gatorrari
    Gatorrari F1 World Champ
    16,470
    Georgia
    Jim Pernikoff
    The Pan Am 707 that crashed in Maryland in 1963 was in a holding pattern outside the thunderstorm that was keeping it from landing in Philadelphia when it was hit by the lightning that led to the aircraft's destruction.
    And the 767 that I was on that (I believe) was struck by lightning was also holding in the clear outside the cloud near Atlanta when it was apparently hit. (I saw a bright flash in the corner of my eye that was very near the wingtip and could actually hear the thunder inside the airplane!)
