812GTS 2021. Clock adjustments and start stop engine | FerrariChat
Discussion in 'FF/Lusso' started by Scott4503, Jun 17, 2021.
  1. Scott4503
    Scott4503 Rookie
    Dec 1, 2014
    31
    seattle
    scott halliday
    #1 Scott4503, Jun 17, 2021
    812GTS. 2021
    Two questions
    How the heck can you change the clock??
    And
    Is there a way to turn Off the engine turn off switch. Like when you’re at a standstill??
    thank you. I appreciate any help
    and why does Ferrari make the clocks soooo difficult to adjust??
    SAFE4NOW likes this.
  2. gilly6993
    gilly6993 F1 Rookie
    Aug 20, 2009
    2,555
    Longmeadow, MA
    Eric
    LMAO. Yea it’s crazy. The clock adjustment is in the settings to the left of the steering wheel. It’s easy and annoying it’s not in the main screen….
    The Lusso has a start/stop off switch in the controls by the rear view mirror/ interior lights….not sure how the 812 is…
    Caeruleus11 and SAFE4NOW like this.
  3. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,822
    Dallas Texas
    If you know you know
    While there is no way that I am aware of to turn Start/Stop off permanently, you can press the button located on your dome light each time you start the car. It will stay that way ( off ) for the remainder of your trip!
    ( Unless you turn it back on again )
    Steve
    p.s. The button is the one with the " A " with an arrow circling it, with the word " off " underneath it.
  4. Scott4503
    Scott4503 Rookie
    Dec 1, 2014
    31
    seattle
    scott halliday
    so how to get the left screen to activate?
  5. hs355
    hs355 Karting
    Feb 1, 2014
    124
    It’s in the settings, but you have to stop the car to activate the menu. You won’t see it when driving.
    Caeruleus11 likes this.
  6. Dubaicity
    Dubaicity Karting
    Nov 21, 2013
    238
    Germany
    Clock setting:
    If you can`t see the setup menu on the left because of automatically activated parking sensors - turn off the parking sensors by pressing the parking sensors button.
    If there is still the speedo or something else seen on the left screen without the possibility to enter the setup menu - press the return button on the left side to go back to the main menu.
  7. RamsHmb
    RamsHmb Formula 3
    1,220
    San Francisco
    James
    Too funny. Had the clock off by an hour for several months until I figured it out last week. Good luck
  8. Scott4503
    Scott4503 Rookie
    Dec 1, 2014
    31
    seattle
    scott halliday
    I’ll try it. What a yearly pain. No one can like this feature especially if you drive these a lot. Thank you all though!
  9. shifter
    shifter Formula Junior
    Apr 8, 2004
    625
    Danville, Ca
    Joe
    The start/stop bugs the hell out of me, hope someone can figure out a way to permanently disable.
    R J and Gh21631 like this.
  10. italiafan
    italiafan F1 World Champ
    16,121
    Stickbones Swagglesmith
    I wonder what the environmental impact is of having start/stop on Ferrari V12s per year.
    I’d guess it amounts to the amount of burgers sold at one McDonalds for one day per year.
    Thecadster likes this.
  11. Scott4503
    Scott4503 Rookie
    Dec 1, 2014
    31
    seattle
    scott halliday
    Thanks everyone. Got er done! It’s still more complicated than it should be. But it’s a pretty great ride so I can survive
  12. JackCongo
    JackCongo Formula Junior
    890
    Jacques
    Did you manage to get permanently rid of the stop & start feature ?
  13. Gh21631
    Gh21631 F1 Veteran
    9,053
    East
    Finally got to drive my car, the start/stop thing sucks. It took me a while to find the dang button. I had to pull over and look around.
    The most awful feature ever, all of my other cars do not require me to hold the button every time I get in.
    Solid State and Thecadster like this.
  14. ryalex
    Aug 6, 2003
    25,905
    Las Vegas, NV
    Ryan Alexander
    What I don’t understand is that I thought that the starting was what wears the engine the most. Maybe Pennzoil oversold that?
    Gh21631 likes this.
  15. SecretSquirrari
    SecretSquirrari Karting
    Dec 3, 2020
    118
    Chicagoland
    J
    Starting after the car has sat for a while, allowing the oil to drain to the bottom of the crankcase, is a time of maximum rate of wear. Some cars offset that by firing up an electric oil pump when the car door is opened or it has other reason to believe the car will be starting soon.
    But restarting a warm engine that was running recently will not introduce significant wear on the engine. Whether or not the starter motor can handle the "abuse" depends on how they engineered and built it (which in turn depends on whether they thought most people would leave Auto Stop/Star on or would turn it off most or all of the time).
    ryalex likes this.
  16. JackCongo
    890
    Jacques
    Same thing here in my GTS . I hate this thing.
    I also have the start/stop feature on my F12tdf but for an unknown (good) reason I turned it off once and that was it!
    ryalex and Gh21631 like this.
  17. JackCongo
    890
    Jacques
    If anyone finds a way to turn it off permanently, please share!
  18. R J
    R J Formula Junior
    May 17, 2017
    602
    But any benefit cancelled by the car batteries that need to be replaced more frequently by those that actually utilise start stop rather than disable before setting off. Am not confident the battery will survive a full use of the start stop. The battery won’t even survive 9 days without being on constant trickle charger.
    italiafan likes this.
  19. Gh21631
    Gh21631 F1 Veteran
    9,053
    East
    Access to the OBD port will likely provide this option. It should be a simple setting to change.
  20. Caeruleus11
    Caeruleus11 F1 World Champ
    11,540
    I think the one time setting on start stop was allowed in markets outside the US, but now those markets have moved to the the US rule which has always required the start stop to be designated at each drive. It’s annoying, but its also near he door lock button, in these cars- so for me its just part of the start up procedure.
    R J, RamsHmb, JackCongo and 1 other person like this.
  21. RamsHmb
    RamsHmb Formula 3
    1,220
    San Francisco
    James
    Yep…press starter for car, turnoff auto, next start stop off, and finally bumpy road mode. Sometimes I will forget a step but I remember it’s four steps and back track
    R J, ryalex, italiafan and 1 other person like this.
  22. Solid State
    Solid State F1 World Champ
    10,511
    Maximus Decimus Meridius
    Any unnecessary engine wear on a V12 is significant to me. The worst concept ever conceived. Serves no benefit.
    RamsHmb, R J, ryalex and 2 others like this.
