82 308 GTSi - Fuel pump runs when key turned to position 2 | FerrariChat
Discussion in '308/328' started by PorscheSki, May 25, 2014.
  1. PorscheSki
    PorscheSki Rookie
    May 3, 2014
    12
    Using the search function on FerrariChat and the Mondial 8 WSM I have been troubleshooting the cause of the fuel pump running when ignition is turned to position 2 but car is not running or being started.
    I believe I have confirmed that the airflow sensor safety switch is not working. Steps I have taken:
    1. Remove fuel pump fuse and verify that fuel pump does not run. Fuel pump did not run but does run with fuse in place.
    2. Visually verify that airflow sensor plate is closed when engine not running by removing the air box. It is closed.
    3. Unplug cable to airflow sensor safety switch and verify that fuel pump still runs in ignition position 2. It still runs.
    4. Jumper cable to simulate a closed airflow sensor switch. Fuel pump no longer runs when ignition turned to position 2. Pulled out jumper and fuel pump starts running.
    Conclusion, I believe the safety switch is not going to a closed state when airflow sensor plate is in full closed position.
    Some questions for the group:
    1. Do you agree with my conclusion?
    2. What are possible causes for this failure?
    a. mechanical geometry changed
    b. dirty contacts inside assembly
    c. other
    3. What are possible fixes?
    a. replace just the switch?
    b. clean contacts with carb cleaner/other without disassembling unit
    c. clean contacts with disassembly required
    c. send unit for rebuild
    d. other
    Since the airflow sensor plate is fully closed and the engine runs fine throughout all revs/conditions it would seem that the only thing wrong is the safety switch mechanism. If this is the case, fuel will not go to engine until airflow sensor moves out of closed position even though pump is running when ignition turned to position 2. If I am correct about this, I have a couple more questions:
    4. Would pressure just keep building until something gives or is there a flow back to the tank?
    5. What would be the safety risk of operating in this state?
    Disclaimer: I am brand new to Ferrari and the 308, but I have a fair amount of background working on Porsche and BMW cars from the 80s. I'm a self trained "mechanic" and do this stuff as a hobby. I apologize if I am missing some steps and I did look for answers to these questions first but haven't been able to find them after a reasonable amount of time.
    Thank you for any assistance.
  2. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,149
    SanFrancisco BayArea
    1983 US 308 GTS QV
    I believe your point 4 provides full diagnostic confirmation that your switch is not working. I learned about this switch when I discovered mine was unplugged. My car did what yours does. I plugged it back in and restored normal vehicle function.
    As I understand it, it circulates back to the tank on a QV using a pressure regulator valve, so there is no build up of excess pressure.
    As I understand it's function, it is solely to shut-off the fuel pump in the event of an accident or roll-over. I have reconnected the switch. Not the best thing to mess with.
    Me too, so read my ramblings suspiciously.
  3. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,557
    NY/SC
    David
    This was the condition of my 328 for a few years until my mechanic sorted it out.
    #4 Believe there's a failsafe there for such a circumstance, but if there's a problem with that #5 the safety risk is your sh** could blow up, or at least catch fire and THEN blow up. That's what my mechanic warned me was possible anyway. Until he fixed it, I just dealt with it by not leaving the switch on w.out the engine running.
  4. Bell Bloke
    Bell Bloke Formula 3
    Dec 6, 2012
    1,839
    Guys were is the airflow sensor safety switch on the car?
    Cheers BellBloke
  5. PorscheSki
    PorscheSki Rookie
    May 3, 2014
    12
    Thank you for the replies.
    I read that about the QV but I couldn't find a similar statement regarding the 2v KJet cars.
  6. PorscheSki
    PorscheSki Rookie
    May 3, 2014
    12
    #6 PorscheSki, May 26, 2014
    The connector sits next to the fuel distributer toward the back right corner of the car just to the left of the air box/airflow sensor plate. I believe it connects to some type of contact points that measure the height of the airflow sensor arm. It is hard to tell from the diagram exactly how it works.
  7. Bell Bloke
    Dec 6, 2012
    1,839
    Many thanks Porscheski, and just to recap what does this actually do ie why does it cut the fuel pump, is it just to stop fuel being pumped in the event of an off engine or a crash?
  8. PorscheSki
    PorscheSki Rookie
    May 3, 2014
    12
    That is my understanding.
  9. PorscheSki
    PorscheSki Rookie
    May 3, 2014
    12
    I have now confirmed via the book, Bosch Fuel Injection & Engine Management: How to Understand, Service, and Modify by Probst that the fuel distributer in all K-Basic and K-Lambda systems includes a pressure regulator that sends fuel back to the tank when maximum pressure fuel pressure is reached.
