812 GTS: To Novitec or not be Novitec! | Page 3 | FerrariChat
Discussion in 'F12/812' started by nimamd, Oct 2, 2022.
  1. Lagunae92
    Lagunae92 F1 Rookie
    3,107
    SoCal
    Call me crazy…but I am really enjoying the sound of the stock GTS. With the top down, it gives you some great sound. It almost sounds more pure and tonal to me than the 812SF, which had a more raw and guttural sound. I’m in break-in mode, so haven’t explored the higher 8k rpms yet, but so far so good. Really considering an x pipe, even though I didn’t like it much on the SF. Now, I didn’t think the valve controller did a lot for the SF, but I can really hear the valves opening and closing in the GTS, so looking very much forward to installing that shortly.
  2. U-Boat Commander
    U-Boat Commander Formula 3
    1,334
    On its own the 812 GTS sounds great with the top down. But I ran it side by side with my 599 and it sounded very muted.
    Lagunae92 likes this.
  3. Lagunae92
    Lagunae92 F1 Rookie
    3,107
    SoCal
    I’m sure. The SA?
  4. U-Boat Commander
    1,334
    Yeah, it's like a whole another level.
  5. Lagunae92
    Lagunae92 F1 Rookie
    3,107
    SoCal
    Wish those noise restraints were the same as that era.
  6. marcmc8867
    marcmc8867 Formula 3
    Jul 27, 2004
    1,028
    NC
    Marc M.
    I took delivery of my GTS Saturday. The sounds is amazing and so far I don't have any thoughts of changing it. With the top down especially it is glorious.
    RamsHmb and Lagunae92 like this.
  7. Condor Man
    Condor Man F1 Rookie
    4,938
    Los Angeles
    That’s great to read!
    The less you have to do the better.
    I don’t mind the full blown sound in my TDF however for the 812 GTS I think it is nice to have it more as a gentleman’s car rather than a racer.
    BTW - Are you around this weekend?
    I will be down at Newport Sat, Sun, Mon.
    May the Horse be with you
    Caeruleus11, RamsHmb and Lagunae92 like this.
  8. Lagunae92
    Lagunae92 F1 Rookie
    3,107
    SoCal
    Supposed to go skiing, but the plans may change. Will keep you posted.
    Condor Man likes this.
  9. Condor Man
    4,938
    Los Angeles
    OK. No probs.
    Let me know if your plans change.
  10. Gh21631
    Gh21631 F1 Veteran
    9,312
    East
    A valve controller makes a pretty good difference but not crazy loud. Cold start with the valves open sounds great.
  11. Condor Man
    4,938
    Los Angeles
    How about the Enzo gathering at the Petersen next weekend?
    Are you going to this?
  12. Lagunae92
    Lagunae92 F1 Rookie
    3,107
    SoCal
    I signed up yesterday hoping I can make it work.
  13. Condor Man
    4,938
    Los Angeles
    That's awesome.
    It is always a big event!
  14. nickorette
    nickorette Formula Junior
    Jun 19, 2017
    380
    Canada
    Mine's sitting underground awaiting spring to arrive, but did have a chance to hear start-up with the exhaust remote. Sounds glorious!
    I think the other thing to consider is the back window, putting that down creates a nice sound chamber in the cabin.
    Lagunae92 and Thecadster like this.
  15. Lagunae92
    Lagunae92 F1 Rookie
    3,107
    SoCal
    It's a game changer for sure. Now I want all of my cars to be spiders because of that option.
    nickorette likes this.
  16. Tupps11
    Tupps11 Formula Junior
    Jan 7, 2009
    560
    There is ZERO need to go all in and pay for the entire setup from the get go.
    I installed the Novitec X-pipe + the remote controlled valves on my OEM F12.
    It's mooooooooooore then enough. No fumes. No drone. Loud when you open the valves and civilized when you keep them shut. They open automatically anyway when you go above a certain RPM.
    Best part is...you can always do the sport cats or back boxes later when you are bored and feel like upgrading something. None of these parts are reliant on the other.
    I guarantee you won't do either once the x-pipe and remote valves are installed.
    soulsea likes this.
  17. Lagunae92
    Lagunae92 F1 Rookie
    3,107
    SoCal
    I had a different experience adding an X pipe to lay to my 812. The high rpm sound was great, but I lost almost all low end volume. Downshifts were thin, and the x pipe needs more air flow to really get what you want from it. My 812 didn’t have a GPF, which reduces airflow even more. It’s a warranty buster, but HFCs will make the most difference on the GTS.
  18. Tupps11
    Jan 7, 2009
    560
    My F12 was Euro Spec. Back in 2015 the cars came without the gas particulate filter (thank God).
    I really loved the sound. Doesn't mean it wouldn't sound better with the high flow cats.
    But overall, i didn't regret the decision to upgrade in phases. Especially since the high flow cats required detaching the engine mounts and lifting the engine slightly for the access needed to install.
  19. KarlA69
    KarlA69 Formula Junior
    Oct 9, 2017
    759
    Karl
    I had the same experience exactly - need high flow cats otherwise X pipe is unimpressive
    Bundy and Lagunae92 like this.
  20. Lagunae92
    Lagunae92 F1 Rookie
    3,107
    SoCal
    I like the phases idea too. I’ll likely do an x pipe and see how it is with the top down, then hfcs even the warranty is almost out. Something like that.
  21. 250boano
    250boano Formula Junior
    Apr 27, 2022
    452
    Europe
    DD
    No F12s were fitted with GPF, all 812 GTS are fitted with GPF. Not a fair comparison.
    With the GPFs in place anything you do behind them has it's efficacy massively reduced.
    With the GTS you need to go full bore, or leave it as is.
  22. Terrence
    Terrence Formula Junior
    Feb 15, 2004
    361
    Hawaii/LA
    Terrence
    Anyone installed a valve controller on the GTS? Or specifically, GTS with particulate filter? Like a 2023? I was told by Forza, who makes the controller that I may not wanna buy a valve controller for my 2023 GTS because it has particular filter and the computer looks for certain pressure in the exhaust, and if I open the valves manually, the computer will think there’s a problem and either trigger the check engine light or going to limp mode. Any thoughts?
    Thank you.
  23. Gh21631
    Gh21631 F1 Veteran
    9,312
    East
    Mine is a late 22' and no issues with a valve controller.
  24. Lagunae92
    Lagunae92 F1 Rookie
    3,107
    SoCal
    All GTS models have GPF. No issues with my capristo remote.
  25. soulsea
    soulsea Formula 3
    1,402
    29464
    I'll let you know as soon as mine gets here. I have the Capristo thingie sitting in my garage, but I can't imagine a 23 is any different than a 22.
