82 GTBi Restoration/EFI Conversion | FerrariChat
Discussion in '308/328' started by chrisrpi02, Oct 24, 2024.
  1. chrisrpi02
    chrisrpi02 Rookie
    Mar 29, 2015
    13
    CA
    Chris
    Hello, I've had a few posts with a some questions but thought I could share more of my project and also see if anyone wanted to go in on a purchase of injector adapters I plan to have made to convert the 2 valve manifold to accept EFI injectors.
    I purchased a 1982 GTBi US spec that hasn't run since 1986 and only has 7900 miles, so the first thing I did was pull the engine apart :) I am pretty far past that now though, I have the car mostly ready for the engine to be reinstalled once I get the block and heads back from the machine shop. I'll post some pictures of progress over the past few months.
    Car delivery
    everything was there and all original except for some old body work on the passenger side that looks like was prepped with 80 grit before it was painted. Engine sat with coolant oil, fuel etc in it since 1986.
    got the engine out and had to make some pullers to get the heads off, drilled some holes in Home Depot C-Channel and finally got the heads off.
    with the engine out i rebuilt all the suspension and brakes
    Suspension I replaced bushings with poly bushings, and the thrust bearings on the wheel side and had the a-arms powder coated. I also rebuilt the rear calipers and replaced the front calipers with the replacements from Superformance. The cost to rebuild myself would have been the same as new calipers so went with new. Though the original metal brake line fitting bottomed out on the hex head before it was seated so I had to make new brake lines also with extra long fittings.
    Had to get creative with threaded rod and odd size pipe to get the suspension bushings out, I used the press in style rather than the weld in.
    I also installed QA1 coil overs with the "Paper Weights" and had the rotors turned.
    Still need to add the "USA" stencil back to the upper a-arms otherwise brakes and suspension done :) at least enough for the first drive! I also got the Superformance 16" wheels in gold.
    While the engine is out I replaced the heater core hose in the sill and the brake booster hose.
    and all the hoses underhood
    I'll have a bunch of left over Gates green stripe5/8 and 1/2 hose when done, not quite there yet!
    Getting ready for the engine to be back I replaced the shift shaft seals and added the oil pan baffle and drilled the hole in the shift shaft blind pilot (though it seems there is no consensus if it actually does anything figured it was easy to do and can't hurt!) and replacing all fasteners when I put things back together, mostly from Belmetric.
    I think the car is ready for the engine, cleaned everything up, repainted the tanks, new hoses
    Ferraripilot, rwbolt1 and Frisky like this.
  2. chrisrpi02
    chrisrpi02 Rookie
    Mar 29, 2015
    13
    CA
    Chris
    ran out of space for Pictures!
    engine bay ready for the engine
    Now for the engine work - I got 10.5 CR JE pistons and the 1700402 sport performance cams from Cat Cams. Had the cams made with the original air pump drive end so that i can install the air pump to pass visual smog here in CA. Also got Magnaflow muffler and two cats that are CA approved with a CARB EO. still need to have the exhaust welded up once I get the engine in.
    Here is my plan for the EFI -
    I plan to have these adapters made (probably at Xometry or something similar) that thread into the bosses on the manifold and accept Bosch EV14 injectors.
    the adapter threads into the stock manifold and uses shims under the adapter so that it is clocked properly. The threads in the manifold ar einconsistent so a single design won't work in all locations. the shims will space the adapter up slightly so that the orientation is correct. here is an example with a few I 3D printed
    I am going to use Swagelock fittings on the top that mate to a pipe thread and the top adapters i purchased from here: https://billet-speed.com/products/small-fuel-injector-top-hat-only-ev-14-and-pico
    Then I am using 3/16 SS pipe and will bend it to look like the original plumbing to a manifold from McMaster, need to get the engine all together so I can make the SS fuel lines.
