News
77 308 -- my bonnet pull cable broke!
Discussion in 'Technical Q&A' started by greg328, Apr 2, 2005.
  1. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,120
    Austin, TX USA
    Greg
    Anybody have any experience replacing the pull cables to the front bonnet on a 308? Mine broke off at the chrome lever today, and I'm wondering what to do to fix it...
    My guess is to remove left front wheel, accessory cover, and have a look.
    Beyond that, no idea....
    If I were to replace the cable, can I go aftermarket? The current one seems to be sheathed in black plastic. How do you measure for perfect length/tension.....? The cable attachment at the chrome lever (inside cabin, on wheel well) looks like it was welded onto the bolt...
    Inquiring minds want to know!!
    TIA,
    Greg
  2. f355spider
    f355spider F1 World Champ
    Rossa Subscribed Owner
    May 29, 2001
    17,030
    Hugh G. Rection
  3. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,120
    Austin, TX USA
    Greg
    Very kind of you..
    I did a search, and only found one slightly-related thread.....
    Thanks again,
    Greg
  4. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Greg, you've looked for the secondary pull cable (under dash near door), right?
    Philip
  5. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,120
    Austin, TX USA
    Greg
    yep, I already knew about it, and used it. I need to replace the broken main cable now, that's my challenge of the moment.
    This car seems to present a new challenge every so often. I also pulled my non-functional Veglia clock out to try and repair......
    Greg
  6. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Can you access latches to undo bonnet by using a small screw driver front leading edge of windscreen?
  7. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,120
    Austin, TX USA
    Greg
    Yes,
    but I think to pull the cable and replace, you need full access from the side/bottom.....
    Greg
  8. Verell
    Verell F1 Veteran
    Owner Consultant
    May 5, 2001
    6,986
    Groton, MA
    Verell Boaen
    You should be able to pull the old cable out of the jacket.
    Once you have it out, measure it's length, & diameter. Then buy a similar bicycle/motorcycle control cable, or stainless steel aircraft cable from www.mcmaster.com.
    The ring connector that mounts to the lever is crimped onto the cable. Should be able to get similar crimp-on rings from an aircraft or sailing supply. They may even have the cable & crimp the ring on for you.
    Then push the new cable thru the existing jacket. Probably will have to solder the strands on the end you're pushing thru together so whey won't snag inside the jacket.
    Alternatively, purchase a new cable from ferrari.uk.
  9. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,120
    Austin, TX USA
    Greg
    Verell,
    When you say "pull the old cable out of it's jacket", you don't mean the black plastic sheath that the cable is encased in, do you?
    Any tips on how to remove the latch-side end, under the bonnet, without altering the length?
    TIA,
    Greg
  10. Verell
    Verell F1 Veteran
    Owner Consultant
    May 5, 2001
    6,986
    Groton, MA
    Verell Boaen
  11. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,120
    Austin, TX USA
    Greg
    Thank you again, Verell, for the info. I'm sure I'll get with you again as I begin to tackle this problem....
    Much appreciated..
    Greg
