77 308-- dropping voltage w/ A/C on..... | FerrariChat
Discussion in 'Technical Q&A' started by greg328, Jul 3, 2005.
  1. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,204
    Austin, TX USA
    Greg
    I'm starting this new thread, because the old one's title was misleading
    ("308 Power Distribution Block..")
    Please use this one now for responses to that thread.......:
    I'm still trying to solve the mystery of why my A/C drops my voltage down to about 10v when turned on, regardless of fan speed. (I installed a VDO voltmeter to monitor voltage-multimeter readings at battery and fuse block match the VDO.)
    It's a recently-installed Sanden rotary, using R12. Blows nice and cold, but taxes my system when on. In fact, at night, using A/C, the "G" light is very faintly lit, glowing a abit more when I tap the brakes or ise the blinkers. With A/C off, my brakes, blinkers work fine, no warning light. Also, my wipers are surprisingly fast. If I turn on the A/C, the wipers slow to a stop!! (My battery is new, alternator rebuilt last month to 75amp)
    Battery cables look great, ground is clean. Everything points to the A/C compressor/clutch as the culprit....
    Any ideas...?
    Greg
  2. ham308
    ham308 Formula Junior
    Nov 3, 2003
    358
    NE Switzerland
    Richard Ham
    The AC clutch should be some sort of electro-magnetic coil, so a coil of wire. It surely shouldn't take more than an amp or so, so if you check the resistance it should be 10-20 ohms. If it reads less it would be shorting out somewhere, might still work, but it would be taking a lot of current and something, somewhere will be getting hot.
    Guess what I mean is, can you measure the resistance of the AC clutch? :)
  3. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,204
    Austin, TX USA
    Greg
    Richard,
    Thanks. I have a multimeter, which will measure resistance.
    Could you assist me on how to measure the A/C clutch's resistance?
    What are my target values, and which values would indicate a problem....
    I appreciate your advice...
    Greg
  4. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Unplug the lead to the clutch. Measure resistance between the clutch side of the connector & ground.
    Will check my a/c clutch tomorrow, but expect it to be higher than 10 Ohms. 10 Ohms would give 1.4A of current at 14 Volts.
    FYI: Amps=Voltage/Ohms
    Your earlier statement:"Brake lights and blinkers also pull the readings down about 1.5 volts" makes me dubious that the problem is in the A/C system. I think it's somewhere between the battery + terminal & the fuse block input connection, and/or between the alternator body & the battery - terminal.
    BTW, The brake lights & blinkers probably add up to 6 to 8 Amps, & flashing lights draw an amazing amount of initial current, easily 10x their steady state current.
    statement current. If we assume they draw 6A, then 1.5V/6A = 0.25 Ohms that we're looking for in the paths I've mentioned.
    BTW, turning on the A/C turns on a lot more than the clutch. It turns on: R.H. Radiator fan, A/C blower, as well as the A/C clutch. Collectively these could easily add up to something like 10 to 12 Amps. So that same 0.25 Ohm would produce 2.5V loss.
    BTW, for future reference, you can ask a moderator to change the title of your thread if you have a reasonable reason.
  5. wolftalk
    wolftalk Formula Junior
    Jan 27, 2004
    367
    san franciso area
    phil
    Measured 2 clutches - 290 ohms and 310 ohms.
    A "special service tool" for removing the clutch from the shaft is a 5/8", 11threads/inch bolt. A couple inches long will do.
    If you have an impact wrench, you can replace the clutch without removing the compressor from the car...at least for a york.
    Dunno if you can spin the sanden compressor around so you can get to the clutch.
  6. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,204
    Austin, TX USA
    Greg
    Thanks everybody. Tomorrow is the day I get back to tackling this problem..
    Verell----Could I pull the fuse to the R.H. fan to eliminate that as possible cause? Not sure if there's a fuse for A/C blower, I'll check...
    I suspect it's NOT the A/C, I suspect my system just doesn't charge well under load..because other accesories also tend to pull down voltage readings--the A/C just pulls more.......
    Greg...
    PS--Verell, thanks for the note about changing titles of threads. I'll do that in the future....
  7. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    RH radiator fan fuse is #17 counting left to right it's 16A, so fan probably draws somewhere between 6A & 10A. (rule-of-thumb: Usually the load will be 1/2 to 2/3 the fuse rating).