    The injectors I am using are: https://finjector.com/eng/ev14_injector_12_ohm_338cc_c20_jetronic_ev1_o_o_34_mm_short_long_spray_end_bosch_0280158038-p-2101-185
    These are Bosch EV14 PN 0280158038 that are 347 cc/min with a 20° cone pattern and extended tip. The tip allows the injector to reach to the end of the hole that the mechanical injector normally fits in so it shouldn't spray on the wall of the manifold, at least not as bad as something with a short tip!
    here is the injector in the manifold
    The adapters are about $40 each if I only have 8 made but price comes down if more are made if anyone is interested!
    I am making a cam sensor adapter also but I need to select the ECU I am going to use first. Narrowed down to Link XtremeX or ECUmaster EMU Pro. I like that the EMU pro has Lambda controllers built in, can drive coils directly and their software uses Tau-X for fuel enrichment but I think Link is a bit more polished! Has anyone used either of them?
    That is about where I am currently, anything else I should replace while everything is apart?
    Chris
    Ferraripilot and Frisky like this.
  3. chrisrpi02
    chrisrpi02 Rookie
    Mar 29, 2015
    13
    CA
    Chris
    One more thing - does anyone have a used head gasket they don't need anymore? the machine shop I am using apparently threw theirs away (they just moved locations) and need one for the torque plate to do the final honing on the cylinders.
  4. bjunc
    bjunc Formula Junior
    Jun 18, 2023
    445
    Miami, FL
    Robert
    You might be interested in the EFI conversion I did on my Boxer ('83 BBi):
    https://www.ferrarichat.com/forum/threads/efi-boxer.687781/
    Lots of similar challenges to tackle; which often led to a combination of cut/bent parts from SendCutSend, as well as 3D printing.
    I initially went down a similar path of putting EV14 injectors in custom bosses. The manifolds are different, but a similar idea. I considered a top-hat design like you have, but eventually went with a rail. I believe there's another 308 EFI conversion in the works using a top-hat to AN fitting:
    https://www.efihardware.com/products/3378/injector-adapter-4an-with-stainless-steel-retaining-clamp
    I also 3D printed a distributor cap that I used as a cam sensor. Being a flat 12, I have fewer ECU options. I went with a Motec 150.
    Once the initial EFI conversion was finished, I converted the dual throttle body / long runner manifolds into a ITBs; which required custom stubby intake manifolds. I designed them in Fusion 360 based on the BBLM manifolds (weber carbs cut in half), printed prototypes on my Bambu X1C, and then had them printed in aluminum via CraftCloud (much cheaper than Xometry or Protolabs).
    Good luck. It's a lot of work, but I have zero regrets having done the conversion.
    Ferraripilot likes this.
  5. Dr Tommy Cosgrove
    36,426
    Birmingham, AL
    Tommy
    What is the chassis number?
  6. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,846
    Atlanta
    John!
    Good stuff, really glad you're getting it on the road again. Any other internal mods?
  7. chrisrpi02
    chrisrpi02 Rookie
    Mar 29, 2015
    13
    CA
    Chris
    @Dr Tommy Cosgrove vehicle is number 38691
    @Ferraripilot internal mods are the pistons, cams, also performance valve springs and ti retainers from Superformance and the oil baffle. I think that is it!
    @bjunc great thread on the BBi! Only made it a few pages so far but you have very similar targets to mine. Want to keep the stock look and have all mods be reversible. I am surprised the injectors are slightly different installation, would have expected Ferrari to have some commonality!
    Have you seen any issues with using the cam for crank and cam triggers? I don't have a crank trigger plan yet... I like your path or adding something to the flywheel and using the stock pickup locations. I am a little hesitant on the cam option due to potentially less accuracy due to half speed and belt driven but it is what drove the distributors originally! And accuracy on injector timing is not critical...
    I am also deciding between tefzel wiring or using one of the pre made harness pigtails, depends on ECU choice, it's nice to have pre terminated wiring in multiple colors and labeled but none of it is tefzel.
    I have to finish the whole thread, only on page 3!
  8. Dr Tommy Cosgrove
    36,426
    Birmingham, AL
    Tommy
    Hasn't run since 86?
