812 Replacement Rumors | Page 101 | FerrariChat
Discussion in '12Cilindri' started by Thecadster, Jun 29, 2021.
  1. ohno
    ohno Formula Junior
    Sep 10, 2009
    353
    In your post #2480 you focused on the technical differences between the F12 Berlinetta and the F12 TDF. And you nailed it! But if I understand day355 correctly in his last posts he is more referring to the optics of a SWB, which can be seen a bit in the side view of the F12 TDF. In his opinion, the three side air outlets above the rear fender are not (styling effect #2483). This leaves only the front air outlet and the wider C-pillar of the F12 TDF, reminiscent of a (250 GT) SWB. And as Caeruleus 11 mentioned in #2494, the modern cars, with their very long hoods make it difficult for us to see SWB in anything. So the Ferrari Centro Stile has not so many options to focus on this theme. But the slightly wide C-pillar is a good option in my opinion. But of course we are talking about very subtle differences here!
    Solid State likes this.
  2. Condor Man
    Condor Man F1 Rookie
    4,938
    Los Angeles
    I am 100% with you on this one.
  3. ohno
    ohno Formula Junior
    Sep 10, 2009
    353
    #2503 ohno, Jan 2, 2023
    But even in this image comparison, the wider C-pillar dominates (besides the three ventilation slots). According to day355, it's not the three slots, so only the C-pillar remains.
    I did some more research and now found this little sketch by F. Manzoni regarding the F12 TDF design...
    Caeruleus11 and 456-boy like this.
  4. Adrien3
    Adrien3 Rookie
    Oct 29, 2021
    10
    Fuel cap?
  5. maha
    maha F1 Rookie
    Mar 17, 2014
    3,706
    dinajpur, bangladesh
    mahmud
  6. abdulla.alhajri
    abdulla.alhajri Karting
    Jul 16, 2015
    129
    oh boy!!!!! 812SF was really the last true v12 when you listen to this
    tickerhound, KenU and Solid State like this.
  7. RogGT-R
    RogGT-R Karting
    Jul 20, 2020
    110
    London, UK
    Roger B
    Short shifting way way early was he not?
    Looked more like slow speed reaction and stability testing potentially.
    Caeruleus11 and Dubaicity like this.
  8. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,563
    Austin TX
    Contrast:
    @Varryx
    can you still access that area closer to the track as shown in the above video, allows closer observation and sound recordings
  9. kane00
    kane00 Formula Junior
    491
    Los Angeles
    Keith
    . What are talking about. You can’t tell anything.
  10. Glenn Quagmire
    Glenn Quagmire Formula Junior
    614
    I expect to be spec’ing my 812 GTS fairly soon and have been told it will be among the last to be produced. However, if the replacement also has a V12 (as rumored), the desire to proceed with the 812 disappears for me. I imagine that it’s more likely that a V12 successor, is the last of its kind…and ultimately the one to have. If true, the lure of the 812 is reduced along with its value. Curious what others think?
    LMH likes this.
  11. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    it looks like they are testing the stability control system in the various settings. You can see how the car starts sliding then immediately straighten up and cuts the power.
    RogGT-R likes this.
  12. Caeruleus11
    Caeruleus11 F1 World Champ
    11,619
    Get what you want. I say a bird in hand and all that.
    There’s no guarantee of anything. What if the people here, as well intended as they are, are somehow mistaken, or Ferrari just changes their minds. Its an Internet forum, and we don’t owe each other anything- though I would submit, we owe each other good intentions and hopefully most of the time good manners.
    However, even if the info here is correct, you at least know if you love or like about the GTS. If the successor is as described, maybe it has a soft top- how will you feel about that? Very very likely it has some form of all digital interior- how do you feel about that? I am very much open to change but the loss of a physical tach, starter button removes some of the emotional response from me and the lack of physical HVAC controls I find just silly. Maybe they add some of that back? In my case, I would look past these things if the car itself is brilliant, as I expect it will be.
    Its hard to play the “last of” game. I think the GTS will hold value well and you could always roll the GTS into the next one if you want. I also imagine having a GTS on your history will help if you want to get the next generation.
    Scudmsl, KenU, JagShergill and 10 others like this.
  13. Nocetto
    Nocetto Karting
    Jun 3, 2020
    52
    Rookie
    Amen,
    I wonder sometimes why people post comments instead of using common sense.
    HCEdwards, Caeruleus11 and italiafan like this.
  14. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    that's got to be at least the 5th Ferrari for which we say "it's the last V12". So now instead we need to use things like "last V12 without GPF" or last V12 with a manual gearbox, or "last V12 which is not a limited series" (and that one was never true). Anyway just get an 812 if you like it, then swap to the new thing when it comes out if you like it better.
