'79 door panel lock pull grommet | FerrariChat
Discussion in '308/328' started by AZDoug, Jan 4, 2010.
  1. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    That little chrome bezel around the door lock pull at the top rear of the door panels, those of you that re did your door panel leather, what did you do, remove and reuse the old grommet, or get new ones someplace, or do something else?
    Since I have a lathe and lots of stainless bar stock, I considered spinning up a couple new ones out of 400 series and polishing them and swaging them onto the panels.
    Thanks,
    Doug
  2. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    I am missin one of mine - any source for these??
  3. chris_columbia
    chris_columbia Formula Junior
    868
    Columbia MD
    Chris
    Well it's 2024, did anyone find a source for these door lock grommets? I pulled one of my door panels apart yesterday. I have the leather and glue. Will order foam today. But, this grommet doesn't appear to be used on another more common car. This would have been quick to knock out back when I had lath access. Guess I'll try to bend it back into shape and if that doesn't work, I will farm it out to a machine shop.
    On a side note, the gel coat on the side panels is very orange(well, at least after 2hrs of cleaning the old glue off with some nasty chemicals). You guys with red cars are lucky. When you get a paint chip on the rear wheel well, it's also this color underneath. With a red car you barely notice. On a blue car, people think I repainted a red car, blue.
  4. chris_columbia
    868
    Columbia MD
    Chris
  5. chris_columbia
    868
    Columbia MD
    Chris
    Well, I used a M8 Stainless Steel Rivnut. Mcmaster-Carr PN# 97467A693. Sliced the rear into strips, which get bent over on the underside of the panel. Worked great.
    rjlloyd and bitsobrits like this.
  6. bitsobrits
    bitsobrits Formula Junior
    Nov 12, 2011
    750
    Omaha, NE area, US
    Steve
    Nice example of lateral thinking...and a nice result in the car.