    Wonder why someone would park a 4 year old Ferrari and no one touched it again? Any history on that? Just curious.
  9. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,731
    The twilight zone
    I've never .messed the ecus you're looking at but they both look fine spec wise. I know I've read several here use link and are happy. I use enginelab and love it but it's not for everyone
    I think the tua-x think is probably over rated. OEMs really need good mixture control to meet emissions targets... the rest of us can err on the rich side and never give it another thought
    I did mine with tefzel... i break stuff and that is more forgiving
  10. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,322
    Dumpster Fire #31
    SMG
    It's always neat to see other designs and how they tackle EFI on the 2V. Very cool.
    The 2V has always been a real pita with injector conversion, the threaded boss, the angled ports. Have to use custom bent fuel lines for each injector. Then tie it all into a manifold to supply fuel.
    The QV simplified so much that it's a slam dunk in comparison.
    Project looks very good!
    Gotta love the Advent of 3D printing and mfg to speed things up.
    My preference is Link ecu's. Simple, easy and loads of tweaking with an intuitive to me gui.
    350HPMondial likes this.
  11. Dr Tommy Cosgrove
    36,426
    Birmingham, AL
    Tommy
    My only fear with anything programmable retrofitted to these things is just that. It's a program and finding someone that can help with it if/when it goes south.
    Stock they are simple and dependable. I have a Scirocco with Electromotive driven ignition and fuel injection and there is only ONE person, in his 80's, here in town that can talk to it with a laptop and he has had to reset it twice in the past 10 years. For unknown reasons (he says maybe voltage spikes, I dunno) the damn thing has just gone back to some baseline program. It runs great when it works and it is working fine now but if it fails again and he is dead, what do I do? Electromotive is gone. I have literally lost sleep worrying over this.
    I would love to play around like this with my QV and Alfa Spider (82 with Bosch) because of the performance increases I have seen with my VW but the problems I have had spook the hell out of me.
    LE06 and Ferraripilot like this.
  12. Ferraripilot
    May 10, 2006
    17,846
    Atlanta
    John!
    Get with him and learn how to reset the rig yourself!
  13. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,731
    The twilight zone
    I kind of like the thought of the ecu dying....it means its way past time for a better one :p
    Seriously, kind of the opposite of worrying about part is NLA...wait, you mean I NEED to upgrade?...how sad :)
  14. Dr Tommy Cosgrove
    36,426
    Birmingham, AL
    Tommy
    I bought a cheap laptop at best buys and downloaded the program so I'm good there. I called him and he broke his hip and he cannot get around very well at the moment.
    But, yes, that is exactly my intention.
  15. bjunc
    Jun 18, 2023
    445
    Miami, FL
    Robert
    Short answer is that I haven't seen any issues at all using the cam for the sync/ref sensors. I was a little concerned at first, but it's very easy to see the signal and how little jitter there is between what the ECU expects, and what it actually sees. A proper crank sensor is technically better, but using the cam is so much more accurate than the mechanical (rusty spring) advance that it replaced. As far as I'm concerned, I have much bigger fish to fry than trying to shave a millisecond off the timing calculation.
    Regarding wiring, I would go for the Tefzel if you can swing it – along with Raychem DR25 heat shrink. That said, it's an expensive commitment to purchase proper cutting, stripping, and crimping tools for the various terminal types, so I wouldn't blame you for just going with a pre-terminated harness.
    Let me know if there's anything you'd want to know about how I did mine. Good luck!
  16. bjunc
    Jun 18, 2023
    445
    Miami, FL
    Robert
    Just my 2c on the obsolescence of EFI hardware, but I felt that CIS was even worse in this regard. I personally find it easier to find a "tuner" (or learn it yourself) than it is to find a qualified CIS technician (or learn it yourself). CIS was a relatively short lived and niche phase compared to EFI; which has basically been around for 30+ years at this point and is ubiquitous.