    There's only 1 A/C fuse, #5, also 16A. Expect that it protects the A/C relay, clutch, & blower, possibly only the clutch & blower.
    re: charging problem
    That hasn't been established, but the answers to these would help:
    What is battery voltage w/ A/C on & engine at ~1000 - 1200 rpm? as compared to idle where you said it 'lugs down the engine w/ A/C on.?'
    Also, what is engine idling rpm w/ A/C on?
    ~2V drop between battery & fuse panel with A/C on is too high. Should be down about 0.5V, maybe 1V max. This is a wiring/connector problem, not a charging problem.
  8. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,204
    Austin, TX USA
    Greg
    OK, I'd lke to share what I believe to be key information regarding my 308's low voltage situation:
    Took her out for a 4th of July spin tonight, and watched the dash-mounted VDO voltmeter closely. I left the A/C off...
    I found that unless I revved the car at a stop the voltage would drop to around 10v. During driving it stays around 12-13v. When I come to a stop the voltage drops down, due to low engine/alt revs.
    When tapping the brakes or using blinkers, a VERY faint glow was evident in the "G" light--voltage readings were low-ish because I was stopped.
    So, it looks like my system is simply not charging properly unless I'm spinning the engine higher than idle. Running the A/C certainly results in lower voltage readings, but I believe it's through no fault of its own. It just presents a larger draw on the system; any draw while idling will cause lower volt readings.
    Is this normal? Do any of you 308/328 guys experience dropping voltage readings while idling? Or should it always be a healthy 13.5-14 volts regardless?
    Tomorrow I'm bringing the car back to the place that rebuilt my alternator--see what they say...
    Greg
  9. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Again, what was your engine rpm when making those meas'ts at idle?
    It may well be that your idle speed is set too low. If it's under 700 rpm, adjust it up to 850-900 rpm & see if that doesn't help quite a bit.
    The 3x8 alternator is under driven by design at idle so that it isn't badly over-rev'd at redline. As a result the alternator voltage at idle can be expected to drop some, but 10V is excessive.
    I'll try to get some meas'ts on my QV as I didn't record them last time I checked.
  10. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,204
    Austin, TX USA
    Greg
    Verell,
    My idle is over 700rpm at idle. Seems to settle in around 800rpm most if the time. It will lug down, but only if I have the A/C on......
    So, I think idle is set rather correct.
    Is it normal to get different readings on the voltmeter as revs change?
    My Nissan 350Z reads a steady 14.1v at all times the engine is running....
    (Not near as fun to drive, though!!)
    Greg
  11. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    In the summer I set my idle up to ~900rpm. With the A/C on it drops down to ~850rpm. I'm pretty sure I've measured my alternator voltage dropping about 0.5 V if I lower the idle rpm to 800. As I mentioned earlier, the 3x8 alternators are under-driven (pulley ratios turn them a bit too slow at idle) so that they won't be too badly over-revved at red-line. So, yes, it's normall for a small drop in voltage at idle, especially while actively charging the battery after starting, or driving a heavy load like headlights or A/C.
    Just measured my voltage between top of fuse#1 & harness ground braid to hex bolt at upper left of fuse panel:
    Just after starting:
    12.9V @ 900rpm idle
    13.2V @1500rpm
    After running about 5 minuites to let battery recharge:
    13.1V @900rpm idle
    13.2V @1500rpm
    12.8V @900rpm w/A/C on (blower & fan on, but not clutch as I'm low on R134a due to a leaking schrader valve.)
    12.5V @900rpm idle w/park lights on
    Turning on flashers caused voltage to vary between 12.25V & 12.5V, depending on whether the meter read the voltage while the lights were flashed on or not.
    Measured at tops of a couple of other fuses, some with higher current loads,like the fuel pump, or fuses sharing input connections with higher current loads were 0.2V to 0.5V lower.
    Didn't measure the battery voltage, but I'd expect it to be about 0.5V to 0.6V higher than the fuse #1 reading after the starting charge is replaced.
  12. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,204
    Austin, TX USA
    Greg
    OK, I took the car over to the alternator shop today to take some measurements.
    What they found was, the fans alone are drawing ~30 amps, add the lights (and I have them on a bypass harness Hella H4s) and the total is 50 amps, even with the car off. My rebuilt alternator was improved to about 75 amps.
    The fans on the car are German-built, non-stock, put there by the previous owner. They are larger, and cool much better than the stock fans the car came with.
