79 308 mirror vibration | FerrariChat
Discussion in '308/328' started by tomgua1, Apr 12, 2025.
  1. tomgua1
    tomgua1 Rookie
    May 14, 2024
    5
    Danville
    Tom Guadagni
    I was working on the 79 308 window lift and noticed two unpainted supports inside the door supporting the mirror mounting provisions. Are these stock or were they added by a p.o. to minimize mirror vibration?
    Also, does anyone know if the 6 pin power window switches used in 79 to 82 Fiat 124 spiders will work on the 308. Vicks Autosport sells them for $22, but said they had no idea about ferrari stuff.
  2. MaranelloMark
    MaranelloMark Formula Junior
    429
    Bay Area, CA
    Mine vibrates like crazy and I just figured it was normal for its age. 1977 GTB
  3. Dockboy
    Dockboy Formula Junior
    541
    Maryland
    Mark,
    I put an 18 ga. backing plate on the inside of the door skin curved to the profile then used riv-nuts instead of the screws to mount the base.
    Solid as it can be!
    MaranelloMark and ChevyDave like this.
  4. MaranelloMark
    429
    Bay Area, CA
    Thanks!
  5. tomgua1
    tomgua1 Rookie
    May 14, 2024
    5
    Danville
    Tom Guadagni
    Image Unavailable, Please Login I had the common right side window lift failure or intermittent operation. After several hours of research on ferrari chat, YouTube, wiring diagrams, etc, the problem turned to be a loose left side connector under the clock oil temp guage panel. The seven terminal connector doesn't have a tricky latch just push it together as hard you can and hope it doesn't loosen up for a few years. All three switches work great now and the right side window is now raises faster.
  6. tomgua1
    tomgua1 Rookie
    May 14, 2024
    5
    Danville
    Tom Guadagni