    A good ECU can work with various sensor signals (new and old). Eg, my modern Motec M150 can just as easily read a signal from my 40 year old sensors as it can a modern digital sensor. When that ECU dies, I expect I'll be able to replace it with one even more capable.
    When you factor in performance gains, fuel flexibility, and the ability to upgrade cams (CIS is very sensitive to intake reversion), then it's kind of no brainer, IMO.
    Carbs are a different story.
  17. chrisrpi02
    chrisrpi02 Rookie
    Mar 29, 2015
    13
    CA
    Chris
    Dropped off the last parts (I hope!) at the engine machine shop, so hopefully I will get the bored and honed block and heads back soon and I can start putting it all back together.
    Yeah, it is surprising! I bought the car from the second owner who only put ~1,000mi on the car before parking it. I didn't find anything wrong with the engine but form his description it sounded like maybe it sat for a while and the injectors got dirty/clogged and the engine ran poorly.
    Enginelab looks interesting but also looks like it isn't supported anymore? I would love to use OpenECU or something from New Eagle or a MicroAutoBox and write my own SW in Simulink but it is far too expensive! Looked into MegaSquirt and even the Arduino ECU project but those don't seem to be capable enough. That's probably why i want Tau-X since it is the way I would do it, I find it easier to tune and actually models the physics partially instead of modelling an accelerator pump to mimic a carburetor like most other enrichment strategies. It's been a while since i have calibrated anything though and like you said it doesn't need to be OEM perfect!
    yes, 3D printing and being able to do it with a printer from Amazon for a couple hundred bucks is a game changer.
    The individual fuel lines and manifold on the 2V are a challenge, I don't totally like my plan yet... planning to use these manifolds from McMaster https://www.mcmaster.com/5469K247/ and more Swagelok fittings. The fabricated (brazed?) pipes from NFF are much nicer and more streamlined.
    @bjunc Thanks for the info on your cam sensor, i think i am going to pursue this also. For the crank position signal I think you said you used the stock reluctance sensor on the distributor? What is the signal pattern on this? I think I will look into something like this wheel that can do both crank and cam signals in one wheel mounted on the cam. the inner holes are the "crank" trigger - 2 sets of 12 -1 teeth to account for half speed on the cam and the outer hole is the single tooth for cam sensor. I need to decide on the ECU so I can confirm the pattern needed. And i can always break it into two as the engine had 2 distributors originally so I can use one for each sensor.
  18. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,731
    The twilight zone
    Enginelab was the supplier to AEM before holley bought AEM for the other products and dropped the ECUs. At that point Jim (the owner of EngineLab) apparently decided to focus on other business. I know he was trying to sell into the general industrial controllers space. Anyway, he decided supporting individuals was taking too much of his time and stopped. They are still selling and I may reach out again, they were talking about releasing a model library to make it easy to people to build working models....but about 1/2 dozen people have found me to ask for help with 1 thing or another and if you chose this path I'd be happy to share my working model and any knowledge I have.
    Tau-x - this is basically right and I do have a version of this strategy in my model but I haven't played with tuning it yet. MoTec uses a version as well, you could look at their accel enrichment function/tuning. The tuning is kind of the important piece....MegaSquirt added a true tua-x but I think have dropped it because their user base couldn't make it work....the base tunes weren't that good, the tuning MAPs not that large so lacking OEM level accuracy and ALL the other correction need to be spot on before the tau-x will work. The MoTec system was more designed to be tunable and I kind of followed that path with mine, at least I think I did. I did a write-up on my version for someone else, but have attached here for you. If cost is no object, the M1series motecs have a development package (they sell the HW and SW separate, $4k and $2.5k last I knew, then logging it extra, everything is extra) that give you their full library and lets you create your own functions. I had an M150 ECU, then realized how much I still needed to spend and sold it and bough the EngineLab that gave me basically all the same stuff, other than the library.
