812 Spider | Page 49 | FerrariChat
812 Spider
Discussion in 'F12/812' started by MalibuGuy, Sep 22, 2018.
  1. klinkman
    klinkman Formula Junior
    537
    Eric
    Congrats as well.
    Wonder who is going to get to the finish line first. ;)
  2. deltona
    deltona Formula 3
    Aug 7, 2009
    1,386
    Justin
    UK dealers have been given a list of ‘first customers’ for the GTS.
    Dealers require a £35k deposit by next Wednesday 18th September to secure those first cars.
    Criteria for these first cars is at least 812 ownership/order along with Portofino or Lusso.
    Dealer demonstrators mid 2020, first RHD customer cars end of 2020 early 2021.
    I’m in. :)
    JagShergill likes this.
  3. Michael Kulisz
    Oct 21, 2018
    11
    Mike Kulisz
    Also in on 812 GTS. Just confirmed my SF90 yesterday as well! Excited for everything Ferrari ATM, no better brand!
  4. jpalmito
    jpalmito F1 Veteran
    Jun 5, 2009
    7,448
    Le caylar (France)
    mathieu Jeantet
    Very interesting
    Thanks a lot.
    Just one question ,
    Because of all those future regulations, do you think it is plausible they will replace V12 front engine range with a V12 rear mid engine range ?
  5. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    No
  6. Maloja
    Maloja Karting
    Oct 19, 2016
    156
    I have also put in an order for an 812 GTS yesterday but I currently „only“ own a GTC4Lusso ;as well as an F12 but have no order pending for an 812SF.
    My dealer at Gohm in Germany told me it is certainly good that I currently own these two V12‘d ( had for a couple of months also an FF before the GTC4Lusso arrived) but it will be up to Ferrari to decide if it will be sufficient to get an effective 812 GTS allocation.
    What do you guys think in terms of allocation probability? Thanks!
  7. davide b
    davide b Formula Junior
    Mar 6, 2007
    442
    montecarlo
    davide
    From what I know Ferrari require a gt car, not specifically an 812
    635CSI likes this.
  8. Art_collector
    Art_collector Karting
    Jul 13, 2019
    113
    Do some one have a photo of the options of the grey 812 GTS?
  9. Ltfor3
    Ltfor3 Karting
    Oct 14, 2013
    167
    FL
    L.T.
    I am trying to get on the list and should know soon. I currently have a '17 Cali T SH and just sold a '15 458 Speciale. I also have an 812 on order for October/ November delivery. What are my chances?
    of2worlds likes this.
  10. REALZEUS
    REALZEUS F1 Veteran
    Feb 16, 2011
    7,705
    Bournemouth, UK
    Ferrari doesn't regard the 812 as a GT anyway. They are right, you know...
  11. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,286
    Austin TX
    My concern is the future sound/noise regulations with new testing procedure that must be tested using the loudest exhaust settings (so hybrid/ev mode do not apply, closed/vs/open exhaust values must always test with open exhaust valves so maximum noise is tested) are what is going to reduce the aural driving enjoyment. Interestingly, GPF helps reduce exhaust noise levels so Ferrari does not have any incentive from a regulatory standpoint to make the car (any they make) louder. "Hot Tubes" such as that in the F8 (and in use with many other manufacturers) where engine noise is piped into the cabin because the exterior exhaust sound levels are dramatically reduced will become prevalent in all exotics over the next few years, at least those sold in EU and due to homologation expenses for various exhausts it is quite unlikely a smaller company such as Ferrari will make different exhausts.
    That said, placement of engine in the chassis will not matter so moving the V12 behind the passenger compartment is not going to help solve any regulatory requirements in any way I can conceive of.
    I think it may be where there are no more V12s in regular production. Know this, the new sound regulations are ever tightening:
    And interestingly, the 812 with its 588 kW engine (800PS, 789bhp), at 6.5L is actually subject to the lowest sound requirement! 588/6.5 = 90.46kW/l, so the "<= 120kW/l" setting above applies! Versus the F8 with its 529 kW engine (710bhp) at 3.9L (529/3.9 = 135kW/l) is subject to the higher level (<= 160kW/l), how does that make any sense?
    So, the F8 can be louder than the 812 based on the above table!
    So Ferrari needs a high horsepower low engine displacement to dial into the sweet spot greater than 160kW/l, for instance, 800 PS engine using 3.6L displacement.
    All that said, a small V12 block, rear-mid-engine, making 800PS is unlikely, but, with combined output with a hybrid system then it could happen.
    But Leiters has already said no to hybrid, downsizing and turbocharging, so, a larger block V12 would seem to be only option (besides staying same size) but is subject to quietest noise regulations and, well, I doubt the V12 will continue as they would have to make it small. But, if they did decide to make a 3.6L V12 it would have to be rear-mid-engine because that is the only way electric motors can fit up front to drive the front wheels, no room for that plus an engine up front and they would need to do that to get more power because a 3.6L V12 with all the tricks, naturally aspirated probably could only make 450-500hp at the most.
