812GTS electrical fault | FerrariChat
Discussion in 'F12/812' started by GaryC1008, Mar 11, 2022.
  1. GaryC1008
    GaryC1008 Rookie
    Sep 15, 2020
    9
    London
    Gary C
    Hi guys,
    Had the front bumper off my 2022 812GTS to fit some carbon lips, back together and started car.
    I now have literally every failure known to man on the screen - E-diff, power steering, engine control unit, rear wheel steering, F1-Tac,Manettino etc.
    Car will engage first gear but I have no reverse.
    Before I call Ferrari embarrassingly, any ideas? I have tried disconnecting battery.
    Many thanks!
    Gary
  2. jamie140
    jamie140 F1 Rookie
    3,238
    GTA/Marco Island, fl
    Jamie
    Battery low?
    350MH83 likes this.
  3. GaryC1008
    GaryC1008 Rookie
    Sep 15, 2020
    9
    London
    Gary C
    My first thought, but its all good voltage wise. Running we have 13.8-14+v and engine off showing a good strong 12v
    I double checked I hadnt left anything unplugged, but it was only the parking sensor multi plug.
  4. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,575
    Grant
    Clutching at straws, it might be worth locking and leave a few mins. and unlocking, do it a couple of times, that sometimes fixed glitches on older cars.
  5. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,538
    Austin TX
    these might be useful:
    https://static.nhtsa.gov/odi/tsbs/2020/MC-10180798-0001.pdf
    https://static.nhtsa.gov/odi/tsbs/2019/MC-10162578-9999.pdf
    GaryC1008 and klinkman like this.
  6. Alcav5
    Alcav5 F1 Rookie
    4,070
    Scarsdale, NY
    Al
    I'll offer my 812SF experience
    After driving the brand new car with a 100 or so miles , after a few hours during a road trip I got all sorts of warnings and it went into limp mode , it wouldn't shift properly (I can't clearly remember what else happened). Even after shut down and restart it didn't clear but I was able to get home.
    Upon repair service manager told me that there is a battery cut off switch , it wasn't fully closed and that was it.
    I owned the car for a year and never had that problem again.
    fwiw
    good luck
  7. GaryC1008
    GaryC1008 Rookie
    Sep 15, 2020
    9
    London
    Gary C
    Thats interesting! Do you happen to know where the switch is?
    thanks
  8. Alcav5
    Alcav5 F1 Rookie
    4,070
    Scarsdale, NY
    Al
    No , it was done at the dealer though I got the visual in my head that it was at the battery post.
    I'm sure someone here knows better than me . You could always pull up a diagram for that part of the car if they're still out there on the web (ricambi?)
  9. ShortShifter'458
    Apr 25, 2012
    3
    Hyderabad, India
    A youtuber is facing same issue with his 3 month old 812 GTS which has a novitec exhaust system. Unfortunately ferrari is voided his warranty and suggesting to replace the ECU to fix this issue. More on it here:
  10. 350MH83
    350MH83 Formula 3
    Jul 11, 2014
    1,173
    Denmark
    Max
    The cut off switch is on the negative terminal of the battery. It's a grey lever.
  11. 250boano
    250boano Formula Junior
    Apr 27, 2022
    450
    Europe
    DD
    A video will be coming out shortly to put the record straight on this car