    Trigger wheels....every ECU on the planet will support a 36-1 +1cam or 60-2 + 1 cam. Those have been the preferred patterns, since the 90s? at least 36 teeth is kind of where you need to be to hit the OEM spec of 0.1 degree ignition timing accuracy and get misfire detection working right (which I have not yet mastered). Lower tooth count patterns work just fine, my very first setup I used 4 (ECUs had JUST gone from 8 to 16bit) but at that low driving is fine, but you notice the ignition timing becomes retarded during rapid acceleration. Most of the really strange most patterns were created to rapid start, surveys says consumers see quick starting as a sign of quality and the older patters require up to 2 full engine revolution to synchronize but it could be much quicker so it starts randomly between like 1/4 and 2 1/4 revolutions where the new patterns will start constantly in like 1/4-1/2 revolution. I think there should be oil pressure so I prefer the older patterns :)
    The 308 CIS flywheel has 2 pins on it that the ignition reads, the way the webbing is it just kind of works out that you can add 33 more pins to make a 36-1 and use either (not both) of the OEM pickups. That is I think the neatest way to do it. The easier way to mount to the front damper or prehaps easier yet the cam mounted but that will the timing to move a little with RPM but it should be pretty repeatable so most of that should come out in tuning leaving whatever error the lower tooth count causes, 1/2 max I guess which is just touching the you can maybe see in on a dyno line.
  19. bjunc
    Jun 18, 2023
    445
    Miami, FL
    Robert
    #19 bjunc, Oct 26, 2024
    It's a sine wave. You can calibrate the ECU to trigger off any part of the wave (but usually the middle). My car has 12 teeth on the distributor reluctance sensor. I locked out the mechanical advance, but otherwise kept the wheel and sensor as-is. I then removed the original distributor "arm" that does the actual ignition distribution, and 3D printed a new arm with a magnet on the end. This acts as the sync signal (using a digital hall effect sensor). It essentially works the same way, but it's a digital step, rather than an analog wave.
    There are some best practices when it comes to triggers. Here's an excerpt from a Hall Effect sensor guide:
    From my experience, the tick over is not "instant", but it's only taking a few seconds to fire up. Honestly, you'd hardly even think to critique it. The fact that it builds a little pressure is a kind of happy accident.
    You can split the engine management, and even some modern cars do that. I'm not sure I've seen it done for less than 10 cylinders though. Even on a Boxer, which effectively behaves as two 6 cylinder engines, I still used just one ECU.
  20. mk e
    mk e F1 World Champ
    Oct 31, 2003
    13,731
    The twilight zone
    The oems do or did that for cost, 4&6 cyl ecus are high volume and cheap, 10-12 not so much.
    The 308 electric ignition was 2 4cyl units which was cost but also speed, they have old slow 8 bit processors and using 2 doubles the time they get to process between spark events. The 10-12 engines really make the ecu processor work. The motec M1 series use a processor with 2 32 channel time coprrocessing units to off load all the time critical stuff....same processor used in old (pre spec ecu) F1 applications. It was a big problem 20 years ago is my point.
    bjunc likes this.
  21. chrisrpi02
    chrisrpi02 Rookie
    Mar 29, 2015
    13
    CA
    Chris
    Finally got my block and heads back from the machine shop :) Starting to put things back together though I haven't made it too far yet!
    I did have a few questions though
    What is everyone's opinion on the ARP rod bolts? i bought the 2 sets of Alfa bolts 126-6101 but are they really better than the stock Ferrari bolts? they look pretty nice! I didn't see anything specific about replacing rod bolts or nuts in the workshop manual but got the ARP bolts thinking they would be an improvement.
    I am also replacing the bearings in the timing belt drive since i have everything apart. Got the inner bearings out and replaced but it doesn't look like there is a good way to press the gear shaft out of the timing cover housing bearing and the best way is to use the ball/T shape inner and outer bearing race puller? Like this:
    thought there might be a better way since I have the engine all apart!
    I also found one of my JE pistons pin bore is too small! need to call JE tomorrow, hopefully they can get it fixed quickly if not maybe the machine shop can hone it a bit bigger.
