82 308gtsi clutch,locking ring nut removal | FerrariChat
Discussion in 'Technical Q&A' started by 82 308gtsi, Nov 7, 2006.
  1. 82 308gtsi
    82 308gtsi Rookie
    May 12, 2004
    9
    try to remove the locking ring nuts from gears so I can remove bell housing and replace the clutch. Exactly what kind of force is 180 newton-meters? This is the force needed to apply on this nut in order to remove it. I have used all my muscle strength possible and nothing happened. Is air impact wrentch the only way to do it? And should I have a pair of new nuts ready ?It looks like after I am done with them,both nuts will not be in good shape.
    thank you
    gary
  2. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,579
    San Carlos, CA
    Mitchell Le
    Bend, or cut the tabs back from the locking nuts. Make sure all is clear, and then use a 1/2 breaker bar ( a long one ) on the nut. It is right handed so lefty is loosy. 120 foot lbs is what it is, but it takes much more to break it loose.
    I have air impact wrench so I just zap it off with an ingersol rand gun.
  3. Rifledriver
    37,108
    .7233 x 180 = lbs. ft.
  4. Rifledriver
    37,108
    You speak of 2 nuts? Are you planning on removing the top one? It does not need to be removed and every destroyed clutch shaft and gear I have ever fixed is because someone removed that nut needlessly. Leave it alone unless you need to replace the clutch shaft, gear or bearing.
  5. jwise
    jwise Formula Junior
    Apr 2, 2003
    781
    Portland Maine
    Yes- an impact wrench is needed,
    Yes- only remove the lower ring nut
    Yes- replace with new ring nut, and use some loc-tite
    Yes- well, I just felt like typing "yes" again
  6. Verell
    Verell F1 Veteran Consultant Owner
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Also:
    Yes, it's best by far to use an air impact wrench.
    With a long bar you've got a good chance of tearing up the nut AND your big $$ ring nut socket. The impact wrench's snap action breaks the nut loose with out there being time for things to bend due to the force being applied for a long time.
    If there's just no way to get an air impact wrench, then try putting a substantial amount of tension on the breaker bar, make sure the socket is firmly seated on the nut, & smack the breaker bar about in the middle with a fairly large hammer. Be sure to keep the tension on the while. Again, the idea is for the impact to break the nut loose, not the steady state force.
    I've got about a 2-lb short handled hammer that I used to use.
    Then there's the old trick of wedging a piece of 4x4 between the end of the handle & the floor & lowering the jack, letting the weight of the car apply the force. Just make sure there's no way for the car to slip off of the jack. However, you're still back to lots of force slowly applied.
