'77 308 Rear Caliper removal | FerrariChat
Discussion in '308/328' started by Tortellini, Jul 23, 2022.
  1. Tortellini
    Tortellini Rookie
    Sep 27, 2014
    47
    S.E. Michigan
    I need to rebuild the left rear caliper due to leaking. After searching, I still don't know how to detach the hand brake cable as a first step. I think Birdman's procedure is for a '78, seems different to mine anyway.
    Any suggestions please?
  2. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    628
    Massachusetts
    Joe
    You should be able to move the lever away from the caliper. This should move the piston inward. The cable with the slot on the end should now have some slack, which should allow you to remove it from the hook on the end of the lever
    If that doesn’t work the flat assembly that holds the pulleys can be removed from the frame (two bolts). The pulleys will remain with the flat assembly. That will give you plenty of room.
  3. Tortellini
    Tortellini Rookie
    Sep 27, 2014
    47
    S.E. Michigan
    Thanks... I'll try moving the lever again, hadn't thought about the assembly.
  4. absostone
    absostone F1 World Champ
    10,029
    Remove the two bolts and brake line. raise caliper twist to unclip cable. or juust undo cable at union.
    Plutonium likes this.
  5. absostone
    10,029
    #5 absostone, Jul 23, 2022
    Ive done at least four rears real easy and fun. But i dont remember if the rears have shims for the mounting bolts. I dont think they do. IDk
  6. Alex308qv
    Alex308qv Formula Junior
    Jul 1, 2016
    405
    PA
    Alex
    +1
    A prybar against the inside of the wheel easily moves the lever arm enough for the cable stirrup to come right off.
  7. JTT
    JTT Karting
    Jun 16, 2020
    182
    Ontario
    J Taylor
    Both sides of my tears have shims. One each on the left side and two on the right side.
  8. absostone
    10,029
    Not all are the same them. You need to mic the spacing. Do not follow what someone else did
  9. Tortellini
    Tortellini Rookie
    Sep 27, 2014
    47
    S.E. Michigan
    Some great info for me to work through here ...really appreciate!!
    I'm going at a snail's pace so this will take me a while, I'll certainly look out for any shims as well...
  10. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I used a big screwdriver to push the lever forward and popped the cable loop off the end. I suppose if it was still to tight and I had a second set of hands I might have some one do the same on the other side at the same time. Then I'd go after unbolting the pulley mechanism.
    Sergio Tavares likes this.
  11. Tortellini
    Tortellini Rookie
    Sep 27, 2014
    47
    S.E. Michigan
    That nearly worked (just needed a longer screwdriver) ...ended up just removing the caliper which then allowed me to remove the cable.
    absostone likes this.
  12. absostone
    10,029
    What I said my man. :)
  13. Dockboy
    Dockboy Formula Junior
    602
    Maryland
    Put an 11mm socket on the caliper half bolt to use as a fulcrum for a pry bar or long screwdriver. You will need to do that when you get the caliper back on because I can't imagine trying to install the caliper with the cable attached!
  14. absostone
    10,029
    If it came off that way it goes on that way
  15. Dockboy
    602
    Maryland
    Sure, but why fight it?
    You should do the initial piston extender adjustment with the cable off anyway.
  16. absostone
    10,029
    ive done three cars no problems. also pads need to be set with a feeler gauge on rears. if its to tight loosen the turnbuckle .
