81 308 Towed Home after car show | FerrariChat
Discussion in '308/328' started by Gordo308, Jul 5, 2017.
  1. Gordo308
    Gordo308 Karting
    Sep 2, 2013
    98
    Essex, CT
    Gordon Laing
    Hi All,
    I drove my 308 to the car show 5 miles away yesterday. On the way there it bucked under acceleration for the first time in the 4 years since I've owned it. I continued to the car show anyway. After the show, it started but I had no power, it wouldn't even rev up. The least bit of pressure on the gas pedal stalled the car. I was able to limp it out to the parking lot where I got a flat bed to bring me home.
    It starts, all banks are firing, but can't put a load on it. I'm thinking fuel filters (but could both have gone bad) or the fuel pump has weakened.
    I haven't begun troubleshooting yet.
    I welcome any advice.
    Cheers
  2. 19633500GT
    19633500GT F1 World Champ
    13,098
    Blueberry
    Muffin-Tops
    If you unplug the fuel pump, does it still work (you'll hear it) after you start the car?
  3. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    clogged/dead fuel injectors would be one thing to check. What you describe was very similar to what I experienced with my Esprit once. It would run (just barley), no revs, no power. Injectors are not that easy to check/pull on a 308 so start with some easier stuff like fuel filter, pump or check fuel pressure.
  4. Gordo308
    Gordo308 Karting
    Sep 2, 2013
    98
    Essex, CT
    Gordon Laing
    Update: I just tried to start it and it fired right up and sounds fine!! Revs without issue.
    I haven't gone on the road yet. Still weary. Maybe a short ride up my rode and back later today.
    Maybe a vapor lock or still the fuel pump.
    The filters should be fine.
  5. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    Water in the fuel from sitting?
  6. RED HEAD
    RED HEAD Karting
    219
    London
    H
    I had a similar experience and it was a faulty fuel pump. Started fine but as soon as any throttle applied it died.
  7. johnhunt
    johnhunt Formula Junior
    Aug 9, 2013
    343
    Washington
    John Hunt
    I had this on a Porsche once. It was a rubber hose on my air intake that would pinch itself when the engine was under load. Of course no load and it looked normal. Took awhile to figure that one out.
  8. Rosey
    Rosey F1 Rookie
    Nov 5, 2015
    3,809
    Australia
    Mark R
    That would have been my guess. Water in the tank.
  9. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,220
    Gold Coast, Aust.
    Patrick
    +308
    Had the same with the 400 - put a tank of E10 through it to suck up the water
  10. pappy.72
    pappy.72 Formula Junior
    Nov 13, 2010
    536
    Elgin, IL
    Dave
    Simple fix. Stop going to car shows and just drive it more. How often are you driving it?
  11. Schulz308
    Schulz308 Formula 3
    1,506
    STL USA
    HaHa love that logic!
  12. rjlloyd
    rjlloyd Formula Junior
    Jun 19, 2014
    447
    Brisbane, Australia
    Richard Lloyd
    I had a similar problem with my 81, ended up pinning the problem down to poor fuse connection with the old ceramic fuses, getting hot with a high resistance. Upgraded to Birdmans fuse panels and no more problem. Might be worth checking the fuses for heat if you've still got the old ceramic fuses
