812 Replacement Rumors | Page 134 | FerrariChat
Discussion in '12Cilindri' started by Thecadster, Jun 29, 2021.
  1. DeSoto
    DeSoto F1 Veteran
    Nov 26, 2003
    7,856
    I think I'd rather have the future electric Ferrari than the current V12 SUV. At least it still can look good.
    Well, although they can make an electric SUV.
  2. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,495
    Bournemouth, UK
    Comparisons are always made stock for stock.
    Mainly due to the costs involved. Even more drive even cheaper cars.
  3. bamaman
    bamaman Formula Junior
    Nov 27, 2015
    955
    Mobile Alabama
    William M (B.J.) Lyon, Jr.
    Seems and odd place to put a starter....except in an airplane. What is Ferrari thinking? I still prefer an actual mechanical tachometer rather than the digital version. Rolex hasn't gone digital....
  4. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,495
    Bournemouth, UK
    That's not the engine starter button. It is the button that disables the start-stop function.
    Caeruleus11 likes this.
  5. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,591
    Austin TX
    Seems rather pointless to even have the "start/stop" function (euphemistically called 'High Emotion, Low Emissions' or HELE) at all. 100% agreed on a full analog tachometer!
    Bundy likes this.
  6. RamsHmb
    RamsHmb Formula 3
    1,235
    San Francisco
    James
    JackCongo likes this.
  7. iohead
    iohead Karting
    Feb 19, 2013
    174
    To understand why things are the way they are...
    Engine start-stop is categorized as an "off-cycle" technology by the US EPA. It is meant to achieve CO2 reductions that are not reflected in prevailing pollution test procedures.
    Active aerodynamics to reduce drag and therefore decrease fuel consumption (by a tiny bit) is also categorized similarly.
    Implementing these things in a vehicle allows a manufacturer to obtain off-cycle credits, which help the manufacturer meet the incessantly tightening emission requirements. Because it is so hard for performance cars to meet such requirements, every little thing counts for a manufacturer.
    Moreover, the EPA will only allow the start-stop credit if that's the default mode of operation: you can't disable it permanently, and upon every power cycle, the car must be in start-stop mode. If an owner defeats start-stop (e.g. electronically) , it is "illegal" in the same sense as removing your catalytic converters is illegal.
    Adamas, Ultralab, Kmaaq and 2 others like this.
  8. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,591
    Austin TX
    First, thank you for the deep dive on this topic.
    What I have found is this: because Ferrari did not apply for said credits, it is completely optional and Ferrari should of never included HELE in its USA cars, at least through 2019. And, of course, the in-cabin button provides a built-in "defeat" device...not illegal because Ferrari never applied for the credits:
    https://www.epa.gov/sites/default/files/2021-01/documents/420r21003.pdf
    Page 97
    and other references found by searching the above doc for "Ferrari"
    sailfly and Bundy like this.
  9. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,591
    Austin TX
  10. soulsea
    soulsea Formula 3
    1,402
    29464
  11. iohead
    iohead Karting
    Feb 19, 2013
    174
    Kudos for looking this up. I agree with you that it's strange for Ferrari to have been doing this for several years without getting the related credits. There must be an explanation: we just don't know it yet.
    As for the cabin button to enable/disable it, that's legal in any case. The EPA requirement is that the feature can't stay disabled across full power cycles: as long as it's enabled when you get in and turn the car on, that's sufficient. But yes, I would agree that if HELE isn't a factor for the EPA (no credits), then permanently disabling it wouldn't/shouldn't be considered illegal. (Unless of course you are in parts of California, where plenty of people are anathematic to the very existence of such cars so it might as well be illegal to drive a performance car at all.)
  12. Solid State
    Solid State F1 World Champ
    10,718
    Maximus Decimus Meridius
    I just can't figure out why a company that sells parts costing more than gold would want you to restart your engine at every light instead of once per trip. o_O
    sailfly, ryalex, Bundy and 4 others like this.
  13. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,495
    Bournemouth, UK
    Probably due to EU regulations. No reason for them to re-engineer the cars without the system.
  14. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,591
    Austin TX
    Well Ferrari does try to design to the lowest-common denominator for its vehicle emissions, rarely are there differences from market to market (hence, why GPF is used in USA cars when there is no corresponding particulate matter regulations that would necessitate the use thereof).
    A question for you is this, why would Ferrari have a built-in, non-defeatable, 20-minute engine idle timer that triggers the car to continuously honk its horn non-stop until the car is turned off (i.e. putting in gear has no effect)? I believe that started with the 812SF.
  15. MidnightRun
    MidnightRun Karting
    Nov 4, 2006
    159
  16. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,591
    Austin TX
    Do you happen to have the option code for that?
  17. Condor Man
    Condor Man F1 Rookie
    4,938
    Los Angeles
    It looked the best in this blue;
    Having stated this, I did not see any red cars and most were muted dull dark or light greys or blacks.
    I want to order a Metallic Red..... At this stage.
    KZEVO and RamsHmb like this.
  18. Prancing12
    Prancing12 Karting
    May 8, 2005
    61
    STO it is.
    I've never been a fan of Lambo's with awd, the 2wd was always the one to go for, in my case that is.
    Shack likes this.
  19. Prancing12
    Prancing12 Karting
    May 8, 2005
    61
    I am willing to order a new Ferrari today, if they give me a cockpit that looks like this.
    sailfly, Dan_458 and day355 like this.
  20. day355
    day355 F1 Rookie
    Jun 25, 2006
    2,718
    #3345 day355, Apr 21, 2023
    It's the best sports car today !
    And yet I'm not a Lambo fan...
    The harder you push, the more the car reveals...
    Everything is coherent, nothing is disproportionate...
    I didn't think you could push so hard on the road without ending up at the top of a tree
  21. Shack
    Shack F1 Rookie
    May 2, 2005
    2,646
    Earth
    Totally 100% agree.
    But I am biased :)
    kane00, Spet00, Thecadster and 2 others like this.
  22. day355
    day355 F1 Rookie
    Jun 25, 2006
    2,718
    Congratulations, the best choice for who likes to drive !
    Shack likes this.
  23. WM458
    WM458 Formula Junior
    Aug 25, 2014
    479
    Germany
    With regard to dashboard and infotainment appearance and functionality I was still fine with F8 or 812. except navigation acvuracy.
    F90 and 296 are computer movers. 167 will be the same.
    I prefer to concentrate on the road, the sound and the emotions given by original sports car feelings.
    Anything else can be found with Tesla and friends.
    Altoria F, khal360, FORZA 62 and 2 others like this.
  24. Spet00
    Spet00 Formula Junior
    Jul 21, 2020
    346
  25. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,495
    Bournemouth, UK
    Still a digital dash. Wait till the Needles Brigade see this...
    Altoria F likes this.