    So, it looks as though we've found the culprit. The fans are drawing more than usual amps. What are my alternatives? I don't want to toss the fans; they're supposedly better than original. The shop suggested I go with an AC Delco, if a fit can be found. They put out around 115 amps or so. I just spent $150 on the rebuilt alternator, hate to lose that.
    Would an overly-large amp draw cause the volts to drop, like indicated?
    Any ideas, anybody....?
    Greg
  13. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    25 amps a piece from the headlights? What wattage H4 bulbs are you running?
  14. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    He said that fans (30A) + headlights combined to 50A.
    .: 10A/headlight. That's still 120W/bulb!!! Umm, or is that the draw when headlights are switched on, thus includes tail lights, etc?
    Did they measure the current draw with just the car running?
    Estimate another 31-35A. ie:8-10A for fuel pump, another 8-10A for the ECUs & ignition, 15A for misc. stuff.
    And you're way beyond the alternator's capacity.
    You're going to have to put it on an Amps diet fer sure.
    Umm, greg, 328s come with either an 80A or 85A alternator, how come only 75A?
  15. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,204
    Austin, TX USA
    Greg
    Verell,
    my username is misleading--remember, I drive a 1977 308 GTB! I created my username years ago, when I was dreaming of a 328.....
    The alternator on my car was 65a originally. I had it rebuilt to 75a.
    The fans' amp draw was measured w/ key in 1st position, engine off, A/C on.
    I had just driven the car so it was warm, and the other fan was kicked on, so both front fans were on. They pulled ~30a combined. I then popped up my lights, which added another ~20amp draw (total of 50a).
    My H4 lamps are only 70 watts or so, a small bump up from stock, and I've installed a bypass harness, bypassing the stock wiring/fuse block. So, they probably drew a high amount because they were running off pure battery at that moment, w/ no alternator charge....
    Is there a way to upgrade the fan relays to a higher amp rating? Would that alleviate any draw? What if I installed another relay in series off of the stock relays? Somebody mentioned that might help....
    I'm hoping to retain the fans and my rebuilt alternator. Am I dreaming?
    Furthermore, am I really doing any harm if the fully loaded voltage reading is still higher than the cold battery reading (engine off)? If the fully-loaded reading is still higher, then at least I'm not draining the battery, right?
    Greg
  16. f355spider
    f355spider F1 World Champ
    18,029
    Relays will not compensate for the fact that your electrical draw is greater than your alternator can produce. You need to either reduce the draw, get a higher output alternator, or (better) both.
    Best to look into whether it is possible to further increase the output of your existing alternator. Seems others have been able to have this done.
  17. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,204
    Austin, TX USA
    Greg
    Dave,
    I figured as much. I guess there's no way to power the fans not using the alternator. There's only so much amperage available in the system, period, correct?
    Greg
  18. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    Right. When the car is running, the idea is that the alternator powers everything, with some leftover energy output to charge the battery, which gets depleted a little bit when you start the car. If you consume more energy than the alternator puts out, such as is the case when you start your car (before the alternator is spinning and producing power output!), then you'll have an energy "deficit" which the battery will fill... for a while until it gets depleted, i.e., when the voltage drops below a certain amount (around 11V/12V, say).
    I suppose you could add an extra battery somewhere just for the fans, and trickle charge this at night! At 30 amps the fans would run it down pretty quickly though...
    This power deficit that you have is not usually a problem on these cars--even the stock 55A alternator is supposed to handle everything. Upgraded to 75A, this should make up for any extra current drawn by the new fans. Doesn't really make sense.
    Verell: does the Facet/Corona fuel pump in carb 308s REALLY draw 8-10A? That seems like an awful lot of current for that component.
    --Mike
  19. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,204
    Austin, TX USA
    Greg
    Mike,
    Remember, these fans are upgraded mid-'80s vintage Mercedes fans (just found out the make today by calling the previous owner). They are larger, cool better, but draw more amps. That's the cause of my problem!
    Million-Dollar Question:
    If the voltage measurement at battery with ALL accessories ON (A/C, blinkers, radio, blinkers, etc...) is HIGHER than my battery voltage COLD, with key out, (~12.5 volts), is there truly any cause for concern? At least the battery is being charged, not depleted, right? In spite of the inordinate voltage/amp draw?
