812 Replacement Rumors | Page 193 | FerrariChat
Discussion in '12Cilindri' started by Thecadster, Jun 29, 2021.
  1. Newjoint
    Newjoint Formula 3
    Jan 17, 2016
    1,483
    The 812 handles like car a foot shorter but not lighter. Brilliant for its size and near luxury comfort level. If you choose the GTS get the full electric seats- the seat heater is worth it on cold days with the top down and don’t really notice the extra weight- it is a street car- not meant for the track although it will do it without complaint.
    Caeruleus11 and khal360 like this.
  2. U-Boat Commander
    U-Boat Commander Formula 3
    1,332
    The 812 does surprisingly well on a track. I have tracked it back to back with both a Pista and F8. You'll feel the weight and size in the corners but it's true that it feels smaller than it is; and on the straights it's a monster. But on twisty mountain roads it has a more difficult time compared to a lighter, smaller rear-mid engine car. It's difficult to shift all that weight around in tight corners and fast switchbacks and less weight in the rear means your scooting out the rear end more when trying to get power down.
  3. day355
    day355 F1 Rookie
    Jun 25, 2006
    2,706
    In fact, you'll find that when you remove the camouflage, the car appears much more compact !
    ohno, Garbageman, Caeruleus11 and 2 others like this.
  4. Senad
    Senad Formula Junior
    May 14, 2019
    476
    Kuwait
    Sanad Alibrahim
    appears, but is it really ?
  5. Shack
    Shack F1 Rookie
    May 2, 2005
    2,644
    Earth
    Not sure I agree on the seats - had CF sports seats in the 812 and the 812 GTS and have been super happy with them. Probably as I have quite bad lower back pain and the CF seats seem to support the lower back better.
    Bundy, Caeruleus11 and Frank_C like this.
  6. Frank_C
    Frank_C F1 Rookie
    3,026
    Whistling through the wheat field in Texas
    Frank
    Yeah, if you look carefully at all of the latest pics there is a lot of paddding, especially the roof and rear.
    F2003-GA likes this.
  7. ab08
    ab08 Formula Junior
    Aug 28, 2007
    496
    Comparing, from the side view, the F167 still in disguise, and the 812 Superfast, it is noticeable how the space between the beginning of the door and the front wheel is shorter on the F167.
    Furthermore, it seems that the rear axle is a little more advanced in the F167, almost close to the door and the B column, getting even closer to the front axle.
    The overall length and wheelbase are noticeably shorter on the F167.
    It also appears that the hood of the F167 will be lower than the 812.
    inox and 456-boy like this.
  8. DavidJames1
    DavidJames1 Formula 3
    Mar 6, 2010
    1,808
    Bangkok, Thailand
    Agree, I find the CF sports seats way more comfortable than the regular seats - especially notice this on long journeys.
    Bundy, Caeruleus11, Dubaicity and 2 others like this.
  9. babgh
    babgh Karting
    Dec 21, 2016
    198
    Is it just me or the rear windows are most likely to be similar to that of the 550/575m? The front looks nice in camo, I hope they didn't botch its face when they reveal the f167 next year
  10. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    8,492
    Bournemouth, UK
    Thanks for that. Your 812 seems to be on the heavy side.
  11. 4re4ever
    4re4ever Formula 3
    2,276
    Auckland/London
    Simon
    JasonSpidey, 635CSI, ohno and 4 others like this.
  12. omercan
    omercan Formula Junior
    446
    omer can
    WB
    550 2500 mm
    599 2751 mm
    F12 2720 mm
    812 2720 mm
    Forza Scuderia likes this.
  13. Soleith
    Soleith Karting
    Dec 30, 2020
    190
    Surrey, UK
    Just wait until F167 does away with the manettino and makes it a swipe gesture :eek:
    bamaman and Senna1994 like this.
  14. Maximus1973
    Maximus1973 Formula 3
    Oct 29, 2016
    1,541
    Not to mention braking hard before a corner..... that to me is the biggest downside of the 812. It feels lighter when gaining speed and through corners, but brake hard before a corner and you'll scare yourself easy. I had several "OMG" not so pleasant moments when I drove the GTS on track....
    Bundy likes this.
  15. Newjoint
    Newjoint Formula 3
    Jan 17, 2016
    1,483
    Looking at it critically- and assuming the cars are to identical scale in the photos (probably not)the front overhang is the same, windshield is set back a few mm, rear overhang is greater as the rear wheels are more forward. Not happy about more over hang front or back
    So wheelbase is smaller- probably indicating the car is also a bit narrower(good as the 812 is plenty wide) to keep the ideal wheel placement as square as possible and perhaps the overall car is a bit shorter (also good- maybe better handling and less weight)
  16. inox
    inox Formula Junior
    Oct 11, 2017
    617
    Wasn't it so that windscreen should be moved 4 cm towards the front axle? If so, then pictures don't quite match.
  17. omercan
    446
    omer can
    4re4ever I think you're on drugs
    bamaman, polishhammer83 and NGooding like this.
  18. inox
    inox Formula Junior
    Oct 11, 2017
    617
    Looking at the F167 pic, it appears to be taken near the rear of the car. This is visible e.g. inside the cockpit and particularly in the front brake disc. This may cause windscreen to stop earlier than it should. The other reason could be that bonnet still has a thick layer of camouflage.
  19. day355
    day355 F1 Rookie
    Jun 25, 2006
    2,706
    Almost 4 cm less between the front wheel and the windshield !
    ingegnere, ohno, F2003-GA and 2 others like this.
  20. U-Boat Commander
    1,332
    Not to mention the gasoline consumption, which is immense. I went through a half tank of gas on about 30 miles of mountain roads. Not kidding. I got to the end of the drive and had an oh **** moment when I realized I was close to empty.
  21. Senad
    May 14, 2019
    476
    Kuwait
    Sanad Alibrahim
    great!!!
    any more info regarding (some) overall dimensions
  22. Condor Man
    Condor Man F1 Rookie
    4,938
    Los Angeles
    Wow, 599 feels so much bigger than the F12 to me.
    May the Horse be with you
  23. 4re4ever
    4re4ever Formula 3
    2,276
    Auckland/London
    Simon
    Scale was done via the rims. The F167 has a lot of padding so the question is. Is it the full final body below if not that changes a lot but... the wheel base is different as is the windshield and roof. I think its going to be smaller all around, But not by a lot though.
    ryalex likes this.
  24. 4re4ever
    4re4ever Formula 3
    2,276
    Auckland/London
    Simon
    Sure am Type 1 Diabetic for 40 years with a Masters in Design.....
    There is a lot of factors that are still guess work with so much padding and not knowing if the final front and rear are on under all that padding.
    omercan and ryalex like this.
