812 gts comming. | Page 2 | FerrariChat
812 gts comming.
Discussion in 'F12/812' started by j09333, Sep 21, 2020.
  1. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    I just saw Kyle Lowry of the Toronto raptors getting
    A Grigio GTS looked amazing ! Congrats on urs!
    j09333 likes this.
  2. j09333
    j09333 Formula 3
    1,328
    You can try configurater. These plus carbon dashboard inserts are my choices.
  3. j09333
    j09333 Formula 3
    1,328
    #28 j09333, Nov 13, 2020
    Pulled out valve hose and pluged it.
    Sound stupidly good.
    Well lets hope CEL light doesn’tcome on.
    Take the wheel off and you cna access it pretty easily.
    of2worlds likes this.
  4. j09333
    j09333 Formula 3
    1,328
    Overall I just wanted to see if GPF has any effect on raw sound and electronics.
    Based on past experiences with f12 and ff, it sounds same when valve is open.
    of2worlds and junc like this.
  5. Horsin'around
    Horsin'around Formula Junior
    Jun 14, 2017
    255
    Good to hear.
    Any sound clips/videos?
    We would all love to hear that glorious V12.
  6. KenU
    KenU Formula Junior
    Oct 14, 2004
    543
    Planet Earth
    Ken
    There was a post on another GTS thread in which the owner installed the Capristo Valve Controller on his GTS and stated no CEL and greatly improved exhaust note.
  7. junc
    junc Formula Junior
    501
    Chicago/Laguna Beach
    Jun
    Any check engine lights now that it’s been a day since you plugged them? My service tech keeps saying he is pretty sure it will trigger one if I plug the valves or use the controller on my incoming GTS. I saw that the controller didn’t trigger one in another GTS.
  8. KarlA69
    KarlA69 Formula Junior
    Oct 9, 2017
    759
    Karl
    I’ve got the Capristo controller on my GTS and can confirm there are no CEL or other issues
    Avia11, of2worlds, Thecadster and 2 others like this.
  9. junc
    junc Formula Junior
    501
    Jun
    Thank you for the confirmation.
  10. KenU
    KenU Formula Junior
    Oct 14, 2004
    543
    Planet Earth
    Ken
    How's the sound/tone/volume in your opinion (valves open) compared to the pre-GPF 812SF?
  11. Avia11
    Avia11 Formula Junior
    877
    San Diego, CA
    can you post a video of the sound? I'd like to do the same if the sound is much better. thanks in advance for your consideration. i appreciate it. :)
  12. j09333
    j09333 Formula 3
    1,328
    The only difference in sound is under 4000 rpm. It is much linear. Volume increase under 4k significantly so be aware.
    Why do this? Most v12 torque down under is enough so opening valve do little. Also, most of the time spent is under 4k so people does this incliding me.
    Compared to SF, with or without valve mod, yes it loses somewhat to SF’s shouting nature up at the top rpm. Has more rounded sound so to speak. But it is not less or worse. I wish I speak more fluent english.
  13. j09333
    j09333 Formula 3
    1,328
    No cel so far. It seems valve mod doesn’t affect any GPF sensor.
    My exp with valve mod is as following.
    V8 had no issue. 430,458,488.
    Lp640 had no issue.
    Avantador had an issue. No CEL but engine frequently died during idle. Less back pressure made this.
    FF died during idle too.
    F12 was good for years. No CEL no idle die.
    I didn’t try SF and Lusso.
    By the way, GTS died during idle twice even before valve mod, so I figure I will do this mod and see because I have to check the car anyway for this matter in the shop anyway.
  14. Alcav5
    Alcav5 F1 Rookie
    4,079
    Scarsdale, NY
    Al
  15. of2worlds
    of2worlds F1 World Champ
    17,988
    ON
    CH
    Oh from the blow up picture no shields or are you going with those special painted shields???
  16. Alcav5
    Alcav5 F1 Rookie
    4,079
    Scarsdale, NY
    Al
    sharp eye, I didn't even realize.
    No shields, wanted the Avio blue to be predominant also wanted to be low key.
    tomc, j09333 and of2worlds like this.
  17. gliazzurri
    gliazzurri Formula Junior
    Jun 11, 2016
    479
    Maryland
    Those are all stock photos. I believe each one is identical.
  18. Alcav5
    Alcav5 F1 Rookie
    4,079
    Scarsdale, NY
    Al
  19. of2worlds
    17,988
    ON
    CH
    Yes that was once the thinking when the picture seemed the same. However Il Co-Pilota asked the tech guy at the Ferrari factory and each picture is that car as he explained in the reply copied below>
    There was some guess work regarding this, but I did some digging. They are in fact correct, they are not reused.
    The three cams are not manned and just snaps a photo when the car passes. It literally takes zero effort to get the pic. The little effort lies in getting the pic sent out. It is fully automated and as one of their techs said when showing me the cam. Why cheat with something that is fully automated and just runs itself.
  20. gliazzurri
    Jun 11, 2016
    479
    Maryland
    Ok maybe then not the case. Guess we see for sure now that a declared painted shields owner shows it. Good to know. All the others seem nearly identical even the backgrounds. Whereas the other ones are a bit different positioning in the frame.
  21. bearmdjd
    bearmdjd Karting
    Jul 10, 2017
    77
    j09333, tomc and of2worlds like this.
  22. Alcav5
    Alcav5 F1 Rookie
    4,079
    Scarsdale, NY
    Al
    Avia11, of2worlds, Cigarzman and 2 others like this.
  23. Alcav5
    Alcav5 F1 Rookie
    4,079
    Scarsdale, NY
    Al
  24. j09333
    j09333 Formula 3
    1,328
    With valve open all time, sound is more linear.
    Will post track footage if I get a chance
    junc, RamsHmb and Alcav5 like this.
  25. j09333
    j09333 Formula 3
    1,328
    Something went wrong with youtue
    Here is new link
    NZCREW, italiafan, Ryan13 and 2 others like this.
