'82 308 GTSi can't shift into 1st gear | FerrariChat
Discussion in '308/328' started by aubreysterling, Oct 3, 2009.
  1. aubreysterling
    Sep 30, 2009
    1
    I just bought this car last week. It had no problems shifting for about 100 miles. Now 1st gear is hit or miss. Sometimes I can get it to stay, but it usually pops out and if I try to hold it while letting up the clutch, it grinds. All other gears work fine, but it sometimes tries to pull forward in reverse. In the meantime, I've just been using 2nd gear from a stop, but I figure this is going to wear the clutch out.
    I've read a ton of threads, but I can't figure out what exactly is the issue (gear alignment?). All seem to be beyond what I am capable of fixing myself. I was hoping to get a few more miles before putting it in the shop, but oh well. How much is this going to cost?
  2. ragtop1
    ragtop1 F1 Veteran
    5,245
    Ontario
    Larry Warren
    If you are lucky, it may be a linkage adjustment issue that can be aligned. Otherwise, an engine out service and transmission investigation is in order. Gears, syncros and bearings.
    Then you get to check out many more issues that will need addressing with a clean look at an empty engine bay.
    Too hard to estimate a cost at this point. Depends on the condition of the tranny. Once it is opened up, may as well replace any suspect or worn parts such as 2nd gear syncro, to save on future mishaps that will result in another tear down.
    Most of your costs here is labor.
  3. jeffQV
    jeffQV F1 Rookie
    Feb 13, 2004
    2,976
    NZ
    jeff
    Hopefully as simple as this. I lost first n reverse a couple of weeks ago, turned out to be the selector forks inside the gearbox, they can work lose. A simplish fix, my mechanic sorted it out easily and not too many $$$, good luck!
  4. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    There are two rubber Silentblock bushings in the shift linkage, one of which sees both heat and usually oil. At least that one is ready to replace if it is original no matter what. Verrell sells a superior bushing to replace the OEM. I would start there and then do the shifter alignment. That requires dropping the tranny pan, but is apparently easy. (That's on my to-do list still.)
    Getting the wrong gear in the wrong gate slot is way more likely to be an alignment and bushing issue than anything else.
  5. kerrari
    kerrari Two Time F1 World Champ
    Oct 22, 2004
    24,041
    Coolum Beach AUSTRALIA
    Karen H.
    +1 on this.
  6. Jet Lag
    Jet Lag Karting
    Dec 6, 2003
    173
    Seattle
    Robert Bangs
    #6 Jet Lag, Oct 4, 2009
    I would imagine several things could cause your problem. My '79 308 started off by sometimes going into 3rd instead of 1st, then had a hard time getting into reverse, and finally jammed to the point that I would have to take the gate off to release pressure enough to get the stick shift to move. It turned out to be the rear bushing in the shift linkage - #28 of below. Easy enough to check; a real b!t@h to replace, but it solved my problem.
  7. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
    #7 stekkefun4, Oct 5, 2009
    I have the same problem since I had a service done by an independent old timer garage in Brussels. I have a Mondial QV, shifting to first 1 in 10 times doesn't work. They disassembled the gearbox sump to replace the seal. The problems started immediately when I got my car back. Chances are they didn't put one of these 3 balls back in place - see picture. This will cause the lever to 'miss' a gear from time to time because the spring just underneath pushes the ball up to keep the gear in place. Known problem, simple solution but with some work.