    Tough decisions to be made, lots of forcing from EU regulations suffocating
  12. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,286
    Austin TX
    Interesting, are you working with MAG in Dublin OH? Did you happen to order your 812 this past April? Give them a call, but know this, MAG does not receive a lot of allocations so they are going to reserve those for their top clients, that is my presumption. Best to give them a call and get on the list now...
  13. Ltfor3
    Ltfor3 Karting
    Oct 14, 2013
    167
    FL
    L.T.
    I’m actually in FL most of the year and deal with Ferrari in FL. My sales guy is actually at the plant this week and we are touching base next weekend. I have updated my location. Thx.
  14. jpalmito
    jpalmito F1 Veteran
    Jun 5, 2009
    7,448
    Le caylar (France)
    mathieu Jeantet
    Thanks again , very instructive.
    We can only hope they will find a way ( technically) to let the glorious V12 in the regular range.
  15. F2003-GA
    F2003-GA F1 World Champ
    13,118
    Sunbelt
    Bro
    IMO Innotech sounds better
    Foxmod likes this.
  16. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,286
    Austin TX
    Agreed, but, appears completely impossible, at least on the exterior of the car (another reason the 812GTS has to be now, and quite possibly too late already because the exhaust sounds will be quiet per EU regulations
    As a comparison:
    https://www.counterspacegarage.com/blog/publications/these-stock-cars-fail-laguna-seca-sound-limit/
    excerpt:
    During the majority of track days held at Laguna Seca, cars whose noise levels are measured to be over the 90dB threshold get a mechanical flag for a sound violation.
    and:
    Many sports cars sold in the US market are already too loud for Laguna's sound limit in stock form. For example, all of the following models in showroom trim are known to get flagged at Laguna Seca for being too loud:
    • Ferrari 458
    • Ferrari F430
    • Audi R8
    • Lamborghini Huracan
    so, note, the limit for 2020 for the 812 is 70db, using the new testing procedure which does take a blend of constant speed plus wide open throttle to achieve its rating, all cars no matter what (at least made for EU) will become more and more quiet as these 'noise regulations' are implemented...
    see page 10 here for some details of how sound tests determine sound level:
    https://www.unece.org/fileadmin/DAM/trans/doc/2010/wp29grb/ECE-TRANS-WP29-GRB-52-inf07e.pdf
    of2worlds, Bundy and jpalmito like this.
  17. italiafan
    italiafan F1 World Champ
    16,121
    Stickbones Swagglesmith
    I’ll be keeping my 16M...guessing it to be around 200db! :D
    Maybe that’s why my tinnitus is getting so bad...worth.
    stavura, of2worlds, day355 and 4 others like this.
  18. klinkman
    537
    Eric
    While it’s true many of Laguna’s days are under a restricted limit, there are opportunities. One is coming up I will be attending with the 812 that is 103db. All is not lost
  19. sampelligrino
    sampelligrino Formula 3
    Apr 16, 2017
    1,156
    what a buzzkill. I can even try to force myself to understand the need for GPF as an emissions/environmental thing, but sound??? cmon
    Apparently regs are making EVs has some noise too, for safety purposes, FFS... can't wait for when all cars have to be 40.73db, or else....
    stavura, of2worlds, Bundy and 2 others like this.
  20. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,286
    Austin TX
    40 would be average decibel for inside a home with background noises, a/c, frig, etc...
    here's short list
    Average decibels (dB)
    Leaves rustling, soft music, whisper
    30
    Average home noise
    40
    Normal conversation, background music
    60
    Office noise, inside car at 60 mph
    70 <=== 2020 regulation for 812 ! averaged, not max, car can be louder at max volume but, must average out at 70dB!
    that's thru July 2022 and then it gets even quieter!
    'active noise cancellation' (ANC) will likely be required at that point
    Vacuum cleaner, average radio
    75
    Heavy traffic, window air conditioner, noisy restaurant, power lawn mower
    80–89 (sounds above 85 dB are harmful)
    Subway, shouted conversation
    90–95
    Boom box, ATV, motorcycle
    96–100
    School dance
    101–105
    of2worlds and Bundy like this.
  21. LandandcarsAZ
    LandandcarsAZ Karting
    Jun 14, 2018
    179
    Scottsdale AZ
    Robert
    Novitec will be making a killing with these regulations.
    JTSE30 likes this.
  22. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,310
    Can anyone confirm the exterior and interior colors of the 812 Spider featured in the official video?
    To my eye the exterior is the new launch Grigio GTS and the interior is ciocolatto with contrasting stitching maybe silver?
    Anyone know if the central tunnel was in Nero or ciocolatto? And if there was an accent color line?
    The seat trim looks to be standard full electric.
    Dash and carpets are Nero.
  23. 4_Eff_Sake
    4_Eff_Sake Formula Junior
    Jul 30, 2016
    761
    Australia
    Scott
