'79 rear caliper leaking at the E-brake mechanism | FerrariChat
Discussion in '308/328' started by AZDoug, Oct 21, 2022.
  1. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    The ~7/8" diameter round plug at the bottom of the e-brake lever/fulcrum/whatever you call it.
    The piston seals in the caliper were all replaced 3 years ago.
    What is involved in stopping this leak?
    I assume that area is pressurized while braking?
    Or is there another internal seal that is leaking into the e-brake mechanism, letting it run out around the bottom plug??
    My service manual doesn't have diagrams of the calipers.
    Doug
  2. JTT
    JTT Karting
    Jun 16, 2020
    182
    Ontario
    J Taylor
    There is a small o ring in there that could have easily been missed. It’s not a difficult job to rebuild the caliper. You may not even need to do the pistons or piston seals. There are some excellent tutorials on this here.
    I did 4 of mine with no experience and they all work perfectly.
    Joe
  3. absostone
    absostone F1 World Champ
    10,034
    Go find the PMB brakes vid. Ive posted it plenty of times here. Good luck
    Steve Magnusson likes this.
  4. absostone
    10,034
  5. LB427SC
    LB427SC Karting
    Aug 5, 2021
    132
    Wales, UK
    Lloyd Barnes
    Mine was doing exactly that. O ring on the adjuster shaft as per above solved it. There’s also o rings on the handbrake lever shaft. Easy job. You’d do both rear callipers in a day.
