7DCL750 Diagnostic Help | FerrariChat
Discussion in 'FF/Lusso' started by nguyennhatquang, Dec 3, 2022.
  1. nguyennhatquang
    nguyennhatquang Karting
    Feb 13, 2016
    206
    Hanoi
    Hello,
    My F12 today just suddenly got an issue with the Transmission..
    I got 2 fault code
    P2746 : IN clutch speed ODD invalid singal
    P0842 : in clutch pressure odd too low
    According to the service manual i have 2 issue with Speed sensor and Pressure sensor...
    But when the car restart,, it just shift fine.. only when the trans warm up.
    So, I hooked up my Leonardo in order to read the parameter
    I found that when the transmission is cold : Both the Even Clutch pressure and the Odd Clutch pressure pretty equal to 1.2 1.3 bar..
    but when the trans hot.. the Even clutch pressure still hold it value is : 1.375 bar but the Odd clutch pressure drop to 0.887 then continue to drop to 0.6 and 0.5 which will trick the Transmission lamp.
    Anyone did this transmission before can give me advise? do I has some Hydraulic leak somewhere ?
    thanks..
  2. Altoria F
    Altoria F Formula Junior
    Jan 24, 2020
    438
    France
    P
    I do not have a Leonardo but a simple Autel, my FF showed a speed sensor error when hot and was ok when cold.
    2 times she stayed stuck in neutral and by luck it was at home when arrived before its garage ("hot" gearbox).
    I get it to my dealer (in a closed trailer) and swapped the whole sensors and wire (5-6k€ job), no more issue so far.
    nguyennhatquang likes this.
  3. nguyennhatquang
    Feb 13, 2016
    206
    Hanoi
  4. SeattleStew
    SeattleStew Formula 3
    1,019
    In the rain
    Stew
    You should post this in the technical Q&A section if you haven’t already. There are ferrari mechanics who check that section more regularly than model specific ones.
    Falcon7x likes this.
  5. nguyennhatquang
    Feb 13, 2016
    206
    Hanoi
    @SeattleStew : I created another thread as in the Forum u said.. thank you alot
