77 Water Pump Rebuild Resource Request | FerrariChat
Discussion in '308/328' started by timr, Oct 12, 2022.
  1. timr
    timr Formula Junior
    Sep 24, 2006
    274
    Seattle Washington
    Tim
    Looking for qualified resources who can rebuild my water pump. Thank you.
    JuLiTrO likes this.
  2. lm2504me
    lm2504me Formula 3
    1,121
    Nipomo, CA
    Richard
  3. Rifledriver
    36,868
    If it is the original pump I would not rebuild it. The V8 went through many design changes to the water pumps and I'd never consider rebuilding one from a 77. You want one from a late 308 QV to a replacement pump made up until 95 or so.
  4. Steve Magnusson
    26,626
    +1 -- Measure the OD of the bearing outer race. If it is 35mm, it would be better to get the later 308QV water pump 121255 with 42mm OD bearings as Brian suggested.
    timr, NoGoSlow and absostone like this.
  5. Vonbarron
    Vonbarron Formula 3
    2,244
    Westside Mofo
    S B
    Your in Washington so contact SeattleM5 on this board
    timr likes this.
  6. SeattleM5
    SeattleM5 Formula 3
    1,259
    Kirkland, Washington
    Ettore Palazzo
    Thanks for the shout out Vonbarron.
    In full transparency, rebuilding waterpumps and the other fun stuff that I tinker with on these cars (Bosch CIS stuff mainly) is not my regular job. I have had the great fortune of learning how to do this work from some amazing individuals including Martin308GTB from this Board as well as one of my true hero's, Dave Helms. Anyway, my work on waterpumps started after a disappointing experience with multiple failed water pump rebuilds for my 328 by a well known rebuilder (If you're interested it's chronicled on this site somewhere).
    I agree with Rifledriver, if the pump is original to your 77' I would recommend moving to a later 3x8 pump with the larger 42mm bearings. I use a more modern single piece water pump seal on these rebuilds which has proven to be quite reliable. The first waterpump I ever rebuilt was in 2014 and remains on my 328 this day. I think I have a few large bearing core pumps ready to be rebuilt if you're interested.
    timr, JuLiTrO and NoGoSlow like this.
  7. bitsobrits
    bitsobrits Formula Junior
    714
    Omaha, NE area, US
    Steve
    Is there a reliable way to tell which bearing size one has with the pump installed on the car? Or would I need to have the pulley or pump removed?
  8. SeattleM5
    SeattleM5 Formula 3
    1,259
    Ettore Palazzo
    You should be able to tell by looking at the outer diameter of the water pump housing without removing the pulley. I don't have the exact measurements handy but you can see from the image below that the OD of the bearing on the larger bearing pump is 42mm while on the small bearing pump it is 35mm. I'm not sure what the exact thickness of the pump housing wall is but all things being equal, the outer diameter of the pump housing would be 7mm difference between the two. I have several large bearing pump cores at home and I'll measure the outer diameter of the housing and report back tonight after work.
    timr and JuLiTrO like this.
  9. SeattleM5
    SeattleM5 Formula 3
    1,259
    Ettore Palazzo
    timr and bitsobrits like this.
  10. bitsobrits
    714
    Omaha, NE area, US
    Steve
    Great info, thanks!
  11. timr
    timr Formula Junior
    Sep 24, 2006
    274
    Seattle Washington
    Tim
    Thanks all. DM’s Sent.
    Man, I love this forum.
    JuLiTrO likes this.
  12. Dr Tommy Cosgrove
    36,301
    Birmingham, AL
    Tommy
    Whatever "upgraded" wp Rutland sold 25 years ago is pretty damn robust and durable.
    timr likes this.
  13. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,184
    Kingsport, TN
    Lawrence A. Coppari
    FWIW, I had mine rebuilt by the Flying Dutchman. It's been in service since October 2017. So far, so good.
    timr likes this.
  14. 3px19
    3px19 Karting
    Aug 29, 2006
    217
    Calvin crouch
    seatlle m5
    concerning the single piece water pump seal for rebuild, what is the part number, who for manufacturer (Febi in the photo?) and finally where to source it. Looked on superformance and they don't have. any info appreciated
    thanks
  15. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,783
    Cerritos, CA.