    SirTony76, Shack, nmcclure and 3 others like this.
  15. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,563
    Austin TX
    Life is short, any successor to the 812 with an open top is likely to be several years in the future, maybe 5 or more before you would receive. Do you want to wait that long based on speculation of when/if it will occur?
    What is absolute is any successor will have various intrusive nannies not found on the 812GTS, some of which may not be defeatable. And it will be quieter than the 812GTS due to drive-by noise regulations ever tightening noose. And it will have the dash of the Purosangue (all digital).
    If you are good with all that, I think you still proceed with the 812GTS because there will be many who will not want such an experience and you will likely be able to trade it in at full value. Plus, having an 812GTS will likely position you to be invited to be one of the first to order said successor and thus receive it earlier than otherwise.
  16. Maximus1973
    Maximus1973 Formula 3
    Oct 29, 2016
    1,541
    The GTS is amazing. The next car we have zero fixed information on. Live your life now; not in the future.
  17. of2worlds
    of2worlds F1 World Champ
    18,059
    ON
    CH
    those 'vents' were not something Mr Manzoni wanted to do initially for the tdF design. It was more of an engineering requirement that led to those fender vents being included in the final design. The fact that the vents became an iconic signature detail of the overall tdF design came as something of a surprise to Mr. Manzoni...
    RamsHmb, isot and Caeruleus11 like this.
  18. Shack
    Shack F1 Rookie
    May 2, 2005
    2,626
    Earth
    So true. Took my Speciale out for a drive (after not using it for a while). Reminded me about what analogue driving is all about. When I thing about the test drive I had in the 296GTB vs the drive I had in the Speciale I know which one I would keep.
    The GTS is an absolute blast and pretty analogue too. I would not hesitate!!!
    RamsHmb, Avia11, Maximus1973 and 3 others like this.
  19. 008
    008 Formula Junior
    Jun 6, 2006
    284
    Jupiter Island, FL
    Agreed. I'm less concerned about digital screens and haptic interfaces than I am about the synthetic integration of the hybrid systems. After getting a bunch of seat time in an SF90 and a 296, the distinction became very clear to me as to what eroded the experience. If the 167 isn't a hybrid, I'll happily give up the analog interface. If it's a hybrid, no amount of analog gauges, starter buttons and controls would get me to buy one at this point in their development.
    Shack likes this.
  20. Glenn Quagmire
    614
    Hmmmmm...I wonder where the common sense is in being triggered enough to make an inane forum post about...common sense? Last I checked, the title of this thread is "812 Replacement Rumors."
    Anyway, my point has nothing to do with an analog vs digital experience, or risk of waiting several years for another open top car. I already own all of the above. Rather, my post is about the allure of adding a GTS on the basis of owning the last great front/mid engine V12 GT car from Ferrari. Plenty of buyers pulled the trigger on the 812 platform with this intent. Clearly, Ferrari isn't imminently abandoning the V12 though. So, it begs the question about whether 812 owners that intended to keep the car forever, may choose to ditch it in favor of its successor...assuming the replacement is more likely the last non-hybrid V12 GT? As previously stated, I'm becoming less enamored with owning this car, if there's another V12-only following it. On the other hand, like many others here and elsewhere, owning the last of something (especially in the context of emissions BS) is all the more compelling.
  21. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,427
    Bournemouth, UK
    So far, no driver's assist system in the newly introduced EU legislation is non-defeatable.
    Soleith likes this.
  22. of2worlds
    18,059
    ON
    CH
    What about the "drink-drive" test that is required but won't be turned on initially?
  23. Solid State
    Solid State F1 World Champ
    10,583
    Maximus Decimus Meridius
    Would think the only function for wheel well vents is to relieve well air pressure for higher speed considerations. There is a flap in front on the lower sill that diverts some of the lateral air from entering the well. You don't need the well vents on the hips. He could simply allowed air to exit out the back as in the 812GTS which has huge exit vents yet the dummy vent from the SF. Doesn't surprise me that what he didn't design on the F12tdf was what worked.
    of2worlds likes this.
  24. Maximus1973
    Oct 29, 2016
    1,541
    But don’t you want to drive something now versus driving something in 3-5 years?
    The GTS is a guaranteed hit, we again know nothing fixed about its successor.
    So why wait when you can enjoy ‘life’ right now.
    Unless you want to buy something and keep for life strictly based on the “what if” scenario of the “last” V12.
    ACW44, ANOpax and Shack like this.
  25. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,180
    Denmark
    Max
    and if we have learnt anything over the recent years, the last NA V12 is probably not this one.
    Maximus1973 and ANOpax like this.
