81 308 RPM Erratic | FerrariChat
81 308 RPM Erratic
Discussion in '308/328' started by Pauly, Jun 3, 2008.
  1. Pauly
    Pauly Rookie
    Nov 30, 2007
    37
    Colorado
    Paul
    Hi everyone just started to notice a problem and having a hard time trying to figure out what it could be. About two weeks ago I noticed that the RPM needle started to jump up and down a bit at about 2500 RPM and up and could feel it in the seat that the engine was running with a slight hic-cup leading me to believe that the RPM needle was reading correct. So I thought it might be the gas I was using (Shell here in Denver) so when it was about empty I put in Conoco and a bottle of Chevron fuel injector cleaner and still having the same problem. OK this is what's confusing me to, when in neutral and I rev it through the RPM range and hold it steady at each 500 RPM increments and up to 5K starting at 2k it's smooth, idles smooth too. Any help here would be great, thanks.
  2. desire308
    desire308 Formula 3
    Oct 19, 2007
    1,433
    Florida
    Peter W
    Check your digiplex grounds [under the left rear storage area].
  3. Pauly
    Pauly Rookie
    Nov 30, 2007
    37
    Colorado
    Paul
    Peter you are awesome! It was the digiplex grounds; I can't believe it was that simply. I had no idea those boxes were under there, I would have never figured it out without this web site and your help. I cleaned both boxes (801's) and re-grounded both wires. Both ground wires were on the same bolt so I separated them, each one to a separate ground point. Works like new hope it last a while. Thanks again.
    Pauly
  4. desire308
    desire308 Formula 3
    Oct 19, 2007
    1,433
    Florida
    Peter W
    I found it out in the tech forum I believe...either way the symptoms fit the scenario I have heard a number of times. They are prone to this problem and I have also read it's best to run new grounds from each digiplex and this will keep them stabile. Also make sure the connectors are kept nice and clean/snug. Good to hear I nailed it :::)))
  5. andy308
    andy308 Formula 3
    Jan 16, 2005
    2,025
    Sarasota, FL
    Andy
    I had this same problem with my car a few years back and this solved it right away, F-Chat rules!