    I could not find any description of the actual mechanism of the safety switch or photos of the inside of the downdraft AFM assembly used in the 1982 Ferrari 308 GTSi application.
    So the big questions for me at this point are:
    Can I attempt to clean it in place with some carb cleaner without causing any other damage?
    Should I just leave it as is until the need to have the AFM rebuilt due to operational issues?
    Should I have the AFM rebuilt and recalibrated and fix the safety now even though the AFM is otherwise functioning correctly?
  10. Steve Magnusson
    26,826
    #10 Steve Magnusson, May 26, 2014
    See Fig 9 Sez A-A on page D10 of the 281/83 Mondial8/QV WSM (which you can download from All Ferraris).
    Here's a shot of the internals showing the safety switch hardware components from Robz328:
    It also serves as the rest stop for the airflow plate motion (i.e., when the airflow plate arm pin hits the rest stop plate 14, it completes the circuit) -- if the rest position for your airflow plate is wacko, that would be a clue something isn't right mechanically, but, if that's OK, more likely there's a bit of crud/corrosion allowing mechanical contact, but not electrical contact. Some additional figures for the rest position adjustment that also show the safety switch hardware in cross-section:
  11. Bell Bloke
    Dec 6, 2012
    1,839
    Wow nice shot Steve, many thanks for that ;-)
  12. Steve Magnusson
    26,826
    Don't thank me (I'm just the "Librarian") -- thank Robz328. AFAIK, he's the only one who's posted actually going inside the airflow metering device (which is a huge projected to be avoided ;)).
    It's all about post-crash safety and K-Jet having a rat's nest of small, breakable fuel lines under very high pressure. In a bad crash, very likely that there could be a breach in the K-Jet system, and the ignition key would still be in the "on" (pos II) position spraying (atomized) fuel everywhere.
  13. PorscheSki
    PorscheSki Rookie
    May 3, 2014
    12
    Thank you Steve. I had looked at the diagram in the WSM you mentioned but I wasn't "seeing" how it worked. The photograph you just posted filled in the gap for me. I am going to try some air intake cleaner and see if I can get a clean contact area.
  14. Steve Magnusson
    26,826
    So your airflow plate rest position is OK?
  15. Bell Bloke
    Dec 6, 2012
    1,839
    Actually reading your thread just made me realise that I have the same issue. I've just fixed mine:) It turned out to be a bad connection at the socket on the metering. unit.
    The pump works when there is no connection and stops when the connection is good.
    Not what you would expect.
    All the best Bell.
  16. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,149
    1983 US 308 GTS QV
    I discovered that mine was only loosely put on when it fell off when I bumped it. It reattached with a firm click.
    Without it attached, it is interesting how, if you pause the key at "run" to let the fuel system pressure up, the engine barks to life in less than a single revolution. All the time cranking with the switch connected is just the time it takes for fuel pressure to build sufficiently to open the injectors. Not like I plan on unplugging it again, but interesting nonetheless.
  17. PorscheSki
    PorscheSki Rookie
    May 3, 2014
    12
    I resolved the problem with air intake cleaner spray and a 3mm allen wrench wrapped with white cloth. Holding the plate down I pointed the red tube on the spray into the area where the contact should be made to close the circuit. I then used the cloth on the allen wrench to gently rub around on the surfaces. It came out with lots of black "dirt" on the cloth. I did this until I was no longer getting any "dirt" on the cloth. The switch is now working, keeping the fuel pump off when in ignition position 2.
  18. PorscheSki
    PorscheSki Rookie
    May 3, 2014
    12
    Glad to hear. I think it works that way for ease of troubleshooting fuel injection problems. Since for many checks you need the fuel pump working to pressurize the system but without the engine running. By disconnecting the connector at this safety switch a technician has a very easy way of getting the pump to run without turning over or running the motor.
  19. PorscheSki
    PorscheSki Rookie
    May 3, 2014
    12
    Sorry Steve, I missed this question. Yes the plate mechanism appears to be correctly adjusted.
  20. Steve Magnusson
    26,826
    Thanks for the data point -- I believe that yours is the first reported/confirmed case of bad electrical contact between the pin and plate being the issue (but, like you guys have noted, since it doesn't cause an operational problem, it probably rarely gets addressed by Owners).
  21. Ehamilton
    Ehamilton F1 Rookie
    2,644
    Durham, NC; USA
    Eric Hamilton
    In my case, the problem is in the electrical connector in the wiring harness; the plate switch is doing the right thing, as confirmed with a multimeter.
