77 308 Stripped Petcock Valve | FerrariChat
Discussion in '308/328' started by timr, Oct 1, 2022.
  1. timr
    timr Formula Junior
    Sep 24, 2006
    274
    Seattle Washington
    Tim
    In process of replacing a water pump. In that process I decided I would trade out my old engine block petcock with a new one that had a spout to connect a drain tube. Thank you @obertRo for the kit. However, it seems my old petcock brass bolt is a little soft on the edges making it difficult to remove. A couple of questions: 1. Do the valve twist wings come off? If so I could probably get a box head wrench around it. 2. Does anyone have a suggestions on getting it out with a specific tool or scenario? I don't want to damage it with brute force but it's a gonner so I am open to suggestions. Thank you all.
    obertRo likes this.
  2. Steve Magnusson
    26,794
    You could try a flare nut wrench which is sort of half-way for grip between an open end wrench and a box wrench, but cutting/ripping off the wings (or cutting thru the wing threads) and using a 6-point socket would be better. I believe the wings are mechanically swagged onto the threaded portion so can only be removed by some sort of destruction.
  3. timr
    timr Formula Junior
    Sep 24, 2006
    274
    Seattle Washington
    Tim
  4. timr
    timr Formula Junior
    Sep 24, 2006
    274
    Seattle Washington
    Tim
    Thanks Steve, that was one of the tools I tried (and cussed profusely). The challenge is the open part of the flare nut wrench area isn't large enough to get around the threaded portion. I know weird huh? Oh I hate the destruction method... any thoughts on a destruction tool small enough to get in that area?
  5. Steve Magnusson
    26,794
    Hack saw/Sawsall blade (to cut the threaded part), or maybe you can just physically "rip" the wings off the threaded piece if the swagged feature isn't too strong. I think Rainman Ray would be tempted to just grab the nut part with his special "angry pliers" and twist ;), but, if that fails, then you can't go back to the 6-point socket. My order of desperation would be:
    1. Just try ripping/bending the wings off,
    2. If not successful, break out the saw.
  6. timr
    timr Formula Junior
    Sep 24, 2006
    274
    Seattle Washington
    Tim
    Sigh… thanks for the thoughts! Angry pliers it is… I’ll keep you posted on the difficulty of removing the wings. Thank you.
  7. Rifledriver
    37,098
    I have gotten them off by hooking a box end wrench over one of the ends and prying it off. There is not a lot holding them on, thats one of the problems.
  8. timr
    timr Formula Junior
    Sep 24, 2006
    274
    Seattle Washington
    Tim
    Thanks Rifledriver, I think that is my first effort. Once I’m in, I’m committed…
  9. timr
    timr Formula Junior
    Sep 24, 2006
    274
    Seattle Washington
    Tim
    @Rifledriver & @Steve Magnusson
    Thanks for the input. Success…
    JuLiTrO likes this.
