77 308-blinker/reverse light prob. revisited.. | FerrariChat
Discussion in 'Technical Q&A' started by greg328, Jan 19, 2005.
  1. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Hi guys/gals,
    OK, this is driving me crazy. As I posted about a month before, my blinkers are "on the blink"! My left blinker also activates the right reverse light, which also blinks in tandem. And vice versa. I was in the rear tail panel over the weekend repairing a broken taillight, and all the wiring seems to check out fine. Does anybody have a clue as to what's going on?
    Could it be a fuse/relay issue?
    I'm embarrassed to use the blinkers in public!!!
    Greg
  2. Rifledriver
    37,288
    First thing to do in that situation is to fix all the grounds to the rear lights.
  3. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
  4. Steve Magnusson
    26,931
    Greg -- Have you made any functional measurements to check Brian's suggestion or just a visual inspection? For example, if you measure the voltage between the ground terminal at the turn signal light socket and a good chassis/engine ground (while the bulb is flashing), it should remain ~0V. If the voltage "jumps up" to something like a few volts or more when the bulb goes "on", then the grounding is actually not so good.
  5. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Thank you Steve. I'll try that.
    So, I'm measuring from ground--to-- ground, correct? 0~v is the desired result, yes? Do you think the problem is a crossed connection? How else would the reverse lights pulse with the blinkers??
    I need to get a voltmeter. This is new ground for me (no pun intended!)
    Greg
  6. Steve Magnusson
    26,931
    Correct -- you've got the right picture (and, as I've said before, the most important tool to DIY on a Ferrari = multimeter ;)).
    This kind of thing isn't a "crossed connection" as much as it's a poor connection somewhere -- like at the crimp between a wire and a terminal or between a terminal and a threaded stud. Might not be your problem, but it's a likely thing to check first and rule in or out -- hence Brian's suggestion.
    Do you have any aftermarket mods that are seriously hacked into the wiring (alarm that flashes the ext. lights, etc.)?
  7. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Steve,
    No aftermarket alarm or unusual mods, as far as I know. I'v owned the car about 2 months, so I'm still learning about it. I did add a modern radio (Alpine) in there--had to have that! As I peer into the fuse blocks, I do see a number a what looks like aftermarket connections, very cleanly done. I think they probably involve the stereo system. (This car has a audio power amp from the previous owner).
    Other than that, this car appears EXTREMELY unmolested. Very clean car. Even looks like the fuse box is brand new, even though it is Ferrari OEM. I've purchased new updated fuse blocks from Birdman, haven't installed them yet.
    The paint looks fairly new, so my suspicion is that the painters screwed things up! Do all the grounds for the rear lights occur near the lamp housings? In other words, will I have to start tracing these looonnnggg wiring harnesses all around the car?
    Thanks so much for your assistance in this matter. I'll run out and get a multimeter tomorrow! Any brand recommendations? Where's a good place to get one of those?
    Greg
  8. BigTex
    79,406
    Houston, Texas
    Bubba
    They do ground thru the harness, the black wire makes up to the base plate on the assembly I'm looking at....blue to the brake lights, red/blk stripe to reverse.
  9. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Where the turnsignal AND the back-up light are flashing at the same time makes me think that there is a reverse polarity problem.
    In other words, both lights are getting voltage through a common ground wire, voltage running backwards so-to-speak. This can be caused by a short in the system supplying power to the chassis, taking the path of least resistance back through the ground.
    If the lights are grounded back through the harness then another possibility could be a short in the turnsignal switch itself.
    It sounds odd but I have seen numerous times.
  10. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    i once had a tr3 that when i stepped on the brakes the brake lites lit and one headlight. never could find out why. in addition to the multi meter you might get this thingie, not sure what it's called, but it put it's own current in the line. good for checking complete circuits. like starting at the taillight and working back to the fuse block.good luck. perserverence furthers. also in the old days we used hand signals for turns. if all else fails.
  11. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Thanks everybody. I'm by no means an electrical guru, so any assistance is greatly appreciated. BigTex, you and I should put our heads together on this one....
    Greg
  12. KurtK328
    KurtK328 Formula Junior
    Mar 6, 2001
    347
    Villeneuve-Loubet, France
    Kurt Kjelgaard
    When you have an insufficient ground in the lighting system, turning on the flashing lights (or the brake lights for that matter), an "articial" ground is created through one of the other bulbs.
    This bulb will then light up as it is now in series with the "original" bulb. Both bulbs will be light up, but weaker.
    You often see this on older italian cars. FIAT from the seventies and teh eighties were especially prone to this.
    Find the grounding points in connection with the rear lights, clean them up and I'm sure your problem is solved.
  13. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Thanks Kurt.. Great advice!!
    Greg
  14. Steve Magnusson
    26,931
    Greg -- Are the reverse lights themselves working OK? -- i.e., when you select reverse (with the key "on"), do the reverse lamps, and only the reverse lamps come "on", or do you get a more "colorful" display?
  15. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Steve, I'll check that out and let you know...
    Greg
  16. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Audi was notorius for this also.
  17. tatcat
    Sep 3, 2001
    11,013
    rick c
    it might fix itself. i haven't had windscreen wipers since, like aug. started the car up today and the wipers came on. why? i dunno.