    This is the key question, the answer to which will dictate how I will proceed (i.e.: do nothing, or do something!)
    Greg
  20. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    OOPS! My mistake, didn't ck your profile & assumed you had a 328 from your username.
    Hmm, that changes the picture a lot: No ECUs or electronic ignition, No BOSCH CIS fuel pump!
    That's another different picture, I thought the 30A was just for the 2 radiator fans. 30A for both radiator fans AND the A/C blower ISN'T WAY ABOVE STOCK. Each radiator fan has it's own 16A fuse, so stock fan must draw 6A-10A, & A/C blower is probably 6A-8A. So stock equivalent is something like 18A to 28A. Your heavy duty fans are adding at most 12A, probably only 6A-8A. Not a severe add'l burden given your 10A alternator upgrade.
    Lets' redo my SWAGs:
    50A for A/C blower, radiator fans, & ALL lights.
    Estimates for rest of car:
    4-6 A for fuel pump (this is really a guess, however, a carb'd pump has to pump the same amount of gas, but at only about 10% of the pressure of a CIS pump, so definitely less power req'd.)
    2-3 A for points ignition.
    10-15A for misc. stuff (heater fans, radio, not much else) unless you've got a high wattage audio setup. This could be high.
    68A-74A Estimated. S/B within your alternator's capability!
    Maybe crowding it a bit, but usually the left radiator fan isn't on except on very hot days, stopngo traffic, or when idling w/no ram air coming thru radiator.
    Certainly s/b well within the alternator's capacity with the headlights off.
    So why aren't you seeing more voltage at the battery & why such a drop between the battery & fuse panel. (Did you ever measure the alternator's output voltage at either the alt, or starter?)
    Yes, if the battery voltage with the engine running is greater than the battery's no-load voltage, you're at least not draining the battery while running. However, you may not be chargeing it enough to replenish the current you drained while starting the engine, thus may slowly loose ground, eventually discharging the battery over several days/weeks. Hard to tell w/o driving it.
    IMHO, either your alternator output is low to begin with or you're loosing too much between alternator & battery.
    Would bug me until I understood what was going on, but then I'm an anal electrical engineer. It's your call whether you try living with it or not.
  21. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,204
    Austin, TX USA
    Greg
    Thanks Verell for the great response , as usual. I'm going to pull the fan fuses tomorrow and watch my voltmeter as I turn on the A/C. Just want to confirm that indeed these Mercedes fans are the culprit.....
    I'll let you know....
    Greg
  22. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Measure both the battery & top of #1 fuse to ground. S/B less thatn 0.5 V difference.
    I know it's a PITA, but getting an alternator output reading (Alt. case to output terminal) would complete the picture
  23. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,204
    Austin, TX USA
    Greg
    Verell,
    Should I measure these w/ full load--all acc. on? Or does it matter--we're just trying to find the DIFFERENCE in readings, to find unwanted resistance?
    Also, what exactly do you mean by-"alternator case to output terminal"? That's not the same as "output wire voltage", right...
    Greg
  24. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,204
    Austin, TX USA
    Greg
    OK, for sure I've isolated the problem: it's the R.H. radiator fan ( and L.H. also, I would imagine; they're identical).
    I simply pulled the #17 fuse and monitored my voltmeter as I turned on the A/C. With fuse pulled, there is only a nominal voltage hit when I turn on A/C. Putting fuse back in, running A/C, the voltage drops way down, about 2.5 volts or so. That's just with the R.H. fan. I'm sure when the other one kicks in at high water temp the amp pull is doubled!
    These are Bosch fans, with "A B C D E F G H I J K" around the perimeter in a circle. There is no model number, but the PO says they are mid '80's vintage Mercedes.
    So, again, what are my options? Is there any other way to power these fans?
    I can't imagine any practical way, other than a second battery, which seems a little extreme.
    My alt was rebuilt to 75 amps, and I'm running my lights off a bypass harness....
    Solutions anybody? I don't want to go back to the crappy original fans. It's too hot here in Houston!
    Greg
  25. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    Greg, replace the fans, they're crap. Maybe you like them but they are no good. Modern fans push twice the air at a fraction of the power needs of even mid 80's fans. We Lotus guys have a 35 amp alternator and that Lucas fan is often replaced with a modern one. With it, we can upgrade our stereos to the point we can actually hear sounds from the speakers when we're at redline.
    Ken
