News
'77 Headlight Fun
Discussion in '308/328' started by gte619n, Jun 29, 2015.
  1. gte619n
    gte619n Karting
    Oct 9, 2006
    108
    Atlanta, GA
    Evan Ruff
    Hey guys,
    I was hoping someone could help me out with adjusting my headlight... singular...
    Turning on the headlights work great. When I turn them off, they immediately go down as expected. The driver's side headlight works as expected. The passenger headlight keeps going up and down until I apply a tiny amount of downward pressure, then it closes perfectly.
    I know there are adjusters under the louvers, but I'm not sure exactly how I adjust the closing portion only. Any tips?
    Thanks,
    E
  3. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,335
    Exchange right & left headlight motor relays as a test for the relay contacts being good (or simply replace both relays). Another motor relay powering both pod motors can be temporarily exchanged with the headlight relay. See owner's manual for locations on relay panel.
    Check the tightness of the lever arm which couples motor with pod. There are diodes which go bad in that same circuit but I don't remember the symptoms besides total non-function. A last resort are contacts within the pod which determine open/closed position. I've tried to list these in order of difficulty to work on and order of items known to fail. So start with good relays.
    Paul
    __________________________
    Wiring Diagrams 308 365 400i 512
  4. gte619n
    gte619n Karting
    Oct 9, 2006
    108
    Atlanta, GA
    Evan Ruff
    Thanks Paul, I will check it out and see if anything fixes the issue.
