'79 308 restoration | Page 15 | FerrariChat
'79 308 restoration
Discussion in '308/328' started by Newman, Dec 30, 2003.
  1. Nate Johnson
    Nate Johnson Formula Junior
    Nov 7, 2006
    370
    Why no ceramic coating? You could coat them matte or gloss black - - they would last longer, keep the engine bay cooler, and still look "correct". Just a thought, but in the end it's not my money!
    I'm so excited!
  2. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,465
    Canada
    Newman
    Money is a factor, I have to draw the line somewhere! Plus I dont think I need to, it'll look good.
  3. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    #353 Newman, Apr 15, 2007
    Today I tackled the brake lines. I went with the original lines but had them replated. I considered stainless steel but I hear of nothing but headaches with sealing them at the flared ends. So, with the originals replated and already pre-bent it was easy to figure out where they went. The main line that runs to the rear was a small PITA because I had to pull the Battery + cable back out, run the line down the tube and then put the cable back through since they run together. The next challenge was the master lines that are bent in several places and run together down another small tube at the firewall. They just fit but im sure they must have been made in place on every car by hand, very time consuming. I took a few under shots as well. The gas pedal still impresses me the most, talk about engineering. During the disassembly of the car I remember the gas pedal blowing my mind, made me forever turn my back on the old muscle cars that had a small bent steel rod and a plastic flap pinned to it for a pedal. Its the small things like that that make all the difference and explain the cost behind buying one of these cars new.
    Forgive the dust on the frame, the flash really brings it out and makes it look bad. I also plan to detail it before the engine and gearbox go back in.....which is very soon!
  4. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
  5. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,577
    Avvocato
    Its coming along nicely Paul !
  6. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    Thanks Ric, next weekend it should have an engine in it, just need the rebuilder to finish the alternator since its a prick to install after the engine is in.
    I took the boxer for a spin this afternoon to get the inspiration to work on the 308, Cant wait till summer :)
  7. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    This is looking great - very inspirational.
    What a wonderful car this is!
  8. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    #358 Newman, Apr 18, 2007
    Thanks Russ, im happy withhow its coming along so far. Wish it was done already but im back on track and hussling on it. Im hoping its done this summer and on the road.
    Today I did the belts, tensioners and afew other things not posted. The mounts and some brackets are done. I have to install some engine compartment hoses, finish up the clutch end of things, the alternator and starter and then the headers then drop the assy back in. Then ill move onto the A/C, cooling system and brakes saving the interior and glass for last.
  9. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
  10. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    #360 Newman, Apr 18, 2007
    ...I guess one thing im not completely happy with is the cam gears. I didnt want to mess with the plastic gears just to plate the retaining bolts only to have them hidden by the timing covers so forgive me for not going over the top on that one detail. The cam marks line up perfectly and I decided to leave the degreeing alone and reduce my headaches.
  11. Nate Johnson
    Nov 7, 2006
    370
    (whoops, I didn't see your last post)
    Rock'n'Roll!
  12. Emilio84
    Emilio84 Rookie
    Mar 23, 2004
    6
    wow... just read the entire thread from start to finish and I just want to echo the comments of others. Fantastic work! You're building a dream car of mine (mint euro 308).
  13. sc67vette
    sc67vette Karting
    Feb 28, 2007
    92
    Dallas, Tx
    Steve
    OK, I am going to start on my 308 tomorrow. I will be using this thread as my bible.
  14. Corsa308
    Corsa308 Formula Junior
    Apr 22, 2007
    290
    Sydney, Australia
    Steve D
    Paul, any reason you didn't go for Nick's cam gears and tensionsers?
  15. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    Im honoured, just dont take as long as I have! Motivation was my biggest enemy but I see the light at the end of the tunnel. This is my first ferrari resoration and not my last (im used to muscle cars). I cant begin to explain how much Ive learned about the brand from taking on such a project. It wont be a profitable exercise but the education is priceless as well as the sense of satisfaction. Ill continue with the pics, I installed dozens more studs in the engine/gearbox on friday and im aming for this coming weekend to install the assembly followed of course by more pics.
    Thanks everyone for the support :)
    P.
  16. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    Good question, hard to justify the cost vs benefit. I would go 7 years on a belt change on the 308 and use up a saturday doing the job and assuming the cost of the conversion would be $2K or somewhere around there I cant see the benefit. The belts I installed in 01 that I just replaced last week look perfect as did the tensioners that I never replaced when I bought the 308 and did the belts. The sticker on the plate at the time I bought the car had expired 7 years prior to 01. So assuming the tesnioners were installed no sooner than 13 years ago I would say there is a lot of hype surrounding the failure potential. I could probably replate them and sell them! I guess that was the long reason/explanation. I drive my car regularly so maybe that helps and I know others have had grief with belts, maybe it comes down to installation? I dont know but ill stick with the factory stuff. I wonder if that kit would work on a boxer? Now that would be worth it.
  17. Corsa308
    Apr 22, 2007
    290
    Sydney, Australia
    Steve D
    They probably lasted so well becasue you use the car. I am a big believer in keeping the car exercised and not stuck in the garadge for a 15 min trip every month. Thats what makes cars unreliable. Any car not just a Ferrari.
    Especially belts and water pumps. It isn't much of a surprise that both these items get such a bad wrap, but you can see that if the car isn't used enought then belts and water pump would be the first to go. When I bought my QV the owner said that I should get used to replacing the water pump. I diligently bought a reurb kit for the pump straight away and new I would be ready when it died. I had the car for ten years it it never failed, but then I did drive it to work every day. Roof off, Sydney weather, perfect. Still have that kit.
  18. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    Ill sell it to you when its done :)
  19. irondogmike
    irondogmike F1 Rookie
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    and if he doesn't buy it, I will
  20. irondogmike
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    what I meet to say is if he doesn't buy the car I would love too
  21. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    #371 Newman, Apr 25, 2007
    Here are some pics as of today, I've been too busy to devote the time I need to get this thing in by this weekend so my goal is no later than next weekend. I have to install the rebuilt alternator and starter, install the clutch spring and lever set-up, timing covers and get the headers ready. A few pipes and clamps in the engine bay and in she goes. I keep saying that but it will happen!
  22. spiderseeker
    spiderseeker Formula 3
    Jul 22, 2005
    1,718
    Colorado
    Steve
    Great job- love the pics !!!
    I bet you can't wait to fire it up again.
  23. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    You're right and Ill do it with open headers just to hear it uncorked!
  24. spiderseeker
    Jul 22, 2005
    1,718
    Colorado
    Steve
    You should put an audio clip of the open headers here !
  25. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    I dont know how to do that but when im closer Ill see what I can do.
