'78 GTS Intermittent Wiper Problem | FerrariChat
Discussion in '308/328' started by tomberlin, Sep 13, 2024.
  1. tomberlin
    tomberlin Formula Junior
    849
    Bethesda
    tom berlin
    Wrong title, but I can't see how to edit it. Intermittent wipers work . It's LOW SPEED that does not.
    My 308 wipers do not move when I move the toggle switch that is supposed to regulate fast or slow wipers to the slow position. The toggle switch is functional, it changes which terminal is hot when I move the lever, but the wipers die in that position. The wiring diagram gets real fuzzy when you try to separate out this function. Full disclosure- I believe I'm pretty good with electrics and diagrams, but I guess not today.
    Any thoughts? Thanks in advance, I hope.
    For next time is there any way to edit the title?
    Tom B
  2. Steve Magnusson
    26,821
    No, but you can "report" your own post and ask a Moderator to change it.
    Are you saying that high speed works OK in both intermittent mode and constant "on" mode, but low speed does not work in either mode?
  3. tomberlin
    849
    Bethesda
    tom berlin
    Yes- high speed works in both standard and intermittent, no low speed.
    Cheers,
    Tom B
  4. Alden
    Alden F1 Rookie
    3,604
    Central Florida
    Not sure about your car, but my 1988 Mondial 3.2 has a large Sipia relay that controls the intermittent wiper operation, you might want to check that. Solder joints in the stalk can also fail.
    Alden
  5. tomberlin
    849
    Bethesda
    tom berlin
    Alden thank you for your reply. It turned out that there was a bad connection at the multi-pin connector at the wiper motor.
    For the moment it's all working.
    Tom B
    Alden likes this.
  6. Alden
    Alden F1 Rookie
    3,604
    Central Florida
    Deoxit is your best friend for electrical connections! "I put that sh*t on everything!"
    Alden
  7. Il Tifoso
    Il Tifoso Formula 3
    Oct 22, 2013
    1,643
    SF Bay Area, CA
    Ruben
    Wow, never even realized my 308 had wipers! :D:rolleyes:
